#include "SampleAppsHelper.h"
#include "rsi.h"
#include "RTTasksHelpers.h"
#include "rttask.h"
#include <iostream>
#include <memory>
#include <optional>
#include <thread>
#include <chrono>
int main()
const std::string SAMPLE_APP_NAME = "Real-Time Tasks: Random Walk";
const int NUM_AXES = 1;
const int TIMEOUT_MS = 5000;
std::optional<RTTaskManager> manager;
int exitCode = -1;
std::cout << "Creating task manager..." << std::endl;
manager = RTTaskManager::Create(parameters);
RTTaskHelper::InitializeRTTaskObjects(manager.value());
std::cout << "Submitting task..." << std::endl;
params.
Repeats = RTTaskCreationParameters::RepeatForever;
RTTask task = manager->TaskSubmit(params);
std::cout << "Getting counter global tag..." << std::endl;
exitCode = -1;
std::cout << "Counter is not greater than 0. The task did not run correctly." << std::endl;
exitCode = 0;
std::cout <<
"Counter: " << counter.
Int64 << std::endl;
std::cout <<
"Average: " << average.
Double << std::endl;
std::cerr << e.what() << std::endl;
if (manager.has_value())
manager->Shutdown();
double CommandPositionGet()
int32_t MotionDoneWait()
void Stop()
Stop the task from executing.
The RealTimeTasks namespace.
int32_t Repeats
Number of times the task should execute (RepeatForever for infinite, 0 for none (one-shot)).
int32_t Period
Execution period of the task in RMP sample periods.
int64_t Int64
64-bit signed integer.
double Double
