◆ Get() [2/2]
MotionController * Get ( int32_t controllerIndex = CreationParameters::ControllerIndexDefault)
static
Description: Get a MotionController object. This will NOT start the RMP firmware if it is not already running.
It will open and map in the existing firmware if it is running.
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
controllerIndexThe index of the controller to get (multiple MotionController support). Defaults to CreationParameters::ControllerIndexDefault (0).
On Windows, the INtime node is selected by CreationParameters::NodeName, so Get() can only return controllers this process already created, plus index 0 (the default node, CreationParameters::NodeNameDefault). For any other controller, use Get(nodeName) to attach by INtime node name, or Create() with ControllerIndex and NodeName. As with all creation methods, a valid object is always returned; check ErrorLogCountGet() for errors.
Behavior change (10.7): previous versions ignored controllerIndex and returned the process's single controller, so Get(1) silently returned controller 0 on Windows. It now reports an error for indexes this process has no NodeName for.
CreationParametersGet
axis-config-ampfault.cs, axis-config-hardware-limits.cs, axis-config-phantom-axis.cs, axis-config-settling.cs, axis-config-stop-rate.cs, axis-config-userunits.cs, axis-homing-akd-drive.cs, axis-homing-ds402-drive.cs, axis-homing-master-based.cs, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, axis-motion-hold-via-position.cs, axis-motion-modify.cs, axis-motion-point-to-point.cs, axis-motion-streaming-pt-whilestopping.cs, axis-motion-streaming-pt.cs, axis-motion-streaming-pvajt.cs, axis-motion-streaming-pvt.cs, axis-motion-velocity-via-analoginput.cs, axis-status.cs, camming.cs, compensator-1d.cs, compensator-2d.cs, compensator-single-axis.cs, error-logs.cs, gcode-motion.cs, gcode-units.cs, gearing.cs, io-dedicated.cs, io-general-purpose.cs, io-iopoint-user-buffer.cs, io-iopoint.cs, io-network-pdo-sdo.cs, io-sync-outputs.cs, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, mathblock-pdo-copy.cs, multiaxis-motion-point-to-point.cs, multiaxis-motion-velocity.cs, path-3d-points.cs, path-motion.cs, path-setup-gantry.cs, recorder.cs, touch-probe.cs, userlimit-command-position-direct.cs, userlimit-digital-input-one-condition.cs, userlimit-digital-input-two-condition.cs, userlimit-estop-store-position.cs, userlimit-feedrate.cs, and userlimit-position-abort.cs.
