userlimit-digital-input-one-condition.cs
See IO: User Limits 📜 for a detailed explanation of this sample code.
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
