io-iopoint.cs
See IO: Input & Output 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to use IOPoint objects to read and write network data.
Shows how to create IOPoint objects for digital outputs and use them to control IO.
Requires an EtherCAT network with nodes that have digital outputs.
Console.WriteLine("📜 IO: IOPoint Objects");
const int NODE_INDEX = 0; // the EtherCAT Node we will be communicating with
const int OUTPUT_INDEX = 0; // the PDO Index in that Node
// create IOPoint for digital output - automatically gets memory index of specified node and output index
// set the output to false
output0.Set(false);
Console.WriteLine($"Output {OUTPUT_INDEX} set to: false");
// wait one sample for the change to take effect
controller.SampleWait(1);
// read back the value
bool outputValue = output0.Get();
Console.WriteLine($"Output {OUTPUT_INDEX} value: {outputValue}");
// set the output to true
output0.Set(true);
Console.WriteLine($"Output {OUTPUT_INDEX} set to: true");
void Set(bool state)
bool Get()
Definition rsi.h:12981
