io-network-pdo-sdo.cs
See IO: Input & Output 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to read network inputs and outputs (PDOs and SDOs).
Shows how to enumerate through all network inputs/outputs and read their properties,
including size, offset, name, and value information.
Console.WriteLine("📜 IO: Network PDOs and SDOs");
// get Input values
int inputCount = controller.NetworkInputCountGet(); // get number of Network Inputs (PDOs)
int size = controller.NetworkInputBitSizeGet(i); // read Input BitSize
int offset = controller.NetworkInputBitOffsetGet(i); // read Input BitOffset
string name = controller.NetworkInputNameGet(i); // read Input Name
UInt64 value = controller.NetworkInputValueGet(i); // read Input Value
// get Output values
int outputCount = controller.NetworkOutputCountGet(); // get number of Network Outputs (SDOs)
int size = controller.NetworkOutputBitSizeGet(i); // read Output BitSize
int offset = controller.NetworkOutputBitOffsetGet(i); // read Output BitOffset
string name = controller.NetworkOutputNameGet(i); // read Output Name
UInt64 value = controller.NetworkOutputSentValueGet(i); // read Output Value
