userlimit-digital-input-two-condition.cs
See IO: User Limits 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to configure a user limit triggered by two digital inputs.
Uses AND logic - both inputs must be high for the output to activate.
The RMP controller's User Limits compare two different input bits to specific values (high=1 or low=0).
When both conditions match (using AND logic), the specified output bit is activated (turns high).
In this example:
- Two conditions are configured via UserLimitConditionSet() to monitor two separate inputs
- Both inputs must turn high (1) to trigger the user limit
- When triggered, UserLimitOutputSet() activates the output to high (1)
Console.WriteLine("📜 User Limit: Digital Input Two Condition");
// configure user limits
IOPoint input1 = IOPoint.CreateDigitalInput(controller, userBufferAddress, bitNumber: 1);
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, bitNumber: 2);
Helpers.CheckErrors(input0);
Helpers.CheckErrors(input1);
Helpers.CheckErrors(output0);
// configure first input condition (condition 0)
number: 0,
conditionNumber: 0,
// configure second input condition (condition 1)
number: 0,
conditionNumber: 1,
addressOfUInt32: input1.AddressGet(),
userLimitMask: (uint)input1.MaskGet(),
limitValueUInt32: (uint)input1.MaskGet());
// configure user limit settings (AND logic for both conditions)
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
Console.WriteLine("Waiting for both inputs to trigger...");
if (output0.Get())
// set first input high (bit 0 only) - AND condition not met
controller.MemorySet(input0.AddressGet(), 0b0001); // only bit 0 is high
if (output0.Get())
throw new Exception("ERROR: Output should not trigger with only one input");
// set BOTH inputs high (bits 0 and 1) - AND condition met
controller.MemorySet(input1.AddressGet(), 0b0011); // both bit 0 AND bit 1 are high
throw new Exception("ERROR: User limit did not trigger when both inputs were high");
if (!output0.Get())
Console.WriteLine("✓ User limit triggered successfully - both inputs high, output activated");
output0.Set(false);
Console.WriteLine("\nUser limit digital input two condition complete.");
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
