io-iopoint-user-buffer.cs
See IO: Input & Output 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to create simulated IOPoints using user buffer memory.
Shows how to create IOPoint objects from base memory addresses and test their functionality
without requiring actual network IO hardware.
Console.WriteLine("📜 IO: IOPoint User Buffer");
const int INPUT_INDEX = 0;
const int OUTPUT_INDEX = 1; // the PDO Index in the user buffer
// get user buffer address for simulated IO point storage
UInt64 userBufferAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0);
// create simulated IOPoints based on memory address and index
IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX);
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX);
// get & set an output
bool outVal = output0.Get();
output0.Set(outVal);
Console.WriteLine($"Output 0 value: {outVal}");
// test input operations by directly writing to memory
bool inVal = input0.Get();
Console.WriteLine($"Input 0 memory set to 1, value: {inVal}");
controller.MemorySet(input0.AddressGet(), 0);
Console.WriteLine($"Input 0 memory set to 0, value: {inVal}");
void Set(bool state)
bool Get()
Definition rsi.h:12981
