io-general-purpose.cs
See IO: Input & Output 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to access General Purpose IO on EtherCAT network nodes.
Shows how to read and write digital and analog inputs/outputs.
Requires an EtherCAT network with nodes that have IO.
Console.WriteLine("📜 IO: General Purpose");
// get node
Helpers.CheckErrors(node);
// digital io
bool dIn = node.DigitalInGet(digitalInNumber: 0);
bool dOut = node.DigitalOutGet(digitalOutNumber: 0);
node.DigitalOutSet(digitalOutNumber: 0, state: dOut);
// analog io
int aIn = node.AnalogInGet(analogChannel: 0);
int aOut = node.AnalogOutGet(analogChannel: 0);
node.AnalogOutSet(analogChannel: 0, analogValue: aOut);
Console.WriteLine($"Digital Input 0: {dIn}");
Console.WriteLine($"Digital Output 0: {dOut}");
Console.WriteLine($"Analog Input 0: {aIn}");
Console.WriteLine($"Analog Output 0: {aOut}");
