User Limits
Implement User Limits to configure and trigger actions based on specific input conditions in real-time.
πŸ”Ή What are User Limits?
User Limits are a functionality through which users can configure a comparison between inputs, so an output or an interrupt can be triggered when the comparison happens.
A User Limit will evaluate conditions set by the user. These conditions will be processed in the firmware of the RMP. When these conditions are met, the User Limit will generate an interrupt and can also output 32-bit word to any location in the MotionController firmware.
Each User Limit supports up to two input conditions and one output configuration block.
πŸ”Ή When to use User Limits?
User Limits are best suited for real-time logic processing that must happen in RMP firmware, not in the user application.
  1. When you want to generate an action based on a digital input state change.
  2. When you want to generate an action based on two different input state changes.
  3. When you want to generate an action based on a specific encoder/axis position.
  4. When you want to trigger a digital output when an Axis’ Actual Position is exceeded.
Where output actions are:
  • Axis ESTOP
  • Axis STOP
  • Axis ABORT
  • Digital Output State Change
  • Proportional Gain Change
  • Monitor Different Variables
πŸ”Ή Use cases
High-Speed Sorter Machine
The client has a high-speed conveyor machine that sorts and packages seed packets. They needed to increase the throughput of their machine but were limited by their PLC because the I/O latency was too high. High-speed sorting and packaging machines require high-speed and deterministic IO. Using User Limits, the client was able to set up a comparison of the conveyor position and the location of the packet that is monitored in controller firmware. As soon as the seed packet reached the diverter position, the User Limit comparison became true and fired the β€œextend” digital output within 1 EtherCAT sample (this system sample = 1 ms) to extend the appropriate actuator and divert the packet into its box.
πŸ”Ή RapidCode API Usage
UserLimitConditionSet()
Parameter Definition
int number Enter the user limit number that will be used. Starts from 0 and goes to (UserLimitCountGet – 1.
int conditionNumber Enter 0 or 1 to define the number of input conditions to be processed. Maximum of two input conditions can be combined with AND or OR logic. ConditionNumber would be set to 0 to compare one input bit. ConditionNumber would be set to 1 to compare two input bits.
RSIUserLimitLogic logic Represents logic that user will need to select to select how an input value is compared. See Enumerations below for valid options. Ex: user wants to compare an actual position to see when actual position is greater than 2000 counts. User would have to enter RSIUserLimitLogicGT
ulong address User needs to enter the address of the input. User can call Axis.AddressGet(), MotionController.AddressGet(), or MotionController.NetworkInputAddressGet() to get the address of a particular input.
int mask Decide the bits in an address which need to be used when comparing. Use 0xFFFFFFFF when all bits should be considered. (only applicable when the Condition’s DataType is a 32-bit integer or bitmask)
int limitValue The value to be compared which needs to be set here.
This method should be called first. UserLimitConditionSet() configures user limits to evaluate an input bit. It sets a condition for when the user limit should trigger.
To track more complex input bit addresses, user can get the address from VM3 or contact us.
A user wants to compare the input condition of only a single axis position. If user intends on tracking two input conditions, call the function twice using 0 for the first condition and 1 for the 2nd condition.
If the user wants the User Limit to trigger when axis-0 position is greater than 2000 counts, then 2000 would be the limitValue.
For a Digital Input Slice I/O, if the 4th bit is changing then the user would simply enter: 0x00010000.
UserLimitConfigSet()
UserLimitConfigSet(int number, RSIUserLimitTriggerType triggerType, RSIAction action, int actionAxis, double duration)
int number Enter the user limit number that you are setting up. Starts from 0 and goes to (UserLimitCountGet – 1).
RSIUserLimitTriggerType triggerType Choose the how the condition(s) should be evaluated. RSIUserLimitTriggerType Enum
RSIAction action Choose the action you want to cause when the User Limit triggers. RSIAction Enum
int actionAxis Select the axis that the action (defined above) will occur on.
double duration Enter the time delay (in seconds) before the action is executed after the User Limit has triggered. Resolution of the duration is sample periods (default is 1ms).
Call this method after UserLimitConditionSet(). This method configures a User Limit and enables it.
UserLimitOutputSet()
UserLimitOutputSet(int number, int andMask, int orMask, ulong outputPtr, bool enabled)
int number Enter the user limit number that you want to configure to trigger an output. Starts from 0 and goes to (UserLimitCountGet – 1).
int andMask This is a 32-bit AND mask. andMask is always computed before orMask. Bit mask will be AND-ed with the data pointed by the ulong outputPtr.
int orMask This is a 32-bit OR mask. Bit mask will be OR-ed with the result of (andMask & outputPtr).
ulong outputPtr Pointer to any location in the motion controller firmware. This is a host address, like the values returned from AddressGet(...) methods.
bool enabled If TRUE, the output AND-ing and OR-ing will be executed when the User Limit triggers.
Call this method after UserLimitConfigSet(), but only if you want to configure an output to be triggered. The output will only be triggered when the User Limit is triggered.
πŸ”Ή Other User Limit Info
  • It is important to know that our API reserves a user limit per every axis.
  • The RMP controller has up to 2048 User Limit objects.
  • UserLimitCountSet should be done after either setting AxisCountSet and/or starting the network. (Internally, RapidCode Axis objects use UserLimits.) UserLimitCountSet must be called before creating an Axis or MultiAxis object with MotionController::AxisGet() or MotionController::MultiAxisGet().
  • User Limits are β€œzero” ordinate when accessing them.
πŸ”Ή FAQ’s
  1. Are User Limits monitored cyclically like PLC?
    Yes, User Limit objects are running inside the real-time motion firmware and they are cyclic (processed every cycle).
πŸ“œ Sample Code
Digital Input with 1 Condition
Trigger: Digital Input Conditions: 1
This sample code is done in AKD Drive with one Actual axis. There are a lots of available/free firmware address. Some are suggested in comment. Available/free firmware address can be found using vm3 as long as there is no label on address, it can be used.
  • C#
    Console.WriteLine("πŸ“œ User Limit: Digital Input One Condition");
    // configure user limits
    Helpers.CheckErrors(input0);
    Helpers.CheckErrors(output0);
    output0.Set(false);
    number: 0,
    conditionNumber: 0,
    number: 0,
    actionAxis: 0,
    duration: 0);
    number: 0,
    enabled: true);
    if (output0.Get())
    if (!output0.Get())
    Console.WriteLine("βœ“ User limit triggered successfully - input high, output activated");
    output0.Set(false);
    void Set(bool state)
    bool Get()
    Definition rsi.h:12981
    RSIEventType
    Event Types or Status Bits.
    Definition rsienums.h:1102
    RSIUserLimitLogic
    Definition rsienums.h:771
    Definition rsienums.h:1256
    Trigger types for UserLimits.
    Definition rsienums.h:758
  • C++
    /* CONSTANTS */
    const double USER_UNITS = 1048576; // Specify your counts per unit / user units. (the motor used in this example has 1048576 encoder pulses per revolution)
    const int IO_NODE_NUMBER = 0; // which SqNode to use for I/O?
    const int USER_LIMIT = 0; // which user limit to use?
    const int CONDITION = 0; // which condition to use (0 or 1)
    const int INPUT_BIT_NUMBER = 0; // which input bit?
    USE_HARDWARE = false;
    /* SAMPLE APP BODY */
    if (USE_HARDWARE)
    std::cout << "This sample app cannot be run without hardware." << std::endl;
    return 0;
    // RapidCode interface classes
    IO* io;
    IOPoint* digitalInput;
    // Create a new User Limit
    controller->UserLimitCountSet(1);
    // initialize the I/O class
    io = controller->IOGet(IO_NODE_NUMBER);
    digitalInput = IOPoint::CreateDigitalInput(io, INPUT_BIT_NUMBER);
    auto addr = digitalInput->AddressGet();
    auto mask1 = digitalInput->MaskGet();
    auto mask2 = digitalInput->MaskGet();
    // configure user limit to evaluate input bit
    controller->UserLimitConditionSet(USER_LIMIT,
    CONDITION,
    digitalInput->AddressGet(),
    digitalInput->MaskGet(),
    digitalInput->MaskGet());
    // enable the user limit, generate ESTOP_ABORT action when input is turned on
    controller->UserLimitConfigSet(USER_LIMIT, RSIUserLimitTriggerType::RSIUserLimitTriggerTypeSINGLE_CONDITION, RSIAction::RSIActionE_STOP_ABORT, AXIS_NUMBER, 0.0);
    printf("Waiting for the input bit to go high...\n");
    printf("\nPress Any Key To Exit.\n");
    // wait for user limit to trigger
    while (controller->OS->KeyGet((int32_t)RSIWait::RSIWaitPOLL) < 0)
    printf("User Limit state is %d\r", controller->UserLimitStateGet(USER_LIMIT));
    controller->OS->Sleep(1);
    // disable User Limit
    controller->UserLimitDisable(USER_LIMIT);
    catch (RsiError const& rsiError)
    printf("Text: %s\n", rsiError.text);
    return -1;
    return 0;
Digital Input with 2 Conditions
Trigger: Digital Input Conditions: 2
This sample code shows how to configure the RMP controller's User Limits to compare an two different input bits to a specific signal (high signal (1) OR low signal (0)). If the (2 conditions) patterns match, then the specified output bit is activated (turns high).
The INPUTS are specified in two different UserLimitConditionSet()
The OUTPUT is specified in UserLimitOutputSet()
In this example Beckhoff IO Terminals (Model EL1088 for Inputs and Model EL2008 for outputs) were used to control the Digital IO signals. Make sure to check the correct digital IO signal indexes of your system in:
RapidSetup -> Tools -> NetworkIO
  • C#
    /* This sample demonstrates how to configure a user limit triggered by two digital inputs.
    Uses AND logic - both inputs must be high for the output to activate.
    The RMP controller's User Limits compare two different input bits to specific values (high=1 or low=0).
    When both conditions match (using AND logic), the specified output bit is activated (turns high).
    In this example:
    - Two conditions are configured via UserLimitConditionSet() to monitor two separate inputs
    - Both inputs must turn high (1) to trigger the user limit
    - When triggered, UserLimitOutputSet() activates the output to high (1)
    Console.WriteLine("πŸ“œ User Limit: Digital Input Two Condition");
    IOPoint input1 = IOPoint.CreateDigitalInput(controller, userBufferAddress, bitNumber: 1);
    IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, bitNumber: 2);
    Helpers.CheckErrors(input1);
    // configure first input condition (condition 0)
    number: 0,
    conditionNumber: 0,
    // configure second input condition (condition 1)
    number: 0,
    conditionNumber: 1,
    addressOfUInt32: input1.AddressGet(),
    userLimitMask: (uint)input1.MaskGet(),
    limitValueUInt32: (uint)input1.MaskGet());
    // configure user limit settings (AND logic for both conditions)
    number: 0,
    actionAxis: 0,
    duration: 0);
    number: 0,
    enabled: true);
    Console.WriteLine("Waiting for both inputs to trigger...");
    if (output0.Get())
    // set first input high (bit 0 only) - AND condition not met
    controller.MemorySet(input0.AddressGet(), 0b0001); // only bit 0 is high
    if (output0.Get())
    throw new Exception("ERROR: Output should not trigger with only one input");
    // set BOTH inputs high (bits 0 and 1) - AND condition met
    controller.MemorySet(input1.AddressGet(), 0b0011); // both bit 0 AND bit 1 are high
    throw new Exception("ERROR: User limit did not trigger when both inputs were high");
    if (!output0.Get())
    Console.WriteLine("βœ“ User limit triggered successfully - both inputs high, output activated");
    output0.Set(false);
    Console.WriteLine("\nUser limit digital input two condition complete.");
E-Stop and Store Position
Trigger: Digital Input Conditions: 1 Event: EStop
This sample code shows how to configure a RMP controller's User Limit to compare an input bit to a specific signal (high signal (1) OR low signal (0)). If the (1 condition) pattern matches, then the specified input bit has been activated (turned high) and a User limit Event will trigger. In this example we configure a user limit to trigger when our INPUT turns high(1). Once the INPUT turns high(1) then our user limit will command an E-Stop action on the Axis and store the Axis Command Position. The INPUT is specified in UserLimitConditionSet()
The User Limit configuration is done on UserLimitConfigSet()
The specified address to record on User Limit Event is specified in UserLimitInterruptUserDataAddressSet()
The Data from the speficified addres is retrieved by calling InterruptUserDataGet()
In this example Beckhoff IO Terminals (Model EL1088 for Inputs) were used to control the Digital IO signals. Make sure to check the correct digital IO signal indexes of your system in:
  • C#
    /* This sample demonstrates how to configure a user limit that triggers an E-Stop when a digital input goes high.
    The axis command position is stored when the user limit triggers.
    Example uses Beckhoff IO Terminals (EL1088 for inputs).
    Check your digital IO signal indexes in RapidSetup -> Tools -> NetworkIO.
    Console.WriteLine("πŸ“œ User Limit: EStop and Store Position");
    const int AXIS_INDEX = Constants.AXIS_0_INDEX;
    const int INPUT_INDEX = 0;
    const int USER_DATA_INDEX = 0;
    const double DURATION = 0.125; // time delay before action executes (seconds)
    IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX);
    Axis axis = controller.AxisGet(AXIS_INDEX);
    axis.PositionSet(0);
    axis.ClearFaults();
    // start velocity motion
    axis.MoveVelocity(velocity: 10.0, accel: 20.0);
    number: 0,
    conditionNumber: CONDITION,
    // configure user limit settings (e-stop action)
    number: 0,
    action: RSIAction.RSIActionE_STOP_ABORT,
    actionAxis: AXIS_INDEX,
    duration: DURATION);
    // configure user data to store axis command position
    number: 0,
    userDataIndex: USER_DATA_INDEX,
    Console.WriteLine("Axis moving... waiting for input trigger to E-Stop");
    while (controller.InterruptWait(250) != RSIEventType.RSIEventTypeUSER_LIMIT)
    // simulate input trigger
    // wait for motion to stop
    // get the stored position data
    int triggeredUserLimit = controller.InterruptSourceNumberGet() - initialAxisCount; // account for extra user limit per axis
    double interruptPosition = controller.InterruptUserDataDoubleGet(USER_DATA_INDEX);
    double positionInUserUnits = interruptPosition / axis.UserUnitsGet();
    Console.WriteLine($"βœ“ User limit triggered - E-Stop executed");
    Console.WriteLine($" Triggered User Limit: {triggeredUserLimit}");
    Console.WriteLine($" Position at trigger: {positionInUserUnits} (user units)");
    axis.Abort();
    Console.WriteLine("\nUser limit E-Stop store position complete.");
    double UserUnitsGet()
    Definition rsienums.h:451
Change Feed Rate
Trigger: Position Conditions: 1 Event: FeedRate
Configure a UserLimit to change the FeedRate when the axis has reached a specified position.
  • C#
    /* This sample demonstrates how to configure a user limit to change the feed rate when the axis reaches a specified position.
    The user limit triggers when the command position exceeds the trigger value.
    Console.WriteLine("πŸ“œ User Limit: Feed Rate Change at Position");
    const double POSITION_TRIGGER_VALUE = 5.0;
    const double DEFAULT_FEED_RATE = 1.0;
    const double DESIRED_FEED_RATE = 2.0;
    const int DURATION = 0;
    // set initial feed rate
    axis.FeedRateSet(DEFAULT_FEED_RATE);
    Console.WriteLine($"Initial Feed Rate: {axis.FeedRateGet()}");
    double encoderMultiplier = axis.UserUnitsGet();
    // configure user limit condition (trigger when position > POSITION_TRIGGER_VALUE)
    number: 0,
    logic: RSIUserLimitLogic.RSIUserLimitLogicGT,
    addressOfDouble: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION),
    limitValueDouble: POSITION_TRIGGER_VALUE * encoderMultiplier);
    number: 0,
    actionAxis: axis.NumberGet(),
    // configure user limit output to change feed rate
    number: 0,
    limitValueDouble: DESIRED_FEED_RATE,
    outputPtr: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTARGET_FEEDRATE),
    enabled: true);
    Console.WriteLine($"Moving to position {POSITION_TRIGGER_VALUE + 1}...");
    Console.WriteLine($"Feed rate will change to {DESIRED_FEED_RATE} when position > {POSITION_TRIGGER_VALUE}");
    // start motion past the trigger position
    axis.MoveSCurve(POSITION_TRIGGER_VALUE + 1);
    // verify feed rate changed
    double finalFeedRate = axis.FeedRateGet();
    Console.WriteLine($"Final Feed Rate: {finalFeedRate}");
    if (finalFeedRate == DESIRED_FEED_RATE)
    Console.WriteLine("βœ“ User limit triggered - feed rate changed successfully");
    Console.WriteLine($"βœ— Feed rate did not change (expected: {DESIRED_FEED_RATE}, actual: {finalFeedRate})");
    Console.WriteLine("\nUser limit feed rate change complete.");
    double FeedRateGet()
    Get the axis feed rate.
    void FeedRateSet(double rate)
    int32_t NumberGet()
    Get the axis number.
Position Trigger
Trigger: Position Conditions: 1 Event: Abort
Configure a User Limit to call abort when a specified position is reached.
  • C#
    /* This sample demonstrates how to configure a user limit to abort motion when a specified position is reached.
    The user limit triggers when the command position exceeds the trigger value and executes an abort action.
    Console.WriteLine("πŸ“œ User Limit: Position Abort");
    const int USER_LIMIT_NUMBER = 0;
    const double TRIGGER_POSITION = 5.0;
    const double MOVE_POSITION = 10.0; // must be past the trigger position
    const double VELOCITY = 3.0;
    const double ACCELERATION = 2.0;
    const double DECELERATION = 2.0;
    const double JERK = 50.0;
    const int OUTPUT_INDEX = 1;
    const int WAIT_FOR_TRIGGER_MILLISECONDS = 5000;
    // create simulated output
    IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX);
    output0.Set(false); // start with output off
    // configure user limit condition (trigger when position > TRIGGER_POSITION)
    number: USER_LIMIT_NUMBER,
    conditionNumber: 0,
    addressOfDouble: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION), // for real axis use actual position
    limitValueDouble: TRIGGER_POSITION * encoderMultiplier);
    // configure user limit settings (abort action)
    action: RSIAction.RSIActionABORT,
    duration: 0,
    singleShot: true);
    enabled: true);
    Console.WriteLine($"Moving to position {MOVE_POSITION}...");
    Console.WriteLine($"User limit will trigger abort at position {TRIGGER_POSITION}");
    if (output0.Get())
    Console.WriteLine("ERROR: Output should not be triggered yet");
    // start motion
    axis.MoveSCurve(MOVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK);
    RSIEventType interruptType = controller.InterruptWait(WAIT_FOR_TRIGGER_MILLISECONDS);
    if (interruptType == RSIEventType.RSIEventTypeUSER_LIMIT)
    // note: object number for user_limit interrupts is unscaled, add axis count since there's one user limit per axis
    int interruptSource = controller.InterruptSourceNumberGet();
    // Interrupt source number uses object count, not just user limit count, so account for axis objects
    // E.g., 3 axes + 1 user limit = interrupt source 3 (0-based index)
    int expectedSource = USER_LIMIT_NUMBER + initialAxisCount;
    if (interruptSource == expectedSource)
    Console.WriteLine($"βœ“ User limit triggered - abort executed");
    Console.WriteLine($" Interrupt source: {interruptSource}");
    if (output0.Get())
    Console.WriteLine(" Output activated successfully");
    Console.WriteLine(" WARNING: Output was not activated");
    Console.WriteLine($"βœ— Got USER_LIMIT interrupt but wrong source (expected: {expectedSource}, actual: {interruptSource})");
    Console.WriteLine($"βœ— Expected USER_LIMIT interrupt but got {interruptType}");
    axis.AmpEnableSet(false);
    axis.ClearFaults();
    output0.Set(false);
    controller.UserLimitDisable(USER_LIMIT_NUMBER);
    Console.WriteLine("\nUser limit position abort complete.");
Set Position Triggered by User Limit
Custom
Configure two UserLimits. The first will trigger on a digital input and copy the Axis Actual Position to the UserBuffer and decelerate to zero velocity with TRIGGERED_MODIFY.
The second UserLimit will trigger after the first UserLimit triggers and the Axis gets to IDLE state and it will directly set the command position of an Axis from the position stored in the UserBuffer.
  • C#
    Console.WriteLine("πŸ“œ User Limit: Command Position Direct Set");
    β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
    β”‚ FIRST USER LIMIT β”‚
    β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
    number: USER_LIMIT_FIRST,
    conditionNumber: 0,
    duration: DURATION,
    singleShot: ONE_SHOT);
    β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
    β”‚ SECOND USER LIMIT β”‚
    β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
    number: USER_LIMIT_SECOND,
    conditionNumber: 0,
    userLimitMask: 1,
    limitValueUInt32: 1);
    conditionNumber: 1,
    limitValueDouble: 0.0);
    actionAxis: 0,
    duration: 0,
    // start motion
    axis.ClearFaults();
    axis.Abort();
    axis.ClearFaults();
    number: userLimitIndex,
    bool done = false;
    int interruptCount = 0;
    while (!done)
    interruptCount++;
    switch (eventType)
    done = true;
    Console.WriteLine($"\nβœ“ Completed - received {interruptCount} interrupts");
    default:
    NetworkNode * NetworkNode
    Definition rsi.h:7077
User Limit Triggered by Difference in Position of Two Axes
Trigger: Math Block Process Value Conditions: 1 Event: Abort
This sample code demonstrates how to use a MathBlock to calculate the difference of in position between two axes and trigger a UserLimit when the difference exceeds a certain value.
  • C#
    /* This sample app demonstrates configuring a MathBlock to calculate the difference of position between two axes
    and using that MathBlock process value in a UserLimit to trigger an abort action when the difference exceeds a threshold.
    This sample app requires at least 2 Axis so that positions can be read.
    Console.WriteLine("πŸ“œ MathBlock: Difference of Position UserLimit");
    const int INDEX_ZERO = 0;
    const RSIDataType DOUBLE = RSIDataType.RSIDataTypeDOUBLE;
    const RSIMathBlockOperation SUBTRACT = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
    // get rmp controller
    // set mathblock & userlimit counts before any RapidCodeObject get/create other than the controller
    controller.MathBlockCountSet(1);
    // get & configure both axes
    Helpers.CheckErrors(axis0);
    Helpers.CheckErrors(axis1);
    // set sample addresses
    ulong axis0PositionAddr = axis0.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
    ulong axis1PositionAddr = axis1.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
    ulong mbProcessValueAddr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, INDEX_ZERO);
    // MathBlock config & set (mb.value = axis0.position - axis1.position)
    var mbConfig = controller.MathBlockConfigGet(INDEX_ZERO);
    mbConfig.Operation = SUBTRACT;
    mbConfig.InputAddress0 = axis0PositionAddr; // input0: axis0 command position
    mbConfig.InputAddress1 = axis1PositionAddr; // input1: axis1 command position
    mbConfig.InputDataType0 = DOUBLE;
    mbConfig.InputDataType1 = DOUBLE;
    mbConfig.ProcessDataType = DOUBLE;
    controller.MathBlockConfigSet(INDEX_ZERO, mbConfig);
    // wait 1 sample for MathBlock config to take effect
    controller.SampleWait(1);
    // set UserLimit condition to trigger when absolute position difference exceeds threshold
    number: INDEX_ZERO,
    conditionNumber: 0,
    logic: RSIUserLimitLogic.RSIUserLimitLogicABS_GT,
    addressOfDouble: mbProcessValueAddr,
    limitValueDouble: 5 * axis0.UserUnitsGet()); // 5 revolutions (values in firmware are not scaled by user units)
    // set UserLimit to abort when condition above is met
    number: INDEX_ZERO,
    actionAxis: Constants.AXIS_0_INDEX,
    duration: 0);
    // move axis0 to trigger the UserLimit
    axis0.MoveRelative(
    relativePosition: 10, // revolutions
    vel: 1,
    accel: 1,
    decel: 1,
    jerkPct: 0);
    axis0.MotionDoneWait();
    // get results
    var axis0State = axis0.StateGet();
    // print results
    Console.WriteLine($"Axis 0 state: {axis0State} (expected: {RSIState.RSIStateERROR})");
    // verify userlimit triggered abort action
    if (axis0State != RSIState.RSIStateERROR)
    throw new Exception("❌ UserLimit did not trigger correctly - both axes should be in error state.");
    Helpers.AbortMotionObject(axis0);
    Helpers.AbortMotionObject(axis1);
    controller.UserLimitDisable(INDEX_ZERO); // disable user limit
    const int AXIS_1_INDEX
    Definition _constants.cs:21
    RSIState StateGet()
    MathBlock operations.
    Definition rsienums.h:1614
    RSIDataType
    Definition rsienums.h:784
  • C++
    /* CONSTANTS */
    const int NUM_AXES = 2; // The number of axes to configure
    const int AXIS_X_INDEX = 0; // The index of the first axis
    const int AXIS_Y_INDEX = 1; // The index of the second axis
    // User Limit Configuration
    const double MAX_POSITION_DIFFERENCE = 0.5; // the maximum position difference before the user limit triggers
    const RSIAction USER_LIMIT_ACTION = RSIAction::RSIActionABORT; // the action to take when the user limit is triggered
    const int USER_LIMIT_DURATION = 0; // the time delay before the action is executed after the User Limit has triggered
    // Motion Parameters
    const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE; // the relative position to move the axes
    const double VELOCITY = 1; // the velocity to move the axes
    const double ACCELERATION = 10; // the acceleration of the axes movement
    const double DECELERATION = 10; // the deceleration of the axes movement
    const double JERK_PCT = 0; // the jerk percentage of the axes movement
    // Create the controller
    // Variables to store initial object counts to restore later (starts at -1 to indicate it has not been set)
    int initialUserLimitCount = -1;
    int initialMathBlockCount = -1;
    int exitCode = -1;
    // Prepare the controller as defined in config.h depending on the configuration
    // Save initial object counts to restore later
    initialUserLimitCount = controller->UserLimitCountGet();
    initialMathBlockCount = controller->MathBlockCountGet();
    /* Configure the controller object counts */
    // Normally you would set the number of axes here, but for samples that is handled in the Config::SetupController function
    // Each axis has a motion object associated with it, so we need to add one more motion object than axes
    const int multiAxisIndex = controller->AxisCountGet();
    controller->MotionCountSet(multiAxisIndex + 1);
    const int userLimitIndex = initialUserLimitCount;
    controller->UserLimitCountSet(initialUserLimitCount + 1);
    const int mathBlockIndex = initialMathBlockCount;
    controller->MathBlockCountSet(initialMathBlockCount + 1);
    // Get the axes
    Axis *axisX = controller->AxisGet(AXIS_X_INDEX);
    Axis *axisY = controller->AxisGet(AXIS_Y_INDEX);
    // Configure a multiaxis for the two axes
    MultiAxis *multiAxis = controller->LoadExistingMultiAxis(multiAxisIndex);
    multiAxis->AxisRemoveAll();
    multiAxis->AxisAdd(axisX);
    multiAxis->AxisAdd(axisY);
    multiAxis->Abort(); // make sure the multiaxis is not moving
    multiAxis->ClearFaults();
    // Read the configuration of the MathBlock
    MotionController::MathBlockConfig mathBlockConfig = controller->MathBlockConfigGet(mathBlockIndex);
    // Determine which axis address type to use based on the config USE_HARDWARE flag
    // Configure the MathBlock to subtract the position of the second axis from the position of the first axis
    mathBlockConfig.InputAddress0 = axisX->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
    mathBlockConfig.InputAddress1 = axisY->AddressGet(INPUT_AXIS_ADDRESS_TYPE);
    // Set the MathBlock configuration
    controller->MathBlockConfigSet(mathBlockIndex, mathBlockConfig);
    // Wait a sample so we know the RMP is now processing the newly configured MathBlocks
    controller->SampleWait(1);
    std::cout << "MathBlock configured to subtract the position of the second axis from the position of the first axis." << std::endl;
    // Get the address of the MathBlock's ProcessValue to use in the UserLimit
    uint64_t mathBlockProcessValueAddress =
    // Configure the UserLimit to trigger when the absolute position difference is greater than MAX_POSITION_DIFFERENCE
    userLimitIndex, 0, RSIUserLimitLogic::RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE
    // Set the UserLimit action to abort motion (Note: since the axes are in a multiaxis, the other axis will also be aborted)
    userLimitIndex, RSIUserLimitTriggerType::RSIUserLimitTriggerTypeSINGLE_CONDITION, USER_LIMIT_ACTION, AXIS_X_INDEX,
    USER_LIMIT_DURATION
    std::cout << "UserLimit configured to trigger when the absolute position difference is greater than " << MAX_POSITION_DIFFERENCE
    << " and abort motion." << std::endl;
    // Command motion to trigger the UserLimit
    std::cout << "Moving the axes to trigger the UserLimit..." << std::endl;
    axisX->AmpEnableSet(true); // Enable the motor.
    axisX->MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT); // Move the axis to trigger the UserLimit.
    axisX->MotionDoneWait();
    // Disable the motor and the UserLimit
    axisX->AmpEnableSet(false); // Disable the motor.
    controller->UserLimitDisable(userLimitIndex);
    // The motion should have been aborted and both axes should be in an error state
    std::cout << "Both axes are in the error state after the UserLimit triggered (This is the intended behavior)." << std::endl;
    exitCode = 0;
    std::cout << "Error: The axes should be in an error state after the UserLimit triggers, but they are not." << std::endl;
    std::cout << "First Axis State: " << RSIStateMap.at(axisX->StateGet()) << std::endl;
    std::cout << "Second Axis State: " << RSIStateMap.at(axisY->StateGet()) << std::endl;
    exitCode = -1;
    exitCode = -1;
    if (initialUserLimitCount != -1) { controller->UserLimitCountSet(initialUserLimitCount); }
    if (initialMathBlockCount != -1) { controller->MathBlockCountSet(initialMathBlockCount); }
    // Note: The axis and motion counts are handled by the Config::Cleanup function
    Config::Cleanup(controller);
