SampleAppsHelper.h
Attention
See the following Concept pages for a detailed explanation of this sample: Helper Functions.
#ifndef SAMPLE_APPS_HELPER
#define SAMPLE_APPS_HELPER
#include <algorithm>
#include <cstdlib>
#include <iostream>
#include <string>
#include <sstream>
// Motion Controller Creation Parameters
static constexpr char RMP_PATH[] = "";
static constexpr char NIC_PRIMARY[] = "";
static constexpr char NODE_NAME[] = "";
static constexpr int CPU_AFFINITY = 0;
// If you want to use hardware, then follow the instructions in the README before setting this to true.
static constexpr bool USE_HARDWARE = false;
static void ConfigureHardwareAxes(MotionController *controller)
// If you have configured your axes using rsiconfig, RapidSetup, or RapidSetupX then you can comment out this error and return.
// IMPLEMENTATION REQUIRED: Configure the axes for hardware
std::ostringstream message;
message << "You must implement the " << __func__ << " function (found in " << __FILE__ << " line " << __LINE__ << ") to use hardware.";
// Simple Axis Configuration Example:
// (Look at the Axis: Configuration section in the RapidCode API Reference for more advanced configurations)
const int USER_UNITS = 1048576; // example for 20-bit encoder, 2^20 = 1048576
Axis *axis = controller->AxisGet(0);
axis->PositionSet(0);
axis->ErrorLimitTriggerValueSet(0.1 * USER_UNITS);
axis->ErrorLimitActionSet(RSIAction::RSIActionABORT);
axis->Abort();
axis->ClearFaults();
#if _WIN32
// Create a controller with using defined parameters
return params;
#elif __linux__
return params;
#endif
bool hasErrors = false;
std::string errorStrings("");
const RsiError *err = rsiObject->ErrorLogGet();
errorStrings += err->what();
errorStrings += "\n";
if (!err->isWarning)
hasErrors = true;
if (hasErrors)
throw std::runtime_error(errorStrings.c_str());
// Initialize the Network
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started already.
controller->NetworkStart(); // If not. Initialize The Network. (This can also be done from RapidSetup Tool)
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started again.
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error starting the network, read the network log messages
static void ShutdownTheNetwork(MotionController *controller)
// Check if the network is already shutdown
if (controller->NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
controller->NetworkStateGet() == RSINetworkState::RSINetworkStateSHUTDOWN)
return;
// Shutdown the network
controller->NetworkShutdown();
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
controller->NetworkStateGet() != RSINetworkState::RSINetworkStateSHUTDOWN) // Check if the network is shutdown.
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error shutting down the network, read the network log messages
else // Else, of network is shutdown.
static void ConfigurePhantomAxis(MotionController *controller, int axisNumber)
// Configure the specified axis as a phantom axis
Axis *axis = controller->AxisGet(axisNumber); // Initialize Axis class
CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly
10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis->PositionToleranceFineSet(positionToleranceMax
); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
static int initialAxisCount = -1;
static int initialMotionCount = -1;
static void SetupController(MotionController *controller, int numAxes = 0)
// Start or shutdown the network depending on the configuration
StartTheNetwork(controller);
else if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
message << "The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n"
<< "If you intended to run with hardware, then follow the steps in README.md and /src/SampleAppsHelper.h\n"
<< "Otherwise, shutdown the network before running the sample apps with phantom axes.";
// Check if we are using hardware or phantom axes
// Let the user defined function configure the axes
// Check that there are enough axes configured
int axisCount = controller->AxisCountGet();
if (axisCount < numAxes)
message << "Error! Not enough axes configured. Expected " << numAxes << " axes but only found " << axisCount << " axes."
<< "Please configure the axes in the SampleAppsConfig::ConfigureHardwareAxes function.";
// Record the initial object counts to restore later
initialAxisCount = controller->AxisCountGet();
// Add phantom axes for the sample app if needed
if (numAxes > initialAxisCount)
controller->AxisCountSet(numAxes);
for (int i = 0; i < numAxes; i++)
ConfigurePhantomAxis(controller, i);
static void Cleanup(MotionController* controller)
if (initialAxisCount != -1) { controller->AxisCountSet(initialAxisCount); }
// Reset the object counts
ShutdownTheNetwork(controller);
controller->Reset(); // Reset the controller to ensure it is in a known state.
static void ClearControllerCounts(MotionController *controller)
// Clear the counts
controller->AxisCountSet(0);
controller->MotionCountSet(0);
controller->UserLimitCountSet(0);
static void SetupControllerForPhantoms(MotionController *controller, int axisCount, std::vector<int> axisNums)
ClearControllerCounts(controller);
controller->AxisCountSet(axisCount);
for (auto axisNum : axisNums)
ConfigurePhantomAxis(controller, axisNum);
std::cout << "----------------------------------------------------------------------------------------------------\n";
std::cout << "Running " << sampleAppName << " Sample App\n";
std::cout << "----------------------------------------------------------------------------------------------------\n" << std::endl;
std::cout << "\n----------------------------------------------------------------------------------------------------\n";
if (exitCode == 0)
std::cout << sampleAppName << " Sample App Completed Successfully\n";
std::cout << sampleAppName << " Sample App Failed with Exit Code: " << exitCode << "\n";
} // namespace SampleAppsHelper
#endif // SAMPLE_APPS_HELPER
Set the Amp Fault action.
Set the motor type.
Definition rsi.h:5789
void Reset()
Reset the controller which stops and restarts the RMP firmware.
void NetworkShutdown()
Shutdown the EtherCAT network.
void NetworkStart()
Start the network, doing both a discovery followed by starting to OPERATIONAL state.
const char *const NetworkLogMessageGet(int32_t messageIndex)
int32_t AxisCountGet()
int32_t MotionCountGet()
Definition rsi.h:800
int32_t ErrorLogCountGet()
Definition rsi.h:184
Definition rsi.h:111
bool isWarning
Definition rsi.h:120
Definition rsi.h:173
Shuts down the network communication for the given MotionController.
Clears count settings for axes, motion, and user limits on the controller.
SampleAppsHelper namespace provides static methods for common tasks in RMP applications.
Initial axis count to restore later (-1 indicates it has not been set)
Initial motion count to restore later (-1 indicates it has not been set)
char NodeName[PathLengthMaximum]
[Windows/INtime] Indicate the INtime node on which the RMP and RMPNetwork processes run.
Definition rsi.h:994
Definition rsi.h:962
int32_t CpuAffinity
Definition rsi.h:1014
char NicPrimary[PathLengthMaximum]
Primary EtherCAT Network Interface (NIC) name.
Definition rsi.h:968
Definition rsi.h:882
Definition rsi.h:866
Configures the hardware axes according to user specified implementation.
This struct provides static methods and constants for user configuration in RMP applications....
(Linux only) CPU core to use. This should be an isolated core.
Name of the NIC to use for the EtherCAT network (not needed for running on phantom axes)
Path to the RMP.rta file (usually the RapidSetup folder).
(Windows only) INtime node name. Use "" for default node.
