SampleAppsHelper namespace provides static methods for common tasks in RMP applications. More...
Functions | |
| static void | CheckErrors (RapidCodeObject *rsiObject) |
| Checks for errors in the given RapidCodeObject and throws an exception if any non-warning errors are found. | |
| static void | Cleanup (MotionController *controller) |
| Cleanup the controller and restore the object counts to the original values. | |
| static void | ClearControllerCounts (MotionController *controller) |
| Clears count settings for axes, motion, and user limits on the controller. | |
| static void | ConfigurePhantomAxis (MotionController *controller, int axisNumber) |
| Configures a specified axis as a phantom axis with custom settings. | |
| static MotionController::CreationParameters | GetCreationParameters () |
| Returns a MotionController::CreationParameters object with user-defined parameters. | |
| static void | PrintFooter (std::string sampleAppName, int exitCode) |
| Print a message to indicate the sample app has finished and if it was successful or not. | |
| static void | PrintHeader (std::string sampleAppName) |
| Print a start message to indicate that the sample app has started. | |
| static void | SetupController (MotionController *controller, int numAxes=0) |
| Setup the controller with user defined axis counts and configuration. | |
| static void | SetupControllerForHardware (MotionController *controller) |
| Sets up the controller for hardware use by resetting it and starting the network. | |
| static void | SetupControllerForPhantoms (MotionController *controller, int axisCount, std::vector< int > axisNums) |
| Sets up the controller for phantom axes, including configuring specified axes as phantom. | |
| static void | ShutdownTheNetwork (MotionController *controller) |
| Shuts down the network communication for the given MotionController. | |
| static void | StartTheNetwork (MotionController *controller) |
| Starts the network communication for the given MotionController. | |
This namespace encapsulates operations such as error checking, network management, and controller configuration to streamline application development.
