C#
Check Errors:
Check the RSIError log for any logged errors. Read and print all the errors. Ignore warnings.
public static void CheckErrors(RapidCodeObject rsiObject)
var hasErrors = false;
var errorStrBuilder = new System.Text.StringBuilder();
var errorMsg = rsiError.isWarning ? $"WARNING: {rsiError.Message}" : $"ERROR: {rsiError.Message}";
errorStrBuilder.AppendLine(errorMsg);
if (hasErrors)
throw new Exception(errorStrBuilder.ToString());
Network Start:
Start the network and print any errors encountered.
public static void NetworkStart(MotionController controller)
Console.WriteLine("Starting Network..");
Console.WriteLine($"Network start error: {startError} ({(int)startError})");
throw new SystemException("Expected OPERATIONAL state but the network did not get there.");
Console.WriteLine("Network Started");
Network Shutdown:
Shutdown the network and print any errors encountered.
return;
Console.WriteLine("Shutting down the network..");
throw new SystemException("Expected SHUTDOWN state but the network did not get there.");
Console.WriteLine("Network Shutdown");
Controller Setup:
Phantom Axis Reset:
Resets a phantom axis to a known state by disabling limits, setting tolerances, and clearing faults.
throw new Exception(@$"Axis {phantomAxis.NumberGet()} is not configured as a phantom axis.
Please ensure the axis is set to phantom before calling PhantomAxisConfigure.");
C++
Sample Apps Config:
This struct provides static methods and constants for user configuration in RMP applications. Everything in this struct is expected to be modifed by the user.
std::ostringstream message;
message << "You must implement the " << __func__ << " function (found in " << __FILE__ << " line " << __LINE__ << ") to use hardware.";
Get Creation Parameters:
#if _WIN32
MotionController::CreationParameters params;
return params;
#elif __linux__
return params;
#endif
Check Errors:
bool hasErrors = false;
std::string errorStrings("");
errorStrings += err->
what();
errorStrings += "\n";
hasErrors = true;
if (hasErrors)
throw std::runtime_error(errorStrings.c_str());
Start-The-Network-cpp:
if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
if (controller->
Shutdown-The-Network-cpp:
if (controller->
NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
return;
if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
Configure-Phantom-Axis-cpp:
Axis *axis = controller->
AxisGet(axisNumber);
10.0;
Setup-Controller-cpp:
else if (controller->
message << "The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n"
<< "If you intended to run with hardware, then follow the steps in README.md and /src/SampleAppsHelper.h\n"
<< "Otherwise, shutdown the network before running the sample apps with phantom axes.";
if (axisCount < numAxes)
message << "Error! Not enough axes configured. Expected " << numAxes << " axes but only found " << axisCount << " axes."
<< "Please configure the axes in the SampleAppsConfig::ConfigureHardwareAxes function.";
for (int i = 0; i < numAxes; i++)
Setup-Controller-For-Hardware-cpp:
Clear-Controller-Counts-cpp:
Clears count settings for axes, motion, and user limits on the controller.
Setup-Controller-For-Phantoms-cpp:
for (auto axisNum : axisNums)
Print-Header-cpp:
std::cout << "----------------------------------------------------------------------------------------------------\n";
std::cout << "Running " << sampleAppName << " Sample App\n";
std::cout << "----------------------------------------------------------------------------------------------------\n" << std::endl;
Print-Footer-cpp:
static void PrintFooter(std::string sampleAppName,
int exitCode)
std::cout << "\n----------------------------------------------------------------------------------------------------\n";
if (exitCode == 0)
std::cout << sampleAppName << " Sample App Completed Successfully\n";
std::cout << sampleAppName << " Sample App Failed with Exit Code: " << exitCode << "\n";
