static |
| controller | Pointer to the MotionController containing the axis. |
| axisNumber | The number of the axis to configure as a phantom axis. |
| std::invalid_argument | Thrown if an invalid axis number is provided. {
// Configure the specified axis as a phantom axis
Axis *axis = controller->AxisGet(axisNumber); // Initialize Axis class
CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly
10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis->PositionToleranceFineSet(positionToleranceMax
); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
Definition at line 202 of file SampleAppsHelper.h.
