90#ifndef SAMPLE_APPS_HELPER
91#define SAMPLE_APPS_HELPER
143 throw std::runtime_error(
"You must implement the ConfigureHardwareAxes function (found in /include/SampleAppsHelper.h) to use hardware.");
202 bool hasErrors =
false;
203 std::string errorStrings(
208 errorStrings += err->
what();
209 errorStrings +=
"\n";
219 throw std::runtime_error(errorStrings.c_str());
234 if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
236 std::cout <<
"Starting Network.." << std::endl;
240 if (controller->
244 for (
int i = 0; i < messagesToRead; i++)
248 throw std::runtime_error(
"Expected OPERATIONAL state but the network did not get there.");
252 std::cout <<
"Network Started" << std::endl << std::endl;
267 if (controller->
NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
268 controller->
NetworkStateGet() == RSINetworkState::RSINetworkStateSHUTDOWN)
274 std::cout <<
"Shutting down the network.." << std::endl;
277 if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
278 controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateSHUTDOWN)
282 for (
286 throw std::runtime_error(
"Expected SHUTDOWN state but the network did not get there.");
290 std::cout <<
"Network Shutdown" << std::endl << std::endl;
321 const double positionToleranceMax =
322 std::numeric_limits<double>::max() /
380 if (controller->
381 controller->
383 std::cout <<
"The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n";
384 std::cout <<
"If you intended to run with hardware, then follow the steps in README.md and /include/SampleAppsHelper.h\n";
435 for (
auto axisNum : axisNums)
449 std::cout <<
"----------------------------------------------------------------------------------------------------\n";
450 std::cout <<
"Running " << sampleAppName <<
" Sample App\n";
451 std::cout <<
"----------------------------------------------------------------------------------------------------\n" << std::endl;
463 std::cout <<
"\n----------------------------------------------------------------------------------------------------\n";
466 std::cout << sampleAppName <<
" Sample App Completed Successfully\n";
470 std::cout << sampleAppName <<
" Sample App Failed with Exit Code: " << exitCode <<
"\n";
472 std::cout <<
Set the Amp Fault action.
Set the motor type.
void Reset()
Reset the controller which stops and restarts the RMP firmware.
const char *const NetworkLogMessageGet(int32_t messageIndex)
int32_t NetworkLogMessageCountGet()
void NetworkShutdown()
Shutdown the network. For EtherCAT, this will kill the RMPNetwork process.
void NetworkStart()
Start the network with RSINetworkStartupMethodNORMAL.
int32_t ErrorLogCountGet()
bool isWarning
static void ConfigurePhantomAxis(MotionController *controller, int axisNumber)
static void ShutdownTheNetwork(MotionController *controller)
Shuts down the network communication for the given MotionController.
static void ClearControllerCounts(MotionController *controller)
Clears count settings for axes, motion, and user limits on the controller.
static void SetupController(MotionController *controller)
SampleAppsHelper namespace provides static methods for common tasks in RMP applications.
char NodeName[PathLengthMaximum]
[Windows/INtime] Indicate the INtime node on which the RMP and RMPNetwork processes run.
int32_t CpuAffinity
char NicPrimary[PathLengthMaximum]
Primary EtherCAT Network Interface (NIC) name.
static void ConfigureHardwareAxes(MotionController *controller, std::vector< Axis * > axes)
Configures the hardware axes according to user specified implementation.
This struct provides static methods and constants for user configuration in RMP applications....
static constexpr int CPU_AFFINITY
(Linux only) CPU core to use. This should be an isolated core.
static constexpr int AXIS_Y_USER_UNITS
User units for the second axis.
static constexpr int AXIS_COUNT
Number of axes to configure on the controller.
static constexpr int USER_LIMIT_COUNT
Number of user limits to configure on the controller.
static constexpr int MOTION_COUNT
Number of motion objects to configure on the controller.
static constexpr char NIC_PRIMARY[]
Name of the NIC to use for the EtherCAT network (not needed for running on phantom axes)
static constexpr int AXIS_X_INDEX
Index of the first axis to use in the sample apps.
static constexpr int MATH_BLOCK_COUNT
Number of math block objects to configure on the controller.
static constexpr bool USE_HARDWARE
static constexpr char RMP_PATH[]
Path to the RMP.rta file (usually the RapidSetup folder).
static constexpr int AXIS_X_USER_UNITS
User units for the first axis.
static constexpr int RECORDER_COUNT
Number of recorder objects to configure on the controller.
static constexpr char NODE_NAME[]
(Windows only) INtime node name. Use "" for default node.
static constexpr int AXIS_Y_INDEX
Index of the second axis to use in the sample apps.
