IO: User Limits
Learn how to use User Limits in C#.
In this page:
šŸ“œ User Limit: Digital Input One Condition
Learn how to configure a User Limits 📖 triggered by a single digital input. When the input matches the specified value, the configured output is activated.
Trigger: Digital Input Conditions: 1
Console.WriteLine("šŸ“œ User Limit: Digital Input One Condition");
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
Console.WriteLine("āœ“ User limit triggered successfully - input high, output activated");
output0.Set(false);
Console.WriteLine($"āŒ Error: {e.Message}");
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
šŸ“œ User Limit: Digital Input Two Condition
Learn how to configure a User Limits 📖 triggered by two digital inputs with AND logic. Both inputs must be high for the output to activate.
Trigger: Digital Input Conditions: 2
/* This sample demonstrates how to configure a user limit triggered by two digital inputs.
Uses AND logic - both inputs must be high for the output to activate.
The RMP controller's User Limits compare two different input bits to specific values (high=1 or low=0).
When both conditions match (using AND logic), the specified output bit is activated (turns high).
In this example:
- Two conditions are configured via UserLimitConditionSet() to monitor two separate inputs
- Both inputs must turn high (1) to trigger the user limit
- When triggered, UserLimitOutputSet() activates the output to high (1)
Console.WriteLine("šŸ“œ User Limit: Digital Input Two Condition");
IOPoint input1 = IOPoint.CreateDigitalInput(controller, userBufferAddress, bitNumber: 1);
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, bitNumber: 2);
Helpers.CheckErrors(input1);
// configure first input condition (condition 0)
number: 0,
conditionNumber: 0,
// configure second input condition (condition 1)
number: 0,
conditionNumber: 1,
addressOfUInt32: input1.AddressGet(),
userLimitMask: (uint)input1.MaskGet(),
limitValueUInt32: (uint)input1.MaskGet());
// configure user limit settings (AND logic for both conditions)
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
Console.WriteLine("Waiting for both inputs to trigger...");
if (output0.Get())
// set first input high (bit 0 only) - AND condition not met
controller.MemorySet(input0.AddressGet(), 0b0001); // only bit 0 is high
if (output0.Get())
throw new Exception("ERROR: Output should not trigger with only one input");
// set BOTH inputs high (bits 0 and 1) - AND condition met
controller.MemorySet(input1.AddressGet(), 0b0011); // both bit 0 AND bit 1 are high
throw new Exception("ERROR: User limit did not trigger when both inputs were high");
if (!output0.Get())
Console.WriteLine("āœ“ User limit triggered successfully - both inputs high, output activated");
output0.Set(false);
Console.WriteLine("\nUser limit digital input two condition complete.");
šŸ“œ User Limit: EStop and Store Position
Learn how to configure a User Limits 📖 that triggers an E-Stop when a digital input goes high. The axis command position is stored when the user limit triggers.
Trigger: Digital Input Conditions: 1 Event: EStop
/* This sample demonstrates how to configure a user limit that triggers an E-Stop when a digital input goes high.
Example uses Beckhoff IO Terminals (EL1088 for inputs).
Check your digital IO signal indexes in RapidSetup -> Tools -> NetworkIO.
Console.WriteLine("šŸ“œ User Limit: EStop and Store Position");
const int AXIS_INDEX = Constants.AXIS_0_INDEX;
const int INPUT_INDEX = 0;
const int CONDITION = 0;
const int USER_DATA_INDEX = 0;
const double DURATION = 0.125; // time delay before action executes (seconds)
IOPoint input0 = IOPoint.CreateDigitalInput(controller, userBufferAddress, INPUT_INDEX);
Axis axis = controller.AxisGet(AXIS_INDEX);
axis.PositionSet(0);
axis.ClearFaults();
// start velocity motion
axis.MoveVelocity(velocity: 10.0, accel: 20.0);
number: 0,
conditionNumber: CONDITION,
// configure user limit settings (e-stop action)
number: 0,
action: RSIAction.RSIActionE_STOP_ABORT,
actionAxis: AXIS_INDEX,
duration: DURATION);
// configure user data to store axis command position
number: 0,
userDataIndex: USER_DATA_INDEX,
Console.WriteLine("Axis moving... waiting for input trigger to E-Stop");
// wait for user limit to trigger
while (controller.InterruptWait(250) != RSIEventType.RSIEventTypeUSER_LIMIT)
// simulate input trigger
// wait for motion to stop
// get the stored position data
int triggeredUserLimit = controller.InterruptSourceNumberGet() - initialAxisCount; // account for extra user limit per axis
double interruptPosition = controller.InterruptUserDataDoubleGet(USER_DATA_INDEX);
double positionInUserUnits = interruptPosition / axis.UserUnitsGet();
Console.WriteLine($"āœ“ User limit triggered - E-Stop executed");
Console.WriteLine($" Triggered User Limit: {triggeredUserLimit}");
Console.WriteLine($" Position at trigger: {positionInUserUnits} (user units)");
axis.Abort();
Console.WriteLine("\nUser limit E-Stop store position complete.");
double UserUnitsGet()
Definition rsienums.h:451
šŸ“œ User Limit: Feed Rate Change at Position
Learn how to configure a User Limits 📖 to change the feed rate when the axis reaches a specified position.
Trigger: Position Conditions: 1 Event: FeedRate
/* This sample demonstrates how to configure a user limit to change the feed rate when the axis reaches a specified position.
The user limit triggers when the command position exceeds the trigger value.
Console.WriteLine("šŸ“œ User Limit: Feed Rate Change at Position");
const double POSITION_TRIGGER_VALUE = 5.0;
const double DEFAULT_FEED_RATE = 1.0;
const double DESIRED_FEED_RATE = 2.0;
const int DURATION = 0;
// set initial feed rate
axis.FeedRateSet(DEFAULT_FEED_RATE);
Console.WriteLine($"Initial Feed Rate: {axis.FeedRateGet()}");
double encoderMultiplier = axis.UserUnitsGet();
// configure user limit condition (trigger when position > POSITION_TRIGGER_VALUE)
number: 0,
logic: RSIUserLimitLogic.RSIUserLimitLogicGT,
addressOfDouble: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION),
limitValueDouble: POSITION_TRIGGER_VALUE * encoderMultiplier);
number: 0,
actionAxis: axis.NumberGet(),
// configure user limit output to change feed rate
number: 0,
limitValueDouble: DESIRED_FEED_RATE,
outputPtr: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTARGET_FEEDRATE),
enabled: true);
Console.WriteLine($"Moving to position {POSITION_TRIGGER_VALUE + 1}...");
Console.WriteLine($"Feed rate will change to {DESIRED_FEED_RATE} when position > {POSITION_TRIGGER_VALUE}");
// start motion past the trigger position
axis.MoveSCurve(POSITION_TRIGGER_VALUE + 1);
// verify feed rate changed
double finalFeedRate = axis.FeedRateGet();
Console.WriteLine($"Final Feed Rate: {finalFeedRate}");
if (finalFeedRate == DESIRED_FEED_RATE)
Console.WriteLine("āœ“ User limit triggered - feed rate changed successfully");
Console.WriteLine($"āœ— Feed rate did not change (expected: {DESIRED_FEED_RATE}, actual: {finalFeedRate})");
Console.WriteLine("\nUser limit feed rate change complete.");
double FeedRateGet()
Get the axis feed rate.
void FeedRateSet(double rate)
int32_t NumberGet()
Get the axis number.
šŸ“œ User Limit: Position Abort
Learn how to configure a User Limits 📖 to abort motion when a specified position is reached.
Trigger: Position Conditions: 1 Event: Abort
/* This sample demonstrates how to configure a user limit to abort motion when a specified position is reached.
The user limit triggers when the command position exceeds the trigger value and executes an abort action.
Console.WriteLine("šŸ“œ User Limit: Position Abort");
const int USER_LIMIT_NUMBER = 0;
const double TRIGGER_POSITION = 5.0;
const double MOVE_POSITION = 10.0; // must be past the trigger position
const double VELOCITY = 3.0;
const double ACCELERATION = 2.0;
const double DECELERATION = 2.0;
const double JERK = 50.0;
const int OUTPUT_INDEX = 1;
const int WAIT_FOR_TRIGGER_MILLISECONDS = 5000;
// create simulated output
IOPoint output0 = IOPoint.CreateDigitalOutput(controller, userBufferAddress, OUTPUT_INDEX);
output0.Set(false); // start with output off
// configure user limit condition (trigger when position > TRIGGER_POSITION)
number: USER_LIMIT_NUMBER,
conditionNumber: 0,
addressOfDouble: axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION), // for real axis use actual position
limitValueDouble: TRIGGER_POSITION * encoderMultiplier);
// configure user limit settings (abort action)
action: RSIAction.RSIActionABORT,
duration: 0,
singleShot: true);
enabled: true);
Console.WriteLine($"Moving to position {MOVE_POSITION}...");
Console.WriteLine($"User limit will trigger abort at position {TRIGGER_POSITION}");
if (output0.Get())
Console.WriteLine("ERROR: Output should not be triggered yet");
// start motion
axis.MoveSCurve(MOVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK);
RSIEventType interruptType = controller.InterruptWait(WAIT_FOR_TRIGGER_MILLISECONDS);
if (interruptType == RSIEventType.RSIEventTypeUSER_LIMIT)
// note: object number for user_limit interrupts is unscaled, add axis count since there's one user limit per axis
int interruptSource = controller.InterruptSourceNumberGet();
// Interrupt source number uses object count, not just user limit count, so account for axis objects
// E.g., 3 axes + 1 user limit = interrupt source 3 (0-based index)
int expectedSource = USER_LIMIT_NUMBER + initialAxisCount;
if (interruptSource == expectedSource)
Console.WriteLine($"āœ“ User limit triggered - abort executed");
Console.WriteLine($" Interrupt source: {interruptSource}");
if (output0.Get())
Console.WriteLine(" Output activated successfully");
Console.WriteLine(" WARNING: Output was not activated");
Console.WriteLine($"āœ— Got USER_LIMIT interrupt but wrong source (expected: {expectedSource}, actual: {interruptSource})");
Console.WriteLine($"āœ— Expected USER_LIMIT interrupt but got {interruptType}");
axis.AmpEnableSet(false);
axis.ClearFaults();
output0.Set(false);
controller.UserLimitDisable(USER_LIMIT_NUMBER);
Console.WriteLine("\nUser limit position abort complete.");
šŸ“œ User Limit: Command Position Direct Set
Learn how to use two User Limits 📖 in sequence for advanced control. First user limit triggers on digital input and executes triggered modify to decelerate. Second user limit triggers when first completes and axis is idle.
Trigger: Custom Conditions: Multiple
Console.WriteLine("šŸ“œ User Limit: Command Position Direct Set");
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ FIRST USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_FIRST,
conditionNumber: 0,
duration: DURATION,
singleShot: ONE_SHOT);
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ SECOND USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_SECOND,
conditionNumber: 0,
userLimitMask: 1,
limitValueUInt32: 1);
conditionNumber: 1,
limitValueDouble: 0.0);
actionAxis: 0,
duration: 0,
// start motion
axis.ClearFaults();
axis.Abort();
axis.ClearFaults();
number: userLimitIndex,
bool done = false;
int interruptCount = 0;
while (!done)
interruptCount++;
switch (eventType)
done = true;
Console.WriteLine($"\nāœ“ Completed - received {interruptCount} interrupts");
default:
NetworkNode * NetworkNode
Definition rsi.h:7077
