Use helper functions to learn about RapidCode good practices.
- Warning
In this page:
⚙️ Check Errors
Checks for errors in a RapidCodeObject and throws an exception if non-warning errors are found. This helper reads and prints all errors from the error log, ignoring warnings. Use after any RapidCode API call that might generate errors.
void CheckErrors(RapidCodeObject *rsiObject,
const std::source_location &location = std::source_location::current())
bool hasErrors = false;
std::string errorStrings("");
errorStrings += err->
what();
errorStrings += "\n";
hasErrors = true;
if (hasErrors)
std::ostringstream message;
message << "Error! In "
<< location.file_name() << '('
<< location.line() << ':'
<< location.column() << ") `"
<< location.function_name() << "`:\n"
<< errorStrings;
⚙️ Network Start
Starts the network communication for a MotionController and verifies it reaches OPERATIONAL state. Prints network log messages if the network fails to start. Throws an exception if OPERATIONAL state is not reached.
if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL)
if (controller->
⚙️ Network Shutdown
Shuts down the network communication for a MotionController. Verifies the network reaches SHUTDOWN or UNINITIALIZED state. Prints network log messages if shutdown fails.
if (controller->
NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
return;
if (controller->
NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
