71using RSI.RapidCode.dotNET;
78public class AxisConfig : SampleAppTestBase
80 [Test, Timeout(Constants.MAX_TEST_TIME)]
81 public void AxisSettling()
90 const double POSITION_TOLERANCE_FINE = 200;
91 const double POSITION_TOLERANCE_COARSE = 300;
92 const double VELOCITY_TOLERANCE = 12000;
93 const double SETTLING_TIME = 5;
110 Assert.That(posTolFine, Is.EqualTo(POSITION_TOLERANCE_FINE),
"The getter function should return a value equal to POSITION_TOLERANCE_FINE");
111 Assert.That(posTolCoarse, Is.EqualTo(POSITION_TOLERANCE_COARSE),
"The getter function should return a value equal to POSITION_TOLERANCE_COARSE");
112 Assert.That(velTol, Is.EqualTo(VELOCITY_TOLERANCE),
"The getter function should return a value equal to VELOCITY_TOLERANCE");
113 Assert.That(setTime, Is.EqualTo(SETTLING_TIME),
"The getter function should return a value equal to SETTLING_TIME");
121 [Test, Timeout(Constants.MAX_TEST_TIME)]
122 public void ConfigAmpFault()
130 const double AMP_FAULT_DURATION_TIME = 1;
147 Assert.That(isEnabled, Is.EqualTo(
false),
"The getter function should return a value equal to false");
148 Assert.That(faultAction, Is.EqualTo(
RSIAction.RSIActionABORT),
"The getter function should return a value equal to RSIActionABORT");
149 Assert.That(faultTriggerState, Is.EqualTo(
false),
150 Assert.That(faultDuration, Is.EqualTo(AMP_FAULT_DURATION_TIME),
"The getter function should return a value equal to AMP_FAULT_DURATION_TIME");
158 [Test, Timeout(Constants.MAX_TEST_TIME)]
159 public void SetUserUnits()
165 const int ENCODER_RESOLUTION_BITS = 20;
169 double USER_UNITS = Math.Pow(2, ENCODER_RESOLUTION_BITS);
180 Assert.That(userUnits, Is.EqualTo(USER_UNITS));
181 Assert.That(userUnits, Is.EqualTo(1048576));
186 [Test, Timeout(Constants.MAX_TEST_TIME)]
187 public void StopRate()
190 const double STOP_RATE = 1.2;
191 const double ESTOP_RATE = 1.3;
192 const double ESTOP_DECELERATION_RATE_T = 1.5;
197 Assert.That(axis.
StopTimeGet(), Is.EqualTo(STOP_RATE));
198 Assert.That(axis.
EStopTimeGet(), Is.EqualTo(ESTOP_RATE));
203 const double STOP_RATE_DEFAULT = 1.0;
204 const double ESTOP_RATE_DEFAULT = 0.05;
205 const double ESTOP_DECELERATION_RATE = 1000;
214 [Test, Timeout(Constants.MAX_TEST_TIME)]
215 public void HardwareLimits()
221 const bool ACTIVE_HIGH =
true;
222 const bool ACTIVE_LOW =
false;
223 const double HW_POS_DURATION_TIME = 0.01;
224 const double HW_NEG_DURATION_TIME = 0.01;
249 Assert.That(hPosLimAct, Is.EqualTo(
RSIAction.RSIActionE_STOP),
"Hardware Positive Limit Action should be set to RSIAction.RSIActionE_STOP");
250 Assert.That(hPosLimTrigState, Is.EqualTo(ACTIVE_HIGH),
"Hardware Positive Limit TriggerState should be set to ACTIVE_HIGH");
251 Assert.That(hPosLimDur, Is.EqualTo(HW_POS_DURATION_TIME),
"Hardware Positive Limit Duration set to HW_POS_DURATION_TIME");
253 Assert.That(hNegLimAct, Is.EqualTo(
254 Assert.That(hNegLimTrigState, Is.EqualTo(ACTIVE_LOW),
"Hardware Positive Limit TriggerState should be set to ACTIVE_LOW");
255 Assert.That(hNegLimDur, Is.EqualTo(HW_POS_DURATION_TIME),
262 public void PhantomAxis()
269 axis = controller.
AxisGet(axisNumber);
281 const double positionToleranceMax = Double.MaxValue / 10.0;
RSIAction AmpFaultActionGet()
Get the Amp Fault action.
double SettlingTimeGet()
Get the Settling time.
double UserUnitsGet()
bool AmpEnableGet()
sets the trigger state.
Set the Amp Fault action.
double AmpFaultDurationGet()
trigger state return.
double EStopDecelerationGet()
double VelocityToleranceGet()
Set the motor type.
Trigger state return.
Sets the trigger state.
Set the settling time.
int32_t AxisCountGet()
double EStopTimeGet()
double StopTimeGet()
