HelperFunctions.cs
46using RSI.RapidCode.dotNET; // Import our RapidCode Library
47using System;
48using NUnit.Framework;
49
50
51
52#if DOXYGEN // RSI internal documentation use only
53using RSI.RapidCode;
55#endif
56
60public static class HelperFunctions
61{
75 public static void CheckErrors(RapidCodeObject rsiObject)
76 {
77 bool hasErrors = false;
78 System.Text.StringBuilder errorStringBuilder = new System.Text.StringBuilder();
79 while (rsiObject.ErrorLogCountGet() > 0)
80 {
81 RsiError error = rsiObject.ErrorLogGet();
82
83 if (error.isWarning)
84 {
85 errorStringBuilder.AppendLine("WARNING: " + error.Message);
86 }
87 else
88 {
89 hasErrors = true;
90 errorStringBuilder.AppendLine("ERROR: " + error.Message);
91 }
92 }
93
94 if (errorStringBuilder.Length > 0)
95 {
96 Console.WriteLine(errorStringBuilder.ToString());
97 }
98
99 if (hasErrors)
100 {
101 throw new Exception(errorStringBuilder.ToString());
102 }
103 }
106
120 public static void StartTheNetwork(MotionController controller)
121 {
122 // Initialize the Network
123 if (controller.NetworkStateGet() != RSINetworkState.RSINetworkStateOPERATIONAL) // Check if network is started already.
124 {
125 Console.WriteLine("Starting Network..");
126 controller.NetworkStart(); // If not. Initialize The Network. (This can also be done from RapidSetup Tool)
127 }
128
129 if (controller.NetworkStateGet() != RSINetworkState.RSINetworkStateOPERATIONAL) // Check if network is started again.
130 {
131 int messagesToRead = controller.NetworkLogMessageCountGet(); // Some kind of error starting the network, read the network log messages
132
133 for (int i = 0; i < messagesToRead; i++)
134 {
135 Console.WriteLine(controller.NetworkLogMessageGet(i)); // Print all the messages to help figure out the problem
136 }
137 Console.WriteLine("Expected OPERATIONAL state but the network did not get there.");
138 //throw new RsiError(); // Uncomment if you want your application to exit when the network isn't operational. (Comment when using phantom axis)
139 }
140 else // Else, of network is operational.
141 {
142 Console.WriteLine("Network Started");
143 }
144 }
147}
148
150public static class Constants
151{
152 public const int SAMPLES = 2;
153 public const int AXIS_NUMBER = 0;
154 public const int X_AXIS_NUMBER = 0;
155 public const int Y_AXIS_NUMBER = 1;
156 public const int Z_AXIS_NUMBER = 2;
157 public const int A_AXIS_NUMBER = 3;
158 public const int B_AXIS_NUMBER = 4;
159 public const int C_AXIS_NUMBER = 5;
160 public const int MAIN_AXIS_NUMBER = 0;
161 public const int DRIVEN_AXIS_NUMBER = 1;
162 public const int HOLDING_AXIS_INDEX = 0;
163 public const int MOVING_AXIS_INDEX = 1;
164 public const int AXIS_COUNT = 6;
165 public const int FIRST_AXIS_NUMBER = 0;
166 public const int SECOND_AXIS_NUMBER = 1;
167 public const int THIRD_AXIS_NUMBER = 2;
168 public const double USER_UNITS = 1;
169 public const double AKD_USER_UNITS = 1048576; // USER UNITS for an AKD drive 1 rev (the motor used in this sample app has 1048576 encoder pulses per revolution)
170
172 public const double POSITION = 2; // Specify the position to travel to.
173 public const double VELOCITY = 200; // Specify your velocity. - units: UserUnits/Sec
174 public const double ACCELERATION = 100; // Specify your acceleration. - units: UserUnits/Sec^2
175 public const double DECELERATION = 100; // Specify your deceleration. - units: UserUnits/Sec^2
176 public const double JERK_PERCENT = 50; // Specify your jerk percent (0.0 to 100.0)
178
179 public const double POSITION_A = 5;
180 public const double POSITION_B = 10;
181 public const int MAX_TEST_TIME = 3000;
182 public const int COMP_NUM_ZERO = 0;
183 public const int COMP_NUM_ONE = 1;
184 public const int COMP_NUM_TWO = 2;
185}
186
188public class TestBase
189{
190 public MotionController controller;
191 public Axis axis;
192 public Axis x_axis;
193 public Axis y_axis;
194 public Axis z_axis;
195 public Axis a_axis;
196 public Axis b_axis;
197 public Axis c_axis;
198 public Axis prime_axis;
199 public Axis main_axis;
200 public Axis driven_axis;
201 public MultiAxis jointsMultiAxis;
202 public Robot robot;
203
205 public Axis CreateAndReadyAxis(int AxisNumber)
206 {
207 Axis axis = controller.AxisGet(AxisNumber); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
208 HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialize correctly.
209 ResetAxis(axis);
210 return axis;
211 }
213
214 public void InitializeAllAxes()
215 {
216 axis = controller.AxisGet(Constants.AXIS_NUMBER); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
218 x_axis = controller.AxisGet(Constants.X_AXIS_NUMBER);
220 y_axis = controller.AxisGet(Constants.Y_AXIS_NUMBER);
222 z_axis = controller.AxisGet(Constants.Z_AXIS_NUMBER);
224 a_axis = controller.AxisGet(Constants.A_AXIS_NUMBER);
226 b_axis = controller.AxisGet(Constants.B_AXIS_NUMBER);
228 c_axis = controller.AxisGet(Constants.C_AXIS_NUMBER);
230 main_axis = controller.AxisGet(Constants.MAIN_AXIS_NUMBER);
231 HelperFunctions.CheckErrors(main_axis);
232 driven_axis = controller.AxisGet(Constants.DRIVEN_AXIS_NUMBER);
233 HelperFunctions.CheckErrors(driven_axis);
234 jointsMultiAxis = controller.MultiAxisGet(Constants.AXIS_COUNT);
235 HelperFunctions.CheckErrors(jointsMultiAxis);
236 }
237
238 public void DisableAllAxes()
239 {
240 for (int i = 0; i < controller.AxisCountGet(); i++)
241 {
242 Axis axis = controller.AxisGet(i);
244 axis.Abort();
245 axis.AmpEnableSet(false);
246 }
247 }
248
250 public void ResetAxis(Axis myAxis)
251 {
252 myAxis.ErrorLimitTriggerValueSet(1000);
253 myAxis.UserUnitsSet(Constants.USER_UNITS); // Specify the counts per Unit.
254 myAxis.PositionSet(0); // Sets the current position as 0 effectively 'homing' it.
255 myAxis.Abort(); // If there is any motion happening, abort it (creates a fault).
256 myAxis.DefaultAccelerationSet(Constants.ACCELERATION);
257 myAxis.DefaultDecelerationSet(Constants.ACCELERATION);
258 myAxis.DefaultVelocitySet(Constants.VELOCITY);
259
260 EnableAmp(myAxis);
261 }
263
265 public void EnableAmp(Axis myAxis)
266 {
267 myAxis.ClearFaults(); // To enable after an abort faults must be cleared.
268 myAxis.AmpEnableSet(true); // Enable the motor.
269 }
271
272 public void TearDownFixture()
273 {
274 DisableAllAxes();
275 controller.Shutdown();
276 controller.Delete();
277 }
278}
279
281public class SampleAppTestBase : TestBase
282{
283 [SetUp]
284 public void SetUp()
285 {
286 for (int i = 0; i < controller.AxisCountGet(); i++)
287 {
288 //@[AxisGet]
289 Axis axis = controller.AxisGet(i);
291 //@[AxisGet]
292 ResetAxis(axis);
293 }
294 }
295
296 [OneTimeSetUp]
297 public void OneTimeSetUp()
298 {
299 controller = MotionController.CreateFromSoftware(TestContext.CurrentContext.TestDirectory);// Insert the path location of the RMP.rta (usually the RapidSetup folder)
300 HelperFunctions.CheckErrors(controller); // [Helper Function] Check that the controller has been initialize correctly.
302 controller.MotionCountSet(Constants.AXIS_COUNT + 1); // Create a MultiAxis
303
304 InitializeAllAxes();
305 }
306
307 [TearDown]
308 public void TearDown()
309 {
310 DisableAllAxes();
311 }
312
313 [OneTimeTearDown]
314 public void OneTimeTearDown()
315 {
316 controller.Shutdown();
317 controller.Delete();
318 }
319}
320
322[TestFixture]
323[Category("Software")]
324public class StaticMemoryTestBase : TestBase
325{
326 [OneTimeSetUp]
327 public void OneTimeSetUp()
328 {
329 //@[ControllerReset]
330 controller = MotionController.CreateFromSoftware(TestContext.CurrentContext.TestDirectory);
331 controller.Reset(); // reboot the RMP controller firmware
332 //@[ControllerReset]
333 }
334
335 [SetUp]
336 public void Setup()
337 {
338 controller = MotionController.CreateFromSoftware(TestContext.CurrentContext.TestDirectory);
339 HelperFunctions.CheckErrors(controller);
340 }
341
342 [TearDown]
343 public void TearDown()
344 {
345 TearDownFixture(); // Teardown the entire fixture every time as the controller needs to be restarted between different static memory allocations
346 }
347}
348
350[TestFixture]
351[Category("Software")]
352public class HelperFunctionsTests : SampleAppTestBase
353 {
354 [Test]
355 public void CheckErrorsTest()
356 {
357 string expectedErrorSubstring = "Motion: RSIStateERROR"; // we expect this to be in the message
358 axis.ThrowExceptions(false); // exceptions will be logged, not thrown
359 axis.Abort(); // put into RSIStateERROR
360 axis.MoveSCurve(1); // command a move while in ERROR state - this will log an exception
361 Assert.Throws(Is.TypeOf<Exception>().And.Message.Contains(expectedErrorSubstring), () => HelperFunctions.CheckErrors(axis));
362 }
363
364 [Test]
365 public void CheckErrorsWarningTest()
366 {
367 const int BAD_AXIS_NUMBER = 777;
368 Axis badAxis = controller.AxisGet(BAD_AXIS_NUMBER); // try to get an illegal axis
369 Assert.Throws(Is.TypeOf<Exception>().And.Message.Contains(BAD_AXIS_NUMBER.ToString()), () => HelperFunctions.CheckErrors(badAxis));
370 }
371 }
@[BasicConstants]
Default: 2.
@[BasicConstants]
Definition rsi.h:5870
void DefaultVelocitySet(double velocity)
Set the default velocity in UserUnits.
void Reset()
Reset the controller which stops and restarts the RMP firmware.
void NetworkStart()
Start the network, doing both a discovery followed by starting to OPERATIONAL state.
const char *const NetworkLogMessageGet(int32_t messageIndex)
void Shutdown()
Shutdown the controller.
int32_t AxisCountGet()
Definition rsi.h:800
Definition rsi.h:10804
int32_t ErrorLogCountGet()
Definition rsi.h:184
Definition rsi.h:111
bool isWarning
Definition rsi.h:120
Definition rsienums.h:568
The Cartesian namespace.
