Learn how to configure different settings for an axis.
- Warning
In this page:
📜 Settling
Settling 📖 is the amount of time that a move must be within the position Fine band, in order for the move to be considered complete.
Source: axis-config-settling.cs
📜 Amp Fault Configuration
Learn how to configure the Axis amp fault action for a specific Axis amp state enable/disabled (true/false).
Source: axis-config-ampfault.cs
📜 User Units Set/Get
Learn how to get and set Counts Per Unit (User Units) 📖 .
Source: axis-config-userunits.cs
📜 Stop Rate
Learn how to set the Stopping Rates 📖 .
Source: axis-config-stop-rate.cs
📜 Hardware Limits
Learn how to get and set Hardware Limits 📖 .
bool ACTIVE_HIGH = true;
bool ACTIVE_LOW = false;
double HW_POS_DURATION_TIME = 0.01;
double HW_NEG_DURATION_TIME = 0.01;
Source: axis-config-hardware-limits.cs
📜 Phantom Axis
Learn how to create Phantom Axes 📖 .
int axisIndex = controller.AxisCountGet() - 1;
Source: axis-config-phantom-axis.cs
