Learn how to configure different settings for an axis.
- Warning
In this page:
📜 Settling
 Settling 📖  is the amount of time that a move must be within the position Fine band, in order for the move to be considered complete.
Source: axis-config-settling.cs
📜 Amp Fault Configuration
Learn how to configure the Axis amp fault action for a specific Axis amp state enable/disabled (true/false).
Source: axis-config-ampfault.cs
📜 User Units Set/Get
Learn how to get and set  Counts Per Unit (User Units) 📖 .
    int ENCODER_RESOLUTION_BITS = 20;
    double USER_UNITS = Math.Pow(2, ENCODER_RESOLUTION_BITS);
Source: axis-config-userunits.cs
📜 Stop Rate
Learn how to set the  Stopping Rates 📖 .
    double STOP_RATE_DEFAULT = 1.0;
    double ESTOP_RATE_DEFAULT = 0.05;
    double ESTOP_DECELERATION_RATE = 1000;
Source: axis-config-stop-rate.cs
📜 Hardware Limits
Learn how to get and set  Hardware Limits 📖 .
    bool ACTIVE_HIGH = true;
    bool ACTIVE_LOW = false;
    double HW_POS_DURATION_TIME = 0.01;
    double HW_NEG_DURATION_TIME = 0.01;
Source: axis-config-hardware-limits.cs
📜 Phantom Axis
Learn how to create  Phantom Axes 📖 .
Source: axis-config-phantom-axis.cs
