12#include "SampleAppsHelper.h"
18static const std::map<RSIState, std::string> RSIStateMap = {
19 {RSIState::RSIStateIDLE,
"RSIStateIDLE"},
20 {RSIState::RSIStateMOVING,
"RSIStateMOVING"},
21 {RSIState::RSIStateSTOPPING,
"RSIStateSTOPPING"},
22 {RSIState::RSIStateSTOPPED,
"RSIStateSTOPPED"},
23 {RSIState::RSIStateSTOPPING_ERROR,
"RSIStateSTOPPING_ERROR"},
24 {RSIState::RSIStateERROR,
"RSIStateERROR"}
30 const std::string SAMPLE_APP_NAME =
"Math Blocks: Difference of Position User Limit";
36 const int NUM_AXES = 2;
37 const int AXIS_X_INDEX = 0;
38 const int AXIS_Y_INDEX = 1;
41 const double MAX_POSITION_DIFFERENCE = 0.5;
42 const RSIAction USER_LIMIT_ACTION = RSIAction::RSIActionABORT;
43 const int USER_LIMIT_DURATION = 0;
46 const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE;
47 const double VELOCITY = 1;
48 const double ACCELERATION = 10;
49 const double DECELERATION = 10;
50 const double JERK_PCT = 0;
58 int initialUserLimitCount = -1;
59 int initialMathBlockCount = -1;
83 const int userLimitIndex = initialUserLimitCount;
86 const int mathBlockIndex = initialMathBlockCount;
112 : (RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_POSITION);
120 mathBlockConfig.
Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
127 std::cout <<
"MathBlock configured to subtract the position of the second axis from the position of the first axis." << std::endl;
130 uint64_t mathBlockProcessValueAddress =
131 controller->
AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, mathBlockIndex);
135 userLimitIndex, 0, RSIUserLimitLogic::RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE
140 userLimitIndex, RSIUserLimitTriggerType::RSIUserLimitTriggerTypeSINGLE_CONDITION, USER_LIMIT_ACTION, AXIS_X_INDEX,
143 std::cout <<
"UserLimit configured to trigger when the absolute position difference is greater than " << MAX_POSITION_DIFFERENCE
144 <<
" and abort motion." << std::endl;
147 std::cout <<
"Moving the axes to trigger the UserLimit..." << std::endl;
149 axisX->
MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT);
157 if ((axisX->
StateGet() == RSIState::RSIStateERROR) && (axisY->
StateGet() == RSIState::RSIStateERROR))
159 std::cout <<
"Both axes are in the error state after the UserLimit triggered (This is the intended behavior)." << std::endl;
164 std::cout <<
"Error: The axes should be in an error state after the UserLimit triggers, but they are not." << std::endl;
165 std::cout <<
"First Axis State: " << RSIStateMap.at(axisX->
StateGet()) << std::endl;
166 std::cout <<
"Second Axis State: " << RSIStateMap.at(axisY->
170 catch (
const std::exception &ex)
172 std::cerr << ex.what() << std::endl;
176 if (initialUserLimitCount != -1) { controller->
UserLimitCountSet(initialUserLimitCount); }
177 if (initialMathBlockCount != -1) { controller->
MathBlockCountSet(initialMathBlockCount); }
int32_t UserLimitCountGet()
Get the number of UserLimits processing in the firmware.
Configure a User Limit.
int32_t MathBlockCountGet()
int32_t AxisCountGet()
void AxisRemoveAll()
void AxisAdd(Axis *axis)
int32_t MotionDoneWait()
RSIState StateGet()
RSIDataType ProcessDataType
Data type for processing.
uint64_t InputAddress0
RSIDataType InputDataType0
uint64_t InputAddress1
RSIDataType InputDataType1
static constexpr bool USE_HARDWARE
