#include <cmath>
#include "SampleAppsHelper.h"
#include "rsi.h"
int main()
const std::string SAMPLE_APP_NAME = "Axis Configuration";
const int NUM_AXES = 1;
const int AXIS_INDEX = 0;
int exitCode = -1;
std::cout << "Configuring Amp Fault parameters\n" << std::endl;
const double AMP_FAULT_DURATION_TIME = 1;
const RSIAction AMP_FAULT_ACTION = RSIAction::RSIActionABORT;
const int AMP_FAULT_TRIGGER_STATE = 1;
std::cout << "Axis Amp Fault parameters have been set" << std::endl;
std::cout << "Configuring Hardware Limits parameters\n" << std::endl;
const int TRIGGER_STATE = 1;
const double DURATION = 0.01;
const RSIAction ACTION = RSIAction::RSIActionABORT;
std::cout << "Axis Hardware Limits have been set" << std::endl;
std::cout << "Configuring Settling parameters\n" << std::endl;
const double POSITION_TOLERANCE_FINE = 200;
const double POSITION_TOLERANCE_COARSE = 300;
const double VELOCITY_TOLERANCE = 12000;
const double SETTLING_TIME = 5;
std::cout << "Axis Settling parameters have been set" << std::endl;
std::cout << "Configuring Stop Rate parameters\n" << std::endl;
const double STOP_RATE_DEFAULT = 1.0;
const double ESTOP_RATE_DEFAULT = 0.05;
const double ESTOP_DECELERATION_RATE = 1000;
std::cout << "Axis Stop Rate parameters have been set" << std::endl;
std::cout << "Configuring User Units parameters\n" << std::endl;
const int ENCODER_RESOLUTION_BITS = 20;
const double USER_UNITS = std::pow(2, ENCODER_RESOLUTION_BITS);
std::cout << "Axis User Units have been set" << std::endl;
exitCode = 0;
exitCode = -1;
RSIAction AmpFaultActionGet()
Get the Amp Fault action.
double SettlingTimeGet()
Get the Settling time.
double UserUnitsGet()
sets the trigger state.
Set the Amp Fault action.
double AmpFaultDurationGet()
trigger state return.
double EStopDecelerationGet()
double VelocityToleranceGet()
Trigger state return.
Sets the trigger state.
Set the settling time.
double EStopTimeGet()
double StopTimeGet()
