13#include "SampleAppsHelper.h"
20 const std::string SAMPLE_APP_NAME =
"Axis Configuration";
46 std::cout <<
"Configuring Amp Fault parameters\n" << std::endl;
49 const double AMP_FAULT_DURATION_TIME = 1;
50 const RSIAction AMP_FAULT_ACTION = RSIAction::RSIActionABORT;
51 const int AMP_FAULT_TRIGGER_STATE = 1;
64 std::cout <<
"Axis Amp Fault parameters have been set" << std::endl;
67 std::cout <<
"Configuring Hardware Limits parameters\n" << std::endl;
71 const int TRIGGER_STATE = 1;
72 const double DURATION = 0.01;
73 const RSIAction ACTION = RSIAction::RSIActionABORT;
94 std::cout <<
"Axis Hardware Limits have been set" << std::endl;
97 std::cout <<
"Configuring Settling parameters\n" << std::endl;
101 const double POSITION_TOLERANCE_FINE = 200;
102 const double POSITION_TOLERANCE_COARSE = 300;
103 const double VELOCITY_TOLERANCE = 12000;
104 const double SETTLING_TIME = 5;
119 std::cout <<
"Axis Settling parameters have been set" << std::endl;
122 std::cout <<
"Configuring Stop Rate parameters\n" << std::endl;
126 const double STOP_RATE_DEFAULT = 1.0;
127 const double ESTOP_RATE_DEFAULT = 0.05;
128 const double ESTOP_DECELERATION_RATE = 1000;
141 std::cout <<
"Axis Stop Rate parameters have been set" << std::endl;
144 std::cout <<
"Configuring User Units parameters\n" << std::endl;
148 const int ENCODER_RESOLUTION_BITS = 20;
149 const double USER_UNITS = std::pow(2, ENCODER_RESOLUTION_BITS);
159 std::cout <<
"Axis User Units have been set" << std::endl;
163 catch (
const std::exception &ex)
165 std::cerr << ex.what() << std::endl;
RSIAction AmpFaultActionGet()
Get the Amp Fault action.
double SettlingTimeGet()
Get the Settling time.
double UserUnitsGet()
sets the trigger state.
Set the Amp Fault action.
double AmpFaultDurationGet()
trigger state return.
double EStopDecelerationGet()
double VelocityToleranceGet()
Trigger state return.
Sets the trigger state.
Set the settling time.
double EStopTimeGet()
double StopTimeGet()
static void SetupController(MotionController *controller)
static constexpr int AXIS_X_INDEX
Index of the first axis to use in the sample apps.
