2#ifndef _CARTESIANROBOT_H
3#define _CARTESIANROBOT_H
6#if defined(HAS_CARTESIAN_ROBOT)
31 constexpr double pi = 3.1415926535897932384626433832795028841971693993751;
432 Pose(
double x,
double y,
double z);
442 bool Equals(
const Pose& rightHandSide,
double tolerance)
const;
505 virtual const char*
const NameGet()
const = 0;
506 virtual uint32_t AxisCountGet()
const = 0;
511 virtual bool IsConfigured()
const = 0;
513 virtual const char*
const*
const ExpectedAxisNamesGet()
const = 0;
514 virtual uint32_t ExpectedAxisNamesCountGet()
const = 0;
516 virtual uint32_t FreeAxisCountGet()
const = 0;
521 virtual bool InverseKinematicsSolve(
const Pose& inputPose,
void* outputPointerSolutionVector)
const = 0;
523 virtual bool InverseKinematicsSolve(
const RobotPosition& inputPosition,
void* vpSols)
const = 0;
528 virtual void ForwardKinematicsSolve(
const double* inputJointPositions,
Pose& outputPose)
const = 0;
530 virtual void ForwardKinematicsSolve(
RobotPosition& outputPosition)
const = 0;
532 virtual bool IsArticulated()
const = 0;
546 static constexpr double DefaultScaling = 1.0;
550 static constexpr double DefaultOffset = 0.0;
554 static constexpr int ExpectedLabelBufferSize =
MaxLabelSize + 1;
668 LinearJointMapping(
int jointIndex,
CartesianAxis cartesianCoordinate);
669 LinearJointMapping(
int jointIndex,
CartesianAxis cartesianCoordinate,
double scaling,
double offset,
const char*
const label);
733 ArticulatedModelBuilder();
734 ~ArticulatedModelBuilder();
1375 virtual void Load(
const char*
const text) = 0;
1404 virtual uint64_t
DoneWait(uint64_t timeoutMilliseconds) = 0;
void Cancel()=0
Cancel the currently running G-code program.
void ReloadLines(int32_t start=0, int32_t end=-1)=0
Reloads the lines from the last call to GcodeLoad() but only between start line and end of file....
uint64_t DoneWait(uint64_t timeoutMilliseconds)=0
Wait for the completion of G-code program execution with a timeout.
const RobotPosition & ActiveWorkOffsetValuesGet()=0
Gets the actual values of the currently applied offset.
const char *const LineTextGet(uint32_t lineNumber)=0
Gives you the text of a specific line from the last loaded program excluding all comments and with on...
void FreeAxisLetterSet(const char gcodeLetter, const int32_t freeAxisIndex)=0
Map a letter in a Gcode file to a free axis. It will be used to specify the free axis' motion.
RobotPosition ActualPositionGet()=0
Get the current actual position of the robot in the currently active GCode units with any active GCod...
GCodeWorkOffset ActiveWorkOffsetGet()=0
Gets the enum representing the location where the current offset is saved.
void ActiveWorkOffsetSelect(GCodeWorkOffset workOffset)=0
Apply the offset saved under the specified location.
int32_t LineCountGet()=0
Get the number of lines in the last loaded G-Code program.
int32_t SyntaxErrorLineNumberGet()=0
Gets the line number of any errors in the G-Code syntax. Or use the exception thrown by Load or LoadF...
const char *const ProgramGet()=0
Gets the raw file contents of the last loaded program.
int32_t ExecutingLineNumberGet()=0
Get the currently executing line number.
bool IsRunning()=0
Returns true if a Gcode program is executing, false otherwise.
LinearUnits UnitsGet()=0
Get the currently active unit as set by G20/G21.
void AccelerationRateSet(double programmingUnitsPerMinuteSquared)=0
REQUIRED before Load() or LoadFile(). Sets the target acceleration for the machine (units/minute^2)....
void MCodeCallbackRegister(uint32_t mCode, Cartesian::GcodeCallback *callback, bool reloadAfterCallback=true)=0
Register a callback for a specific M-code.
double AccelerationRateGet()=0
Gets the target acceleration for the machine (GcodeUnitsGet()/minute^2). Rotational only moves are in...
void UnitsSet(LinearUnits units)=0
Set the currently active unit (same as calling G20/G21).
void CallbackRegister(Cartesian::GcodeCallback *callback, bool reloadAfterCallback=true)=0
Register a catch-all M-code callback.
double DurationGet()=0
Get the time duration required to run the loaded G-Code program in seconds.
RapidVector< RobotPosition > PlannedPositionsGet(uint64_t startFrame, uint64_t frameCount)=0
Get RobotPositions representing the planned G-Code motion in cartesian space that will happen when ru...
double FeedRateGet()=0
Gets the target feed rate for the machine (GcodeUnitsGet()/minute). Rotational only moves are in (deg...
RobotPosition CommandPositionGet()=0
Get the current command position of the robot in the currently active GCode units with any active GCo...
void LoadFile(const char *const file)=0
Load a G-code program from a file.
void WorkOffsetConfigure(GCodeWorkOffset workOffset, Vector3d offsetValues)=0
Save an XYZ offset to be used with specified G-Code work offset.
void FeedRateSet(double programmingUnitsPerMinute)=0
REQUIRED before Load() or LoadFile() if your g-code does not have 'F' in its contents....
void Load(const char *const text)=0
Load a G-code program from a string.
void Run()=0
Run the loaded G-Code file (or string). The behavior is non-blocking. Use DoneWait() to block.
void Execute(GcodeCallbackData *data)
Executes the M-code callback.
Handles callbacks for M-codes within a G-code file.
Represents a G-code program executor. This class provides an interface to load and run G-code program...
const KinematicModel & ModelBuild()=0
Construct the model using the information the builder currently has. The builder will maintain a refe...
const char *const LabelGet() const
Get the label the model builder is configured to have.
void RotationalUnitsSet(RotationalUnits units)
Set the rotational/angular units the built model will use.
RotationalUnits RotationalUnitsGet() const
Get the rotational/angular units that the model builder is currently configured to use.
LinearUnits UnitsGet() const
Get the units that the model builder is currently configured to use.
void LabelSet(const char *const label)
Set the model name.
The abstract class for Kinematic Model builders. Constructs a single Kinematic Model to use when crea...
void TransformFromKinematicOriginToRobotOriginSet(const Pose &KinematicOriginToRobotOrigin)
Set the kin origin to robot origin tf.
void FreeAxisAdd(const ModelAxisMapping &freeAxis)
Map a free axis in the kinematic model. The Axis' DefaultVelocity/Acceleration will be used for free ...
KinematicModelBuilder(Storage *storage)
The KinematicModelBuilder constructor is protected so that only derived classes can use it....
const KinematicModel & ModelGet()
Get a constant reference to the Kinematic model that is currently built. The builder instance maintai...
Pose TransformFromKinematicOriginToRobotOriginGet() const
Get the Pose representing the transform from the kinematic origin to the robot origin.
const KinematicModel & ModelBuild() override
LinearModelBuilder(const char *const label)
constructs a LinearModelBuilder instance.
Pose operator*(const Pose &rightHandSide) const
Transforms rightHandSide by this. Rotates rightHandSide.position by this, adds this....
Vector3d operator*(const Vector3d &rightHandSide) const
Transforms rightHandSide by this. Rotates rightHandSide by this, and adds this.position to it.
bool EqualsOrientation(const Pose &rightHandSide, double tolerance) const
Approximate equality check. Checks whether all components are within the tolerance of each other....
Pose Inverse() const
Returns an inverted copy of this. this * this.inverse() = I.
Pose(const Pose &pose)
Constructor from an existing Pose.
Pose(const Quaternion &quaternion)
Constructor.
Pose Rotate(const Pose &rightHandSide) const
Rotates rightHandSide by the rotation component of this (ONLY the rotation component).
bool Equals(const Pose &rightHandSide, double tolerance) const
Pose(const Vector3d position, const Quaternion &quaternion)
Constructor.
Pose(const Vector3d &position)
Constructor from an existing position Vector3d.
Pose(double x, double y, double z)
Constructor from X,Y,Z with an identity "no rotation" default Quaternion.
Vector3d Position
The position component of the Pose.
Quaternion Orientation
The orientation component of the Pose.
Pose()
Default constructor. Vector(0,0,0) Quaterion(1,0,0,0).
Multiplication (vector rotation) operator. Rotates vector by this.
Quaternion & operator-=(const Quaternion &rightHandSide)
Subtraction assignment. Subtracts other from this. See operator-.
Quaternion & operator+=(const Quaternion &rightHandSide)
Addition assignment. Adds rightHandSide into this. See operator+.
Quaternion & Set(double w, const Vector3d &vec)
Assigns other into this.
Quaternion operator+(const Quaternion &rightHandSide) const
Adds two quaternions together. this.w + rightHandSide.w, this.v+rightHandSide.v.
Quaternion & operator=(const Quaternion &rightHandSide)
Assignment operator. Copies underlying.
Quaternion(double x, double y, double z)
Euler Constructor. Assumes RPY in Radians. To use a different unit, use Quaternion(const Vector3d&,...
Quaternion & operator*=(double s)
Multiplication (scalar) assignment operator. See operator*(double).
Quaternion Conjugate() const
Negates the imaginary component of the Quaternion.
Quaternion Inverse() const
Conjugate scaled by 1 / SumSquares().
Quaternion operator-(const Quaternion &rightHandSide) const
Subtraction operator. this.w - rightHandSide.w, this.v-rightHandSide.v.
Quaternion operator-() const
Negates this quaternion (w, and v).
Quaternion Normalized() const
Retunrs a normalized copy of this.
Quaternion & Set(const Vector3d &vec, RotationalUnits units=RotationalUnits::Radians)
Assigns the quaternion defined by the Euler Angles into this.
void ToAngleAxis(double &outAngle, Vector3d &outAxis) const
Gets the axis angle representation of this quaternion.
Quaternion & Set(const Quaternion &otherQuaternion)
Quaternion & Set(double x, double y, double z)
Assigns the quaternion defined by the Euler angles into this. Assumes RPY in Radians....
bool operator==(const Quaternion &rightHandSide) const
Exact equality check. See equals for approximately equal to.
Vector3d ToEuler(RotationalUnits units=RotationalUnits::Radians) const
Gets the Euler Angle representation of this quaternion.
double Magnitude() const
Gets the magnitude of this. sqrt(SumSquares()).
Quaternion operator*(double s) const
Multiplication (scalar) operator. w*s, v*s.
static Quaternion FromAngleAxis(double angle, const Vector3d &axis)
Creates a quaternion from an axis angle representation.
bool EqualsOrientation(const Quaternion &rightHandSide, const double tolerance) const
Equality check within tolerance. For orientations q and -q are considered equal.
Quaternion operator*(const Quaternion &rightHandSide) const
Multiplication (rotation) operator. Rotates other by this.
Quaternion(double w, const Vector3d &v)
Constructor.
bool operator!=(const Quaternion &rightHandSide) const
Exact inequality check. See equals for approximately equal to.
Quaternion & Normalize()
Normalizes this. Scales each component by 1 / magnitude.
Quaternion(const Quaternion &otherQuaternion)
Constructor.
double SumSquares() const
Gets the sum of the components squared (w*w+this.dot(this)).
Quaternion(const Vector3d &rpy, RotationalUnits units=RotationalUnits::Radians)
Euler Constructor (Alternate).
Quaternion(double w, double x, double y, double z)
Constructor.
double Dot(const Quaternion &rightHandSide) const
Returns the dot product of each element. w*rightHandSide.w+v.dot(rightHandSide.v).
Quaternion & Set(double w, double x, double y, double z)
Assigns each component into this.
bool Equals(const Quaternion &rightHandSide, const double tolerance) const
void ToMatrix(double *matrix) const
Quaternion To Matrix.
static Quaternion FromMatrix(const double *const matrix)
Matrix to Quaternion.
Quaternion for representing rotations.
double W
W (real component) of Quaternion. Do not modify this unless you know what you are doing.
Quaternion()
Default Constructor. W=1, X=Y=Z=0.
Vector3d V
Vector3d (imaginary) component of Quaternion. 1->x, 2->y, 3->z. Do not modify this unless you know wh...
RapidVector< double > JointsActualPositionsGet()=0
Get the actual positions of the axes in the underlying MultiAxis.
bool MotionDoneGet()=0
double PathAccelerationGet()=0
Gets the target acceleration for the machine (UserUnits/second^2).
bool PathStateWait(PathState stateWaitFor, uint64_t timeoutMilliseconds)=0
Waits for a specific path state.
const double ScaleFactorBetweenUnitsGet(RotationalUnits from, RotationalUnits to)=0
Gets scaling for scale factor needed to convert from -> to units by multiplying.
void OriginTransformSet(const Pose &transform)=0
Transform that defines the origin of the robot in the world. For example if you have a gantry that is...
bool PathStateWaitChange(PathState stateWaitChange, uint64_t timeoutMilliseconds)=0
Waits for the path state to not be the specified state.
void PathArc(const RobotPosition &target, double radius, RotationDirection direction)=0
Appends an arc on to the current on the PathPlaneGet() plane XY by default.
void Stop()=0
Stop an axis.
double PathVelocityGet()=0
Gets the target velocity for the machine (UserUnits/second).
RapidVector< RobotPosition > PathPlannedPositionsGet(uint64_t startFrame, uint64_t frameCount)=0
Get Positions (see RobotPosition) representing the planned motion in cartesian space that will happen...
uint32_t MotionFrameBufferSizeGet()=0
Gets the TrajectoryExecutor's buffer size in frames, one frame is used per RMP sample period.
static constexpr uint32_t MotionFrameBufferSizeMinimum
The minimum size allowable for the Robot's trajectory executor buffer.
void PathLine(const RobotPosition &position)=0
static Robot * RobotCreate(MotionController *controller, MultiAxis *multiAxis, KinematicModelBuilder *builder, uint32_t motionFrameBufferSize=MotionFrameBufferSizeDefault)
void PathVelocitySet(double unitsPerSecond)=0
Sets the target linear cartesian velocity for each move (UserUnits/second).
void SampleCounterWait(uint64_t sampleCount, uint64_t timeoutMilliseconds)=0
Waits for the sample counter of the Robot's main execution thread to incremented by the specified amo...
Plane PathPlaneGet()=0
Gets the plane some arcs will be forced to be on.
const char *const ErrorMessageGet()=0
Get the text of any error in the Trajectory Executor.
bool IsRunning()=0
Returns whether or not the robot is in motion (from executor or other source). Can be used to determi...
void EndEffectorTransformSet(const RobotPosition &transformPosition)=0
Transform that defines the control point relative to the end end of the current kinematic model with ...
RobotPosition ActualPositionGet(LinearUnits units=LinearUnits::None)=0
Get the current actual position of the robot from the trajectory executor in the specified units....
void Abort()=0
bool HasError()=0
Get the error state of the underlying Trajectory Executor.
double PathProcessLoadedMoves()=0
Processes our loaded moves. Used internally and to check whether loaded moves are valid,...
void EndEffectorTransformSet(const Pose &transform)=0
Transform that defines the control point relative to the end end of the current kinematic model For e...
static constexpr uint32_t MotionFrameBufferSizeDefault
The default size the Robot's trajectory executor buffer. There is one frame per RMP sample period.
void OriginTransformSet(const RobotPosition &transformPosition)=0
Transform that defines the origin of the robot in the world as a RobotPosition.
uint64_t MotionDoneWait(uint64_t timeoutMilliseconds=TimeoutForever)=0
void PathPlaneSet(Plane plane)=0
Sets the plane for the purposes of ambiguous cases (arcs >= 180deg). Last set plane or XY plane is de...
Pose ActualPoseGet(LinearUnits units=LinearUnits::None)=0
Get the current actual pose of the robot from the trajectory executor in the specified units....
double PathLinearScalingGet() const =0
Gets scaling between input to path motion and output of path motion to the kinematic model.
RapidVector< double > InverseKinematics(Pose pose)=0
Run the given pose through the current inverse kinematic model to see the joint positions the robot w...
PathMode PathProgrammingModeGet()=0
Gets the programming mode (Relative/Absolute).
RobotPosition ForwardKinematicsPosition(const RapidVector< double > &joints)=0
Get the Actual position of the robot from the the joint MultiAxis positions.
void PathLinearScalingSet(double scaleFactor)=0
Sets scaling between the input to path motion and output of path motion to the kinematic model.
const RobotPosition & OriginTransformGet()=0
Offset for the origin location.
void EStopAbort()=0
E-Stop, then abort an axis.
void PathAccelerationSet(double unitsPerSecondSquared)=0
Sets the target acceleration for the machine (UserUnits/second^2). Should be set appropriately based ...
LinearUnits PathUnitsGet() const =0
Gets the units of path motion.
bool PathIsRunning()=0
Returns whether or not a planned path is being executed. All G-Code gets converted to path....
const RobotPosition & EndEffectorTransformGet()=0
End of Robot to TCP.
void PathArc(const Pose &target, double radius, RotationDirection direction)=0
void PathClear()=0
Clears out all loaded lines and arcs from the path. Part of the PathMotion method group.
void PathUnitsSet(LinearUnits units)=0
Defines the units Cartesian Path Motion is in.
Pose CommandPoseGet(LinearUnits units=LinearUnits::None)=0
Get the current commanded pose of the robot from the trajectory executor in the specified units....
void PathLine(const Pose &target)=0
void MoveAbsolute(const Pose &absolutePose)=0
Executes a point-to-point absolute motion in cartesian space.
PathState PathStateGet()=0
Gets the path state of the Robot.
void EStop()=0
void MotionCounterWait(uint64_t motionCount, uint64_t timeoutMilliseconds)=0
Waits for the counter increment by the specified amount.
void MoveRelative(const Pose &relativePose)=0
Executes a point-to-point motion relative to the current end effector Pose.
RapidVector< double > JointsCommandPositionsGet()=0
Get the commanded positions of the axes in the underlying MultiAxis.
Pose ForwardKinematics(const RapidVector< double > &joints)=0
Get the Actual pose of the robot from the the joint MultiAxis positions.
int32_t AmpEnableSet(bool enable, int32_t ampActiveTimeoutMilliseconds=RapidCodeMotion::AmpEnableTimeoutMillisecondsDefault, bool overrideRestrictedState=false)=0
void PathProgrammingModeSet(PathMode mode)=0
Sets the programming mode (Relative/Absolute).
void PathArc(const Pose &target, const Vector3d ¢er, RotationDirection direction)=0
Appends an arc on to the current path with end pose about a specific center point.
RobotPosition CommandPositionGet(LinearUnits units=LinearUnits::None)=0
Get the current commanded position of the robot from the trajectory executor in the specified units....
uint64_t MotionCounterGet()=0
Gets the current motion counter of the Robot.
const double ScaleFactorBetweenUnitsGet(LinearUnits from, LinearUnits to)=0
static Robot * RobotCreate(MotionController *controller, MultiAxis *multiAxis, const char *const modelIdentifier, uint32_t motionFrameBufferSize=MotionFrameBufferSizeDefault)
void PathArc(const RobotPosition &RobotPosition, const Vector3d ¢er, RotationDirection direction)=0
double PathDurationGet()=0
Get total (seconds) duration of the planned motion that will happen when run is called.
void Resume()=0
Resume an axis.
RapidVector< double > InverseKinematics(RobotPosition pose)=0
void Run()=0
Run the loaded path lines/arcs. The behavior is non-blocking. Use Robot.MotionDoneWait() to block.
void ClearFaults()=0
uint64_t SampleCounterGet()=0
Gets the current sample counter of the Robot's main execution thread.
static constexpr uint64_t TimeoutForever
Use this 64-bit value to wait forever in methods which accept a timeoutMilliseconds parameter.
Delete a Robot.
RSI::RapidCode::Cartesian::Gcode * Gcode
An object to load and run Gcode files.
A representation of the robot containing the Pose and the positions of the free axes.
RobotPosition(const Cartesian::Pose &newPose, const RapidVector< double > &freeAxes)
Copies the new pose into this->Pose. Makes a deep copy of the given RapidVector for this->FreeAxes.
RobotPosition()
Default constructor. Initializes all values to 0. Leaves the FreeAxes RapidVector empty.
Cartesian::RobotPosition operator*(const Cartesian::RobotPosition &otherPosition) const
multiplies this->Pose by otherPosition.Pose and adds otherPosition.FreeAxes to this->FreeAxes (since ...
double AxisValueGet(uint32_t index) const
Gets the freeAxis value at the specified index. Returns 0 if index is out of bounds of the FreeAxes.
RobotPosition(const Cartesian::Pose &newPose, const size_t numberOfFreeAxes=0)
Copies the new pose into this->Pose. Specified number of free axes initialized with zeroes for their ...
void AxisValueSet(uint32_t index, double value)
Sets the freeaxis value at specified index to the passed value. Does nothing if index is out of bound...
RobotPosition(const Cartesian::RobotPosition &otherPosition)
Copy constructor. Copies values of Pose and FreeAxes.
Cartesian::RobotPosition Inverse() const
Gets the inverse of the pose and free axes.
RapidVector< double > FreeAxes
The Robot's free axes. Will have elements added to it for each free axis in the robot.
Cartesian::RobotPosition operator*(const Cartesian::Pose &otherPose) const
multiplies this->Pose by pose. Does not modify this->FreeAxes.
RSI::RapidCode::Cartesian::Pose Pose
The Robot's Pose.
Vector3d is used for three-dimensional points and vectors.
double Z
The Z coordinate.
double X
The X coordinate.
Vector3d Normal() const
Returns a normalized copy of this.
Vector3d operator*(double scalar) const
Returns a Vector3d scaled scaled by. X*scalar, Y*scalar, Z*scalar.
Vector3d & Set(double x, double y, double z)
Sets X=x, Y=y, Z=z.
Vector3d operator+(const Vector3d &rightHandSide) const
Returns a copy of rightHandSide added to this. this.X+rightHandSide.X, this.Y+rightHandSide....
Vector3d operator/(double scalar) const
Returns a Vector3d scaled scaled by. X/scalar, Y/scalar, Z/scalar.
Vector3d & Set(const Vector3d &rightHandSide)
Sets X=rightHandSide.X, Y=rightHandSide.Y, Z=rightHandSide.Z.
Vector3d operator-(const Vector3d &rightHandSide) const
Returns a copy of rightHandSide subtracted from this. this.X-rightHandSide.X, this....
Vector3d & operator*=(double scalar)
Scales each element by scalar. X*=scalar, Y*=scalar, Z*=scalar.
Vector3d operator-() const
Returns a copy of this with elements negated. -X, -Y, -Z.
double Length() const
Returns the length of the vector. Aka the magnitude =sqrt(SumSquares).
bool operator!=(const Vector3d &rightHandSide) const
Returns whether this is not exactly equal to rightHandSide.
bool operator==(const Vector3d &rightHandSide) const
Returns whether this is exactly equal to rightHandSide.
Vector3d & operator/=(double scalar)
Scales each element by scalar. X/=scalar, Y/=scalar, Z/=scalar.
Returns the sum of squares. X*X+Y*Y+Z*Z.
Vector3d()
Default constructor. X=Y=Z=0.
Vector3d & operator-=(const Vector3d &rightHandSide)
Subtracts rightHandSide from this. this.X-=rightHandSide.X, this.Y-=rightHandSide....
double Y
The Y coordinate.
Vector3d & operator+=(const Vector3d &rightHandSide)
Adds rightHandSide to this. this.X+=rightHandSide.X, this.Y+=rightHandSide.Y, this....
double Dot(const Vector3d &rightHandSide) const
Dot Product. this.X*rightHandSide.X + this.Y*rightHandSide.Y + this.Z*rightHandSide....
Vector3d Inverse() const
Vector3d Cross(const Vector3d &rightHandSide) const
Cross Product. Vector.X = this.Y*rightHandSide.z - this.Z*rightHandSide.Y Vector.Y = this....
Vector3d & operator=(const Vector3d &rightHandSide)
Sets this = rightHandSide.
Vector3d(double x, double y, double z)
Constructor. X=x, Y=y, Z=z.
bool Equals(const Vector3d &rightHandSide, const double tolerance) const
Checks whether this.X==rightHandSide.X && this.Y==rightHandSide.Y && this.Z==rightHandSide....
Vector3d & Normalize()
Normalizes this.
Vector3d(const Vector3d &rightHandSide)
Constructor. X=rightHandSide.X, Y=rightHandSide.Y, Z=rightHandSide.Z.
static constexpr int32_t AmpEnableTimeoutMillisecondsDefault
Default timeout in milliseconds for AmpEnableSet() to wait for AMP_ACTIVE / OPERATION_ENABLED to go h...
A wrapper class for the C++ STL vector class that aims to maintain application binary interface....
PathMode
Motion types. For G-code use and Cartesian path motion.
Plane
Rotational directions about and axis.
CartesianAxis
PathState
State of the Robot.
@ Stopping
Motion was interrupted by a stop command or error on the MultiAxis. EStop time will be used....
@ Moving
A path motion is in progress.
@ Idle
The path motion is not moving or in progress. If the joints are moved directly, the PathState will be...
@ Uninitialized
Library is loading. Wait until it is idle.
RotationDirection
Rotational directions about an axis.
LinearUnits
GCodeWorkOffset
Register names for G-Code work offsets.
RotationalUnits
const char * LineText
The actual line content from the G-code file.
RsiError * UserError
Allows the user to set give error details to the G-Code execution thread what occurred during the exe...
int32_t LineNumber
The line number in the G-code file where the M-code is encountered.
Holds data for the G-code M-code callback mechanism.
CartesianAxis CartesianCoordinate
Data for adding joint or free-axis mappings when building a kinematic model.
double Offset
The offset value that will be added to the scaled joint position.
int JointIndex
The index of the robot's joint to map (within an array of joint positions). Often this index will ref...
ModelAxisMapping(int jointIndex)
Constructor that sets the FointIndex and uses defaults for the rest of the data members.
double Scaling
The scaling value that the joint position will be multiplied by.
static constexpr int MaxLabelSize
The maximum size of a joint label and the size of the ExpectedLabel buffer.
ModelAxisMapping(int jointIndex, double scaling, double offset, const char *const label)
Constructor that sets all data members in the struct.
char ExpectedLabel[ExpectedLabelBufferSize]
The label the joint is expected to have. The maximum number of characters the label can have is MAX_L...
