◆ Stop()
void Stop ( )
pure virtual
Stop an axis.
If the motion is in the moving state (::RSIStateMOVING), a STOP action will decelerate the axis to a stop in the time specified by the "stop" time configuration - StopTimeSet(). The motion state will transition to ::RSIStateSTOPPING during the deceleration and then to ::RSIStateSTOPPED after the motion completes.
After Stop(), axis does NOT have error state & drive(amplifier) is still enabled
The stopping time that is used will be from the object (Axis or MultiAxis) that started the active motion, NOT the object that commanded this action.
If a MultiAxis motion is in progress, the stopping time will be determined by MultiAxis::StopTimeSet() and the individual Axis::StopTimeSet() values will be ignored.
Motion: Modify
// start motion
Console.WriteLine($"\tPosition commanded: {POSITION}");
// set feedrate to 150%
axis.FeedRateSet(1.5);
// wait here until we reach position 5
while (axis.CommandPositionGet() < 5)
Thread.Sleep(10);
// stop motion
axis.Stop();
axis.MotionDoneWait();
Console.WriteLine($"\tPosition after FeedRate (1.5): {axis.CommandPositionGet()}");
// set feedrate to reverse motion (-100%)
axis.FeedRateSet(-1);
// resume motion for a bit
axis.Resume();
Thread.Sleep(500);
Console.WriteLine($"\tPosition after FeedRate (-1): {axis.CommandPositionGet()}");
// restore feedrate (100%)
axis.FeedRateSet(1);
// wait for motion done
Console.WriteLine($"\tPosition after FeedRate (1): {axis.CommandPositionGet()} (expected: {POSITION})");
Stop is the same as Pause, and can be resumed by calling Resume(). This means if you have commanded a move and call Stop() method, axis will retain it's motion profile which will continue upon calling Resume().
Go to axis screen->Position and Trajectory box. Various actions (Stop, EStop, Abort) are shown in image below.
StopTimeSet , StopTimeGet , Resume, RSIState
