Represents a G-code program executor. This class provides an interface to load and run G-code programs with a callback interface for M-codes. An instance of this class is created by the Robot class, access it via the Robot.Gcode property. More...
Functions
Visit our Concept Page for more information.
Basics
void FeedRateSet (double programmingUnitsPerMinute)=0
 Sets the target feed rate for the machine (units/minute). Rotational moves are in (degrees/minute). REQUIRED for feed-governed motion (G1/G2/G3).
void AccelerationRateSet (double programmingUnitsPerMinuteSquared)=0
 Sets the target acceleration for the machine (units/minute^2). Rotational moves are in (degrees/minute^2). Should be set appropriately based on your hardware. REQUIRED for feed-governed motion (G1/G2/G3).
void Load (const char *const text)=0
 Load a G-code program from a string.
void LoadFile (const char *const file)=0
 Load a G-code program from a file.
void Run ()=0
 Run the loaded G-Code file (or string). The behavior is non-blocking. Use DoneWait() to block.
uint64_t DoneWait (uint64_t timeoutMilliseconds)=0
 Wait for the completion of G-code program execution with a timeout.
void ReloadLines (int32_t start=0, int32_t end=-1)=0
 Reloads the lines from the last call to GcodeLoad() but only between start line and end of file. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
int32_t LineCountGet ()=0
 Get the number of lines in the last loaded G-Code program.
const char *const ProgramGet ()=0
 Gets the raw file contents of the last loaded program.
int32_t SyntaxErrorLineNumberGet ()=0
 Gets the line number of the first syntax/load error encountered in a call to Gcode::Load or Gcode::LoadFile.
const char *const LineTextGet (uint32_t lineNumber)=0
 Gives you the text of a specific line from the last loaded program excluding all comments and with only once space between chunks.
double FeedRateGet ()=0
 Gets the current target G-code feed rate, interpreted as units/minute for linear speed and degrees/minute for rotational speed.
double AccelerationRateGet ()=0
 Gets the target acceleration for the machine (units/minute^2). Rotational only moves are in (degrees/minute^2).
double DurationGet ()=0
 Get the time duration required to run the loaded G-Code program in seconds.
void Cancel ()=0
 Cancel the currently running G-code program.
RobotPosition ActualPositionGet ()=0
 Get the current actual position of the robot in the currently active GCode units with any active GCode work offsets.
RobotPosition CommandPositionGet ()=0
 Get the current command position of the robot in the currently active GCode units with any active GCode work offsets.
RapidVector< RobotPosition > PlannedPositionsGet (uint64_t startFrame, uint64_t frameCount)=0
 Get RobotPositions representing the planned G-Code motion in cartesian space that will happen when run is called. Also includes the positions of the free axes.
void UnitsSet (LinearUnits units)=0
 Set the currently active unit (same as calling G20/G21).
LinearUnits UnitsGet ()=0
 Get the currently active unit as set by G20/G21 or Gcode::UnitsSet.
void WorkOffsetConfigure (GCodeWorkOffset workOffset, Vector3d offsetValues)=0
 Save an XYZ offset to be used with specified G-Code work offset.
void ActiveWorkOffsetSelect (GCodeWorkOffset workOffset)=0
 Apply the offset saved under the specified location.
GCodeWorkOffset ActiveWorkOffsetGet ()=0
 Gets the enum representing the location where the current offset is saved.
const RobotPosition & ActiveWorkOffsetValuesGet ()=0
 Gets the actual values of the currently applied offset.
bool IsRunning ()=0
 Returns true if a Gcode program is executing, false otherwise.
int32_t ExecutingLineNumberGet ()=0
 Get the currently executing line number.
void FreeAxisLetterSet (const char gcodeLetter, const int32_t freeAxisIndex)=0
 Map a letter in a Gcode file to a free axis. It will be used to specify the free axis' motion.
void CallbackRegister (Cartesian::GcodeCallback *callback, bool reloadAfterCallback=true)=0
 Register a catch-all M-code callback.
void MCodeCallbackRegister (uint32_t mCode, Cartesian::GcodeCallback *callback, bool reloadAfterCallback=true)=0
 Register a callback for a specific M-code.
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t NumberGet ()
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Description
Definition at line 1341 of file cartesianrobot.h.
