using System.Threading;
Console.WriteLine("📜 Motion: G-Code");
string gcodeProgram = @"G91; Sets the programming mode to RELATIVE
G64; Turns off exact stop mode (Default)
G1 X1.0 Y0.0 Z0.0 A1.0 F60.0; Move on USERUNIT in positive x direction at 60in/min. Moves Free axis A to position 1.0.
G3 X1 Y1 I0 J1; Counter clockwise arc with a center point of 0,1,0 and end point of 1,1,0 relative to the current position
M80; Show how to use an M-code with GcodeCallback!";
MultiAxis jointsMultiAxis = controller.MultiAxisGet(0);
Axis[] axes = [xAxis, yAxis, zAxis, aAxis];
jointsMultiAxis.
AxesAdd(axes, axes.Length);
const double scaling = 1.0;
const double offset = 0.0;
SampleGcodeCallback callback = new();
Console.WriteLine($"Error loading G-Code: {e.Message}");
throw;
Console.WriteLine($"G-Code Line Count: {robot.Gcode.LineCountGet()}");
Console.WriteLine($"G-Code Error Log Count: {robot.Gcode.ErrorLogCountGet()}");
Console.WriteLine($"G-code estimated run time: {robot.Gcode.DurationGet()} seconds");
Int64 activeLineNumber = 0;
do
Thread.Sleep(200);
Console.WriteLine($"G-Code Line Number: {activeLineNumber}");
Console.WriteLine("✅ G-Code motion completed successfully");
controller.Delete();
public class SampleGcodeCallback : GcodeCallback
public override void Execute(GcodeCallbackData data)
Console.WriteLine("G-Code Callback executed: " + data.LineNumber + " " + data.LineText);
const int AXIS_3_INDEX
Default: 3.
const int AXIS_1_INDEX
const int AXIS_2_INDEX
Default: 2.
void FreeAxisLetterSet(const char gcodeLetter, const int32_t freeAxisIndex)=0
Map a letter in a Gcode file to a free axis. It will be used to specify the free axis' motion.
void CallbackRegister(Cartesian::GcodeCallback *callback, bool containsMotion=false)=0
Register a catch-all M-code callback.
int32_t ExecutingLineNumberGet()=0
Get the currently executing line number.
void AccelerationRateSet(double programmingUnitsPerMinuteSquared)=0
REQUIRED before Load() or LoadFile(). Sets the target acceleration for the machine (units/minute^2)....
void Load(const char *const text)=0
Load a G-code program from a string.
void Run()=0
Run the loaded G-Code file (or string). The behavior is non-blocking. Use DoneWait() to block.
bool IsRunning()=0
Returns true if a Gcode program is executing, false otherwise.
void FreeAxisAdd(const ModelAxisMapping &freeAxis)
Map a free axis in the kinematic model. The Axis' DefaultVelocity/Acceleration will be used for free ...
RSI::RapidCode::Cartesian::Gcode * Gcode
An object to load and run Gcode files.
CartesianAxis
Data for adding joint or free-axis mappings when building a kinematic model.
