Sets your G-Code program to interpret linear distance in either inches or mm. Equivalent to including G20/G21 in your program.
units
Millimeters / Inches
Clears the current feed rate! You must set a feed rate in the new unit domain (via an F word or Gcode::FeedRateSet) before any feed-governed motion (G1/G2/G3) can occur. This is true even if units do not actually change (e.g., G20 when units are already inches). Because of this, you cannot have G20/G21 on the same line as a feed-governed move.
