| Quaternion () |
| | Default Constructor. W=1, X=Y=Z=0.
| | Quaternion (const Quaternion &otherQuaternion) |
| | Constructor.
| | Quaternion (const Vector3d &rpy, RotationalUnits units=RotationalUnits::Radians) |
| | Euler Constructor (Alternate).
| | Quaternion (double w, const Vector3d &v) |
| | Constructor.
| | Quaternion (double w, double x, double y, double z) |
| | Constructor.
| | Quaternion (double x, double y, double z) |
| | Euler Constructor. Assumes RPY in Radians. To use a different unit, use Quaternion(const Vector3d&, RotationalUnits).
| Quaternion | Conjugate () const |
| | Negates the imaginary component of the Quaternion.
| double | Dot (const Quaternion &rightHandSide) const |
| | Returns the dot product of each element. w*rightHandSide.w+v.dot(rightHandSide.v).
| bool | Equals (const Quaternion &rightHandSide, const double tolerance) const |
| | Equality check within tolerance.
| bool | EqualsOrientation (const Quaternion &rightHandSide, const double tolerance) const |
| | Equality check within tolerance. For orientations q and -q are considered equal.
| Quaternion | Inverse () const |
| | Conjugate scaled by 1 / SumSquares().
| double | Magnitude () const |
| | Gets the magnitude of this. sqrt(SumSquares()).
| Quaternion & | Normalize () |
| | Normalizes this. Scales each component by 1 / magnitude.
| Quaternion | Normalized () const |
| | Retunrs a normalized copy of this.
| bool | operator!= (const Quaternion &rightHandSide) const |
| | Exact inequality check. See equals for approximately equal to.
| Quaternion | operator* (const Quaternion &rightHandSide) const |
| | Multiplication (rotation) operator. Rotates other by this.
| Vector3d | operator* (const Vector3d &rightHandSide) const |
| | Multiplication (vector rotation) operator. Rotates vector by this.
| Quaternion | operator* (double s) const |
| | Multiplication (scalar) operator. w*s, v*s.
| Quaternion & | operator*= (double s) |
| | Multiplication (scalar) assignment operator. See operator*(double).
| Quaternion | operator+ (const Quaternion &rightHandSide) const |
| | Adds two quaternions together. this.w + rightHandSide.w, this.v+rightHandSide.v.
| Quaternion & | operator+= (const Quaternion &rightHandSide) |
| | Addition assignment. Adds rightHandSide into this. See operator+.
| Quaternion | operator- () const |
| | Negates this quaternion (w, and v).
| Quaternion | operator- (const Quaternion &rightHandSide) const |
| | Subtraction operator. this.w - rightHandSide.w, this.v-rightHandSide.v.
| Quaternion & | operator-= (const Quaternion &rightHandSide) |
| | Subtraction assignment. Subtracts other from this. See operator-.
| Quaternion & | operator= (const Quaternion &rightHandSide) |
| | Assignment operator. Copies underlying.
| bool | operator== (const Quaternion &rightHandSide) const |
| | Exact equality check. See equals for approximately equal to.
| Quaternion & | Set (const Quaternion &otherQuaternion) |
| | Assigns other into this.
| Quaternion & | Set (const Vector3d &vec, RotationalUnits units=RotationalUnits::Radians) |
| | Assigns the quaternion defined by the Euler Angles into this.
| Quaternion & | Set (double w, const Vector3d &vec) |
| Quaternion & | Set (double w, double x, double y, double z) |
| | Assigns each component into this.
| Quaternion & | Set (double x, double y, double z) |
| | Assigns the quaternion defined by the Euler angles into this. Assumes RPY in Radians. To use a different unit, use Set(const Vector3d&, RotationalUnits) If you get unexpected values, try negating the returned quaternion (change the direction of rotation).
| double | SumSquares () const |
| | Gets the sum of the components squared (w*w+this.dot(this)).
| void | ToAngleAxis (double &outAngle, Vector3d &outAxis) const |
| | Gets the axis angle representation of this quaternion.
| Vector3d | ToEuler (RotationalUnits units=RotationalUnits::Radians) const |
| | Gets the Euler Angle representation of this quaternion.
| void | ToMatrix (double *matrix) const |
| | Quaternion To Matrix.
Definition at line 194 of file cartesianrobot.h.
