MathBlock.cs
10using RSI.RapidCode.dotNET; // the RapidCode.NET library.
11using System;
12
13#if DOXYGEN // RSI internal documentation use only
14using RSI.RapidCode;
15#endif
16
18public class MathBlockDifferenceOfPositionUserLimit : SampleApp
19{
20 public override int Run()
21 {
23 /* CONSTANTS */
24 // *NOTICE* The following constants must be configured before attempting to run with hardware.
25
26 // Controller Object Counts
27 const int MATHBLOCK_COUNT = 1; // minimum required MathBlocks for this sample
28 const int AXIS_COUNT = 2; // minimum required axes for this sample
29 const int USER_LIMIT_COUNT = 1; // minimum required user limits for this sample
30
31 // Axis Configuration
32 const int FIRST_AXIS_INDEX = 0; // the first axis index
33 const int SECOND_AXIS_INDEX = 1; // the second axis index
34 const double USER_UNITS = 1048576; // counts per unit (the user units)
35
36 // MathBlock Configuration
37 const int MATHBLOCK_INDEX = 0; // the mathblock index
38
39 // User Limit Configuration
40 const int USER_LIMIT_INDEX = 0; // the user limit index
41 const double MAX_POSITION_DIFFERENCE = 0.5 * USER_UNITS; // the maximum position difference before the user limit triggers
42 const RSIAction USER_LIMIT_ACTION = RSIAction.RSIActionABORT; // the action to take when the user limit is triggered
43 const int USER_LIMIT_DURATION = 0; // the time delay before the action is executed after the User Limit has triggered
44
45 // Motion Parameters
46 const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE; // the relative position to move the axes
47 const double VELOCITY = 1; // the velocity to move the axes
48 const double ACCELERATION = 10; // the acceleration of the axes movement
49 const double DECELERATION = 10; // the deceleration of the axes movement
50 const double JERK_PCT = 0; // the jerk percentage of the axes movement
51
52 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
53 USE_HARDWARE = false;
54
55 // Determine which axis address type to use based on the USE_HARDWARE flag
56 RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = (USE_HARDWARE) ?
57 (RSIAxisAddressType.RSIAxisAddressTypeACTUAL_POSITION) : (RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION);
58
59 /* SAMPLE APP BODY */
60
61 // Initialize MotionController class.
62 // NOTICE: Replace "rmpPath" with the path location of the RMP.rta (usually the RapidSetup folder)
63 // if project directory is different than rapid setup directory.
64 MotionController controller = HelperFunctionsCS.CreateController(/*rmpPath*/);
65
66 // Use a try/catch/finally to ensure that the controller is deleted when done.
67 try
68 {
69 HelperFunctionsCS.CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
70
71 // Setup the controller for the appropriate hardware configuration.
72 if (USE_HARDWARE)
73 {
75 }
76 else
77 {
78 HelperFunctionsCS.SetupControllerForPhantoms(controller, AXIS_COUNT, new int[] { FIRST_AXIS_INDEX, SECOND_AXIS_INDEX });
79 }
80
81 // configure the controller object counts
82 controller.MathBlockCountSet(MATHBLOCK_COUNT);
83 controller.MotionCountSet(AXIS_COUNT + 1);
84 controller.UserLimitCountSet(USER_LIMIT_COUNT);
85
86 // get both axis objects and check for errors
87 Axis axis0 = controller.AxisGet(FIRST_AXIS_INDEX);
89 axis0.UserUnitsSet(USER_UNITS); // set the user units (counts per unit)
90 axis0.PositionSet(0); // set the initial position to 0
91 axis0.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
92
93 Axis axis1 = controller.AxisGet(SECOND_AXIS_INDEX);
95 axis1.UserUnitsSet(USER_UNITS); // set the user units (counts per unit)
96 axis1.PositionSet(0); // set the initial position to 0
97 axis1.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
98
99 // configure a multiaxis for the two axes
100 MultiAxis multiAxis = controller.MultiAxisGet(AXIS_COUNT);
102
103 multiAxis.AxisRemoveAll();
104 multiAxis.AxisAdd(axis0);
105 multiAxis.AxisAdd(axis1);
106
107 multiAxis.Abort(); // make sure the multiaxis is not moving
108 multiAxis.ClearFaults(); // clear any faults
109
110 // read the configuration of the MathBlock
111 MotionController.MathBlockConfig mathBlockConfig = controller.MathBlockConfigGet(MATHBLOCK_INDEX);
112
113 // configure the MathBlock to subtract the position of the second axis from the position of the first axis
114 mathBlockConfig.InputAddress0 = axis0.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
115 mathBlockConfig.InputDataType0 = RSIDataType.RSIDataTypeDOUBLE;
116 mathBlockConfig.InputAddress1 = axis1.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
117 mathBlockConfig.InputDataType1 = RSIDataType.RSIDataTypeDOUBLE;
118 mathBlockConfig.ProcessDataType = RSIDataType.RSIDataTypeDOUBLE;
119 mathBlockConfig.Operation = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
120
121 // set the MathBlock configuration
122 controller.MathBlockConfigSet(MATHBLOCK_INDEX, mathBlockConfig);
123
124 // wait a sample so we know the RMP is now processing the newly configured MathBlocks
125 controller.SampleWait(1);
126 Console.WriteLine("MathBlock configured to subtract the position of the second axis from the position of the first axis.");
127
128 // get the address of the MathBlock's ProcessValue to use in the UserLimit
129 ulong mathBlockProcessValueAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, MATHBLOCK_INDEX);
130
131 // configure the UserLimit to trigger when the absolute position difference is greater than MAX_POSITION_DIFFERENCE
132 controller.UserLimitConditionSet(USER_LIMIT_INDEX, 0, RSIUserLimitLogic.RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE);
133
134 // set the UserLimit action to abort motion (Note: since the axes are in a multiaxis, the other axis will also be aborted)
135 controller.UserLimitConfigSet(USER_LIMIT_INDEX, RSIUserLimitTriggerType.RSIUserLimitTriggerTypeSINGLE_CONDITION, USER_LIMIT_ACTION, FIRST_AXIS_INDEX, USER_LIMIT_DURATION);
136 Console.WriteLine("UserLimit configured to trigger when the absolute position difference is greater than " + MAX_POSITION_DIFFERENCE + " and abort motion.");
137
138 // command motion to trigger the UserLimit
139 Console.WriteLine("Moving the axes to trigger the UserLimit...");
140 axis0.AmpEnableSet(true); // Enable the motor.
141 axis0.MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT); // Move the axis to trigger the UserLimit.
142 axis0.MotionDoneWait(); // Wait for the axis to finish moving.
143
144 // disable the motor and the UserLimit
145 axis0.AmpEnableSet(false); // Disable the motor.
146 controller.UserLimitDisable(USER_LIMIT_INDEX); // Disable User Limit.
147
148 // the motion should have been aborted and both axes should be in an error state
149 if (axis0.StateGet().Equals(RSIState.RSIStateERROR) &&
150 axis1.StateGet().Equals(RSIState.RSIStateERROR))
151 {
152 Console.WriteLine("Both axes are in the error state after the UserLimit triggered (This is the intended behavior).");
153 return 0;
154 }
155 else
156 {
157 Console.WriteLine("Error: The axes should be in an error state after the UserLimit triggers, but they are not.");
158 Console.WriteLine("First Axis State: " + axis0.StateGet());
159 Console.WriteLine("Second Axis State: " + axis1.StateGet());
160 return -1;
161 }
162 }
163 catch (Exception e)
164 {
165 Console.WriteLine("Error: " + e.Message);
166 return -1;
167 }
168 finally
169 {
170 controller.Delete(); // Delete the controller object.
171 }
173 }
174}
175
176public class MathBlockCalculateAccelerationFromVelocity : SampleApp
177{
178 public override int Run()
179 {
181 /* CONSTANTS */
182 // *NOTICE* The following constants must be configured before attempting to run with hardware.
183
184 // Controller Object Counts
185 const int MATHBLOCK_COUNT = 2; // minimum required MathBlocks for this sample
186 const int AXIS_COUNT = 1; // minimum required axes for this sample
187
188 // Axis Configuration
189 const int AXIS_INDEX = 0; // the axis index
190 const double USER_UNITS = 1048576; // counts per unit (the user units)
191
192 // MathBlock Configuration
193 const int SUBTRACTION_MATHBLOCK_INDEX = 0; // the first mathblock index (for subtraction)
194
195 // the second mathblock index (for multiplying CommandVelocity * 1.0)
196 const int PREVIOUS_VELOCITY_MATHBLOCK_INDEX = 1; // index must be higher here than the subtraction math block index, so the subtraction data is one sample old
197 const double ONE = 1.0; // we'll write 1.0 to the UserBuffer so the MathBlock can use it for multiplication
198 const int USERBUFFER_INDEX = 0; // where we'll write 1.0 so the math block can use it
199
200 // Motion Parameters
201 const double VELOCITY = 1.0; // the velocity to move the axis
202 const double ACCELERATION = 0.123; // something small so we can check the MathBlock is working
203
204 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
205 USE_HARDWARE = false;
206
207 // Determine which axis address type to use based on the USE_HARDWARE flag
208 RSIAxisAddressType INPUT_AXIS_ADDRESS_TYPE = RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY;
209
210 /* SAMPLE APP BODY */
211
212 // Initialize MotionController class.
213 // NOTICE: Replace "rmpPath" with the path location of the RMP.rta (usually the RapidSetup folder)
214 // if project directory is different than rapid setup directory.
215 MotionController controller = HelperFunctionsCS.CreateController(/*rmpPath*/);
216
217 // Use a try/catch/finally to ensure that the controller is deleted when done.
218 try
219 {
220 HelperFunctionsCS.CheckErrors(controller); // [Helper Function] Check that the axis has been initialize correctly.
221
222 // Setup the controller for the appropriate hardware configuration.
223 if (USE_HARDWARE)
224 {
226 }
227 else
228 {
229 HelperFunctionsCS.SetupControllerForPhantoms(controller, AXIS_COUNT, new int[] { AXIS_INDEX });
230 }
231
232 // configure the controller object counts
233 controller.MathBlockCountSet(MATHBLOCK_COUNT);
234
235 // write 1.0 to the UserBuffer so the MathBlock can use it for multiplication
236 controller.MemoryDoubleSet(controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, USERBUFFER_INDEX), ONE);
237
238 // get Axis object and check for errors
239 Axis axis = controller.AxisGet(AXIS_INDEX);
241 axis.UserUnitsSet(USER_UNITS); // set the user units (counts per unit)
242 axis.PositionSet(0); // set the initial position to 0
243 axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
244
245 axis.Abort(); // make sure the axis is not moving
246 axis.ClearFaults(); // clear any faults
247
248 // read the configuration of both MathBlocks
249 MotionController.MathBlockConfig subtractionConfig = controller.MathBlockConfigGet(SUBTRACTION_MATHBLOCK_INDEX);
250 MotionController.MathBlockConfig previousVelocityConfig = controller.MathBlockConfigGet(PREVIOUS_VELOCITY_MATHBLOCK_INDEX);
251
252 // configure the first MathBlock to subtract the previous velocity from the current velocity
253 // current velocity:
254 subtractionConfig.InputAddress0 = axis.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
255 subtractionConfig.InputDataType0 = RSIDataType.RSIDataTypeDOUBLE;
256 // previous velocity: (as was calculated by the second MathBlock, so we use its ProcesValue)
257 subtractionConfig.InputAddress1 = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, PREVIOUS_VELOCITY_MATHBLOCK_INDEX);
258 subtractionConfig.InputDataType1 = RSIDataType.RSIDataTypeDOUBLE;
259 subtractionConfig.ProcessDataType = RSIDataType.RSIDataTypeDOUBLE;
260 subtractionConfig.Operation = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
261
262 // configure the second MathBlock to multiply the current velocity by 1.0 (which we'll use for the previous sample's velocity)
263 previousVelocityConfig.InputAddress0 = axis.AddressGet(INPUT_AXIS_ADDRESS_TYPE);
264 previousVelocityConfig.InputDataType0 = RSIDataType.RSIDataTypeDOUBLE;
265 previousVelocityConfig.InputAddress1 = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, USERBUFFER_INDEX);
266 previousVelocityConfig.InputDataType1 = RSIDataType.RSIDataTypeDOUBLE;
267 previousVelocityConfig.ProcessDataType = RSIDataType.RSIDataTypeDOUBLE;
268 previousVelocityConfig.Operation = RSIMathBlockOperation.RSIMathBlockOperationMULTIPLY;
269
270 // set the MathBlock configurations
271 controller.MathBlockConfigSet(SUBTRACTION_MATHBLOCK_INDEX, subtractionConfig);
272 controller.MathBlockConfigSet(PREVIOUS_VELOCITY_MATHBLOCK_INDEX, previousVelocityConfig);
273
274 // wait a sample so we know the RMP is now processing the newly configured MathBlocks
275 controller.SampleWait(1);
276
277 // Set the axis to move with a very small acceleration so we can check the MathBlock is working
278 axis.AmpEnableSet(true); // Enable the motor.
279 axis.MoveVelocity(VELOCITY, ACCELERATION);
280
281 // wait several samples so we know the RMP is now processing the move command and accelerating
282 controller.SampleWait(10);
283
284 // keep in mind firmware velocity is in counts per sample squared, so we need to convert to UserUnits per second squared
285 double calculatedAccelerationCountsPerSampleSquared = controller.MathBlockProcessValueGet(SUBTRACTION_MATHBLOCK_INDEX).Double;
286
287 // reduce the velocity back to 0
288 axis.MoveVelocity(0, ACCELERATION);
289
290 axis.MotionDoneWait(); // Wait for the axis to finish moving.
291 axis.AmpEnableSet(false); // Disable the motor.
292
293 // convert to UserUnits per second squared
294 double calculatedAcceleration = calculatedAccelerationCountsPerSampleSquared * controller.SampleRateGet() * controller.SampleRateGet() / axis.UserUnitsGet();
295 Console.WriteLine($"Calculated acceleration from MathBlock: {calculatedAcceleration}");
296
297 // check that the newly calculated acceleration is as expected
298 if (Math.Abs(calculatedAcceleration - ACCELERATION) <= 0.000001)
299 {
300 Console.WriteLine("The MathBlock is calculating the Axis' acceleration by subtracting previous velocity from current velocity.");
301 return 0;
302 }
303 else
304 {
305 Console.WriteLine("Error: The MathBlock is not calculating the Axis' acceleration as expected.");
306 return -1;
307 }
308 }
309 catch (Exception e)
310 {
311 Console.WriteLine("Error: " + e.Message);
312 return -1;
313 }
314 finally
315 {
316 controller.Delete(); // Delete the controller object.
317 }
319 }
320}
static void SetupControllerForHardware(MotionController controller)
static MotionController CreateController()
Creates the MotionController object, using creation parameters.
static void SetupControllerForPhantoms(MotionController controller, int axisCount, int[] axisNums)
HelperFunctionsCS class provides static methods for common tasks in RMP applications.
double UserUnitsGet()
Definition rsi.h:5789
Configure a User Limit.
Definition rsi.h:800
void AxisRemoveAll()
void AxisAdd(Axis *axis)
Definition rsi.h:10701
int32_t MotionDoneWait()
RSIState StateGet()
MathBlock operations.
Definition rsienums.h:1401
RSIDataType
Definition rsienums.h:659
RSIUserLimitLogic
Definition rsienums.h:646
Definition rsienums.h:1112
Definition rsienums.h:434
Trigger types for UserLimits.
Definition rsienums.h:633
Definition rsi.h:3816
double Double
Definition rsi.h:477
