PathMotion.cpp
27
28#include <iostream>
29#include <fstream>
30
31#include "rsi.h" // Import our RapidCode Library.
32#include "SampleAppsHelper.h" // Import our SampleApp helper functions.
33#include "SampleApps.h"
34
35using namespace RSI::RapidCode; // Import the RapidCode namespace
36
38int PathMotion::Run()
39{
41 /* CONSTANTS */
42 // *NOTICE* The following constants must be configured before attempting to run with hardware.
43
44 // Axis configuration parameters
45 const int AXIS_COUNT = (2);
46 const int AXIS_X = 0;
47 const int AXIS_Y = 1;
48
49 const double USER_UNITS = 1048576;
50
51 // Default file path for recording the path followed by the axes
52 const char* const PATH_MOTION_FILEPATH = "PathMotion.csv";
53
54 // To run with hardware, set the USE_HARDWARE flag to true AFTER you have configured the parameters above and taken proper safety precautions.
55 USE_HARDWARE = false;
56
57 /* SAMPLE APP BODY */
58
59 Axis* axisX;
60 Axis* axisY;
61 MultiAxis* multiAxisXY;
62
63 double running_x = 0;
64 double running_y = 0;
65
66 double line_A[2] = { running_x, running_y };
67 running_x += -0.5;
68 double line_B[2] = { running_x, running_y };
69 running_y += -0.5;
70 double line_C[2] = { running_x, running_y };
71
72 //curve down
73 running_y += (-0.25);
74 double arc_center_A[2] = { running_x,running_y };
75 running_x += (0.25);
76
77 //curve left
78 running_x += -0.25;
79 double arc_center_B[2] = { running_x,running_y };
80 running_y += -0.25;
81
82 //curve up
83 running_y += 0.25;
84 double arc_center_C[2] = { running_x,running_y };
85 running_x += -0.25;
86
87 //curve right
88 running_x += 0.25;
89 double arc_center_D[2] = { running_x,running_y };
90 running_y += 0.25;
91
92 running_x += -0.5;
93 running_y += 0.5;
94 double line_D[2] = { running_x, running_y };
95
96 // Create and initialize RsiController class
97 MotionController* controller = MotionController::CreateFromSoftware();
99
100 // Setup the controller for the appropriate hardware configuration.
101 if (USE_HARDWARE)
102 {
104 }
105 else
106 {
107 SampleAppsHelper::SetupControllerForPhantoms(controller, AXIS_COUNT, { AXIS_X, AXIS_Y });
108 }
109
110 try
111 {
112 // enable one MotionSupervisor for the MultiAxis
113 controller->MotionCountSet(controller->AxisCountGet() + 1);
114
115 // Get Axis X and Y respectively.
116 Axis* axisX = controller->AxisGet(AXIS_X);
118 axisX->PositionSet(0);
124 axisX->UserUnitsSet(USER_UNITS);
125 axisX->Abort();
126
127 Axis* axisY = controller->AxisGet(AXIS_Y);
129 axisY->PositionSet(0);
135 axisY->UserUnitsSet(USER_UNITS);
136 axisY->Abort();
137
138 // Initialize a MultiAxis, using the last MotionSupervisor.
139 MultiAxis* multiAxisXY = controller->MultiAxisGet(controller->MotionCountGet() - 1);
141 multiAxisXY->AxisAdd(axisX);
142 multiAxisXY->AxisAdd(axisY);
143
144 // make sure all axes are enabled and ready
145 multiAxisXY->Abort();
146 multiAxisXY->ClearFaults();
147 multiAxisXY->AmpEnableSet(true);
148
149 axisX->Home();
150 axisY->Home();
151
152 multiAxisXY->AmpEnableSet(false);
153
154 // set the trajectory info
155 multiAxisXY->VectorVelocitySet(1.0 * USER_UNITS);
156 multiAxisXY->VectorAccelerationSet(10.0 * USER_UNITS);
157 multiAxisXY->VectorDecelerationSet(10.0 * USER_UNITS);
158
159 // start path list
160 double start_positions[2] = { axisX->CommandPositionGet(),axisY->CommandPositionGet() };
161 multiAxisXY->PathListStart(start_positions);
162
163 multiAxisXY->ClearFaults();
164
165 // turn on blending (smooth corners)
166 multiAxisXY->PathBlendSet(true);
167
168 // Lines and arcs
169 multiAxisXY->PathLineAdd(line_A);
170 multiAxisXY->PathLineAdd(line_B);
171 multiAxisXY->PathLineAdd(line_C);
172 multiAxisXY->PathArcAdd(arc_center_A, -90.0);
173 multiAxisXY->PathArcAdd(arc_center_B, -90.0);
174 multiAxisXY->PathArcAdd(arc_center_C, -90.0);
175 multiAxisXY->PathArcAdd(arc_center_D, -90.0);
176 multiAxisXY->PathLineAdd(line_D);
177
178 // end path list
179 multiAxisXY->PathListEnd();
180
181 // make sure all axes are enabled and ready
182 multiAxisXY->ClearFaults();
183 multiAxisXY->AmpEnableSet(true);
184 // execute the motion
185 multiAxisXY->PathMotionStart();
186
187 // log positions
188 std::ofstream myfile;
189 myfile.open(PATH_MOTION_FILEPATH);
190 myfile << "samples,x,y,\n";
191
192 while (!multiAxisXY->MotionDoneGet()) {
193
194 myfile << controller->SampleCounterGet() << "," << axisX->CommandPositionGet() << "," << axisY->CommandPositionGet() << "\n";
195 controller->SampleWait(10);
196 }
197 // wait for motion to complete
198 multiAxisXY->MotionDoneWait();
199 multiAxisXY->AmpEnableSet(false);
200 myfile.close();
201 printf("\n%s\n", PATH_MOTION_FILEPATH);
202 }
203 catch (RsiError const& err)
204 {
205 printf("\n%s\n", err.text);
206 return -1;
207 }
208 controller->Delete(); // Delete the controller as the program exits to ensure memory is deallocated in the correct order.
209 return 0;
211}
double CommandPositionGet()
void AmpDisableActionSet(RSIMotorDisableAction action)
Set the Amp Disable action.
void Home()
Execute the homing routine.
int32_t SampleCounterGet()
Get the current value of the controller's processor's sample counter.
int32_t AxisCountGet()
int32_t MotionCountGet()
void PathListStart(const double *const startPosition)
Start a line and arc point list for path motion.
void PathMotionStart()
Start the path motion.
void PathArcAdd(const double *const center, double angle)
Add an arc segment to the path.
void VectorDecelerationSet(double deceleration)
Set the vector deceleration.
void PathLineAdd(const double *const position)
Add a line segment to the path.
void PathBlendSet(bool blend)
Set the blending attribute.
void VectorAccelerationSet(double acceleration)
Set the vector acceleration.
void PathListEnd()
End a line and arc point list for path motion.
void AxisAdd(Axis *axis)
void VectorVelocitySet(double velocity)
Set the vector velocity.
int32_t MotionDoneWait()
bool MotionDoneGet()
@ RSIMotorDisableActionNONE
No action taken when disabled.
Definition rsienums.h:1321
@ RSIActionNONE
Definition rsienums.h:1117
