Motion Hold
Execute motion on an Axis or MultiAxis triggered by real-time conditions such as I/O values, axis positions, or software triggers.
🔹 What is Motion Hold?
Motion Hold is a feature available to any motion on an Axis or MultiAxis. The feature allows the user to command (and therefore load) a motion that should not execute immediately. The motion will be triggered by some real-time condition monitored by the RMP firmware.
There are three main types of Motion Hold:
  • I/O triggered motion - A motion holds its execution until an I/O value reaches the desired state.
  • Position triggered motion - A motion holds its execution until an Axis position is exceeded.
  • Software triggered motion - A motion holds its execution until a bit is set in the RMP’s firmware memory.
🔹 Why use Motion Hold?
Motion Hold is especially useful when a motion needs to have a very tight synchronization with some other process – when the synchronization must be accurate to less than one millisecond. A Windows app cannot offer this level of synchronization so it must be configured into the RMP for processing in the real-time firmware for sub-millisecond response to start motion.
Some examples of when Motion Hold might be used for various types:
EXAMPLE 1 - IO Triggered Motion \ An Axis may need to perform its motion precisely when a digital input bit changes state.
EXAMPLE 2 - Position Triggered Motion \ An Axis may need to wait for some other Axis to move into a safe position before it can start its motion.
EXAMPLE 3 - Software Triggered Motion \ An Axis object (Or two axes) that has independent motion but must be started synchronously (can also be accomplished using MultiAxis). The Windows application will set a bit in RMP firmware memory which will trigger both Axis objects to start within the same RMP sample period.
📜 Sample Code
IO Triggered Motion
An Axis may need to perform its motion precisely when a digital input bit changes state. This sample code is done in AKD Drive with Digital IO Inputs switches. A digital input switch triggers to release the HOLD set on the specified Motion. This functionality is available for all Drives but some changes to the sample app may be required.
An Axis may need to wait for some other Axis to move into a safe position before it can start its motion. This sample code is done in AKD Drive with one Actual Axis and one Phantom Axis. It can be applied to two Phantom Axis or two Actual Axis with the slight changes of code which is guided in comment.
An Axis object (Or two axes) that has independent motion but must be started synchronously (can also be accomplished using MultiAxis). The Windows application will set a bit in RMP firmware memory which will trigger both Axis objects to start within the same RMP sample period. This sample code is done in AKD Drive with one Actual axis. There are a lots of available/free firmware address. Some are suggested in comment. Available/free firmware addresses can be found using vm3 as long as there is no label on address, it can be used.
  • C#
    /* This sample demonstrates how to hold motion using a software address (memory location).
    Motion is held until a specific bit pattern is written to the address, useful for custom logic.
    using System.Threading;
    Console.WriteLine("📜 Motion Hold: via Address");
    const int MOVE_DISTANCE = 2;
    // configure phantom axis
    axis.PositionSet(0);
    // get available software address from user buffer
    ulong softwareAddress = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 1);
    // configure motion hold on software address
    axis.MotionHoldUserAddressSet(softwareAddress); // specify the host address
    axis.MotionHoldUserMaskSet(0x1); // specify the bit to watch (logic AND)
    axis.MotionHoldUserPatternSet(0x1); // bit value that will release the motion hold
    // ensure condition is false initially
    if (controller.MemoryGet(softwareAddress) != 0x0)
    controller.MemorySet(softwareAddress, 0x0);
    // enable motion hold
    // command motion - will be held
    axis.MoveRelative(MOVE_DISTANCE);
    Console.WriteLine($"\tFirst motion commanded to move {MOVE_DISTANCE} (held)");
    Thread.Sleep(100);
    double positionWhileHeld = axis.CommandPositionGet();
    Console.WriteLine($"\tPosition while held: {positionWhileHeld} (should be 0)");
    // release motion hold by setting the address
    controller.MemorySet(softwareAddress, 0x1);
    Console.WriteLine("\tReleasing hold via address...");
    controller.MemorySet(softwareAddress, 0x0); // reset to false
    Console.WriteLine($"\tPosition after release: {axis.CommandPositionGet()} (expected: {MOVE_DISTANCE})");
    // command motion again - will be held again
    Console.WriteLine($"\tSecond motion commanded to move {MOVE_DISTANCE} (held)");
    Thread.Sleep(100);
    // release motion hold again
    // disable motion hold
    // this motion will execute immediately
    Console.WriteLine($"\tThird motion commanded to move {MOVE_DISTANCE} (no hold)");
    Console.WriteLine($"\tFinal position: {axis.CommandPositionGet()} (expected: {MOVE_DISTANCE * 3})");
    // clean up
    Definition _constants.cs:26
    double CommandPositionGet()
  • C++
    /* CONSTANTS */
    const int AXIS_COUNT = 1;
    const int AXIS_NUMBER = 0;
    // Index for the address in the user buffer to use for the motion hold
    const int USER_BUFFER_INDEX = 0;
    // Motion parameters
    const double MOTION_DISTANCE = 0.25;
    const std::chrono::duration HOLD_TIME = std::chrono::milliseconds(2000);
    USE_HARDWARE = false;
    const char rmpPath[] = "C:\\RSI\\X.X.X\\"; // Insert the path location of the RMP.rta (usually the RapidSetup folder)"
    /* SAMPLE APP BODY */
    MotionController* controller = MotionController::CreateFromSoftware(/*rmpPath*/); // NOTICE: Uncomment "rmpPath" if project directory is different than rapid setup directory.
    if (USE_HARDWARE)
    // GET AXIS READY
    axis->UserUnitsSet(USER_UNITS); // Specify the counts per Unit.
    axis->PositionSet(0); // Make sure motor starts at position 0 every time.
    axis->ErrorLimitTriggerValueSet(1); // Set the position error trigger value
    axis->AmpEnableSet(true); // Enable the motor.
    // GET AN AVAILABLE MEMORY ADDRESS
    uint64_t userBufferAddress = controller->AddressGet(RSIControllerAddressType::RSIControllerAddressTypeUSER_BUFFER, USER_BUFFER_INDEX);
    // SET MOTION HOLD ON AVAILABLE SOFTWARE ADDRESS
    axis->MotionHoldTypeSet(RSIMotionHoldType::RSIMotionHoldTypeCUSTOM); // Use TypeCUSTOM to hold execution based on a particular bit turning ON or OFF.
    axis->MotionHoldUserAddressSet(userBufferAddress); // Specify the available hostAddress . This address' value will be used to evaluate the motion hold condition.
    axis->MotionHoldUserMaskSet(0x1); // Specify the bit you want to mask/watch from the MotionHoldUserAddressSet' address value (this evaluates using a logic AND)
    axis->MotionHoldUserPatternSet(0x1); // Specify the bit value that will release the motion hold. (When this value is met, motion hold will be released)
    // Check the condition to be false at first
    if (controller->MemoryGet(userBufferAddress) != 0x0) // Check Available host address value is mask to be false (in this case 0x0)
    controller->MemorySet(userBufferAddress, 0x0); // if not, mask it to false value/condition (in this case 0x0)
    // COMMAND MOTION (NO HOLD YET)
    printf("\nCommanding Motion...\n");
    axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will have no HOLD)
    // SET MOTION HOLD
    printf("\nSetting Motion Hold...\n");
    axis->MotionAttributeMaskOnSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
    // COMMAND MOTION AGAIN (MOTION WILL BE HELD)
    printf("Commanding Motion...\n");
    axis->MoveRelative(MOTION_DISTANCE); // Command simple relative motion. (This motion will be HOLD by the condition above)
    std::this_thread::sleep_for(HOLD_TIME); // Sleep for 3 second before releasing motion hold.
    // RELEASE MOTION HOLD (MOTION WILL START)
    printf("Releasing Motion Hold...\n");
    controller->MemorySet(userBufferAddress, 0x1); // Release Motion Hold by specifying the host address value to SET Condition (in this case 0x10000)
    axis->MotionDoneWait(); // Wait for motion to be done
    controller->MemorySet(userBufferAddress, 0x0); // Specify host address value back to false value/condition (in this case 0x0)
    // CLEAR MOTION HOLD
    printf("\nClearing Motion Hold...\n");
    axis->MotionAttributeMaskOffSet(RSIMotionAttrMask::RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask OFF. (This will clear any motion HOLDS that were set on this Axis)
    // COMMAND MOTION AGAIN (NO HOLD)
    axis->MoveRelative(-2 * MOTION_DISTANCE); // This motion will have no HOLD since the previous line has set the motion attribute mask OFF.
    axis->MotionDoneWait(); // Wait for Motion to be completed.
    // Abort and Clear Faults
    axis->Abort();
    catch (RsiError const& err)
    printf("%s\n", err.text); // If there are any exceptions/issues this will be printed out.
    return -1;
    return 0;
