Learn how to configure different settings for an axis.
- Warning
In this page:
📜 Axis: Hardware Limits
Learn how to configure Hardware Limits 📖 including trigger states, duration settings, and actions for axis safety and protection.
const int TRIGGER_STATE = 1;
const double DURATION = 0.01;
Source: axis-configuration.cpp
📜 Axis: Settling Criteria
Learn how to configure Settling 📖 criteria to determine when an axis has successfully reached its target position.
const double POSITION_TOLERANCE_FINE = 200;
const double POSITION_TOLERANCE_COARSE = 300;
const double VELOCITY_TOLERANCE = 12000;
const double SETTLING_TIME = 5;
📜 Axis: Stop Rate
Learn how to configure Stopping Rates 📖 for controlled deceleration when stopping axis motion.
const double STOP_RATE_DEFAULT = 1.0;
const double ESTOP_RATE_DEFAULT = 0.05;
const double ESTOP_DECELERATION_RATE = 1000;
📜 Axis: User Units
Learn how to configure Counts Per Unit (User Units) 📖 to set up proper scaling between user units and encoder counts.
const int ENCODER_RESOLUTION_BITS = 20;
const double USER_UNITS = std::pow(2, ENCODER_RESOLUTION_BITS);
📜 Axis: Phantom Axis
Learn how to create Phantom Axes 📖 that can be used for virtual axis operations.
const double positionToleranceMax = std::numeric_limits<double>::max() / 10.0;
Source: phantom-axis.cpp
