39using RSI.RapidCode.dotNET;
50public class MotionHold : SampleAppTestBase
52 public void MotionHoldByDigitalInput()
56 const int DIGITAL_INPUTS_PDO_INDEX = 3;
86 public void MotionHoldByPosition()
90 const double TRIGGER_POS = 1;
91 const int MOVING_AXIS_TARGET = 10;
92 const int HOLDINGAXIS_TARGET = 2;
123 public void MotionHoldBySoftwareAddress()
138 if (controller.
MemoryGet(SOFTWARE_ADDRESS) != 0x0)
140 controller.
MemorySet(SOFTWARE_ADDRESS, 0x0);
147 System.Threading.Thread.Sleep(WAIT_TIME);
152 controller.
MemorySet(SOFTWARE_ADDRESS, 0x1);
154 controller.
160 System.Threading.Thread.Sleep(WAIT_TIME);
163 controller.
165 controller.
175 Assert.That(expectedCmdPos1, Is.EqualTo(0));
176 Assert.That(expectedCmdPos2, Is.EqualTo(MOVE_DIST));
double CommandPositionGet()
int32_t MemoryGet(uint64_t address)
Read controller memory.
uint64_t NetworkInputAddressGet(int32_t index)
Sets the Axis position.
int32_t MotionDoneWait()
Set the motion hold type.
int32_t NumberGet()
Get the axis number.
RSIUserLimitLogic
RSIMotionAttrMask
RSIMotionHoldType
