#include <map>
#include "SampleAppsHelper.h"
#include "rsi.h"
static const std::map<RSIState, std::string> RSIStateMap = {
{RSIState::RSIStateIDLE, "RSIStateIDLE"},
{RSIState::RSIStateMOVING, "RSIStateMOVING"},
{RSIState::RSIStateSTOPPING, "RSIStateSTOPPING"},
{RSIState::RSIStateSTOPPED, "RSIStateSTOPPED"},
{RSIState::RSIStateSTOPPING_ERROR, "RSIStateSTOPPING_ERROR"},
{RSIState::RSIStateERROR, "RSIStateERROR"}
int main()
const std::string SAMPLE_APP_NAME = "Math Blocks: Difference of Position User Limit";
const RSIAction USER_LIMIT_ACTION = RSIAction::RSIActionABORT;
const int USER_LIMIT_DURATION = 0;
const double RELATIVE_POSITION = 2 * MAX_POSITION_DIFFERENCE;
const double VELOCITY = 1;
const double ACCELERATION = 10;
const double DECELERATION = 10;
const double JERK_PCT = 0;
int exitCode = -1;
: (RSIAxisAddressType::RSIAxisAddressTypeCOMMAND_POSITION);
mathBlockConfig.
Operation = RSIMathBlockOperation::RSIMathBlockOperationSUBTRACT;
std::cout << "MathBlock configured to subtract the position of the second axis from the position of the first axis." << std::endl;
uint64_t mathBlockProcessValueAddress =
controller->
AddressGet(RSIControllerAddressType::RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, MATHBLOCK_INDEX);
USER_LIMIT_INDEX, 0, RSIUserLimitLogic::RSIUserLimitLogicABS_GT, mathBlockProcessValueAddress, MAX_POSITION_DIFFERENCE
USER_LIMIT_DURATION
std::cout << "UserLimit configured to trigger when the absolute position difference is greater than " << MAX_POSITION_DIFFERENCE
<< " and abort motion." << std::endl;
std::cout << "Moving the axes to trigger the UserLimit..." << std::endl;
axisX->
MoveRelative(RELATIVE_POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PCT);
if ((axisX->
StateGet() == RSIState::RSIStateERROR) && (axisY->
StateGet() == RSIState::RSIStateERROR))
std::cout << "Both axes are in the error state after the UserLimit triggered (This is the intended behavior)." << std::endl;
exitCode = 0;
std::cout << "Error: The axes should be in an error state after the UserLimit triggers, but they are not." << std::endl;
std::cout <<
"First Axis State: " << RSIStateMap.at(axisX->
StateGet()) << std::endl;
std::cout <<
"Second Axis State: " << RSIStateMap.at(axisY->
exitCode = -1;
exitCode = -1;
Configure a User Limit.
void AxisRemoveAll()
void AxisAdd(Axis *axis)
int32_t MotionDoneWait()
RSIState StateGet()
static void SetupController(MotionController *controller)
RSIDataType ProcessDataType
Data type for processing.
uint64_t InputAddress0
RSIDataType InputDataType0
uint64_t InputAddress1
RSIDataType InputDataType1
static constexpr int AXIS_COUNT
Number of axes to configure on the controller.
static constexpr int USER_LIMIT_COUNT
Number of user limits to configure on the controller.
static constexpr int AXIS_X_INDEX
Index of the first axis to use in the sample apps.
static constexpr int MATH_BLOCK_COUNT
Number of math block objects to configure on the controller.
static constexpr bool USE_HARDWARE
static constexpr int AXIS_X_USER_UNITS
User units for the first axis.
static constexpr int AXIS_Y_INDEX
Index of the second axis to use in the sample apps.
