◆ ConfigurePhantomAxis()
void ConfigurePhantomAxis ( MotionController * controller,
int axisIndex )
controllerPointer to the MotionController containing the axis.
axisIndexThe index of the axis to configure as a phantom axis.
Exceptions
std::invalid_argumentThrown if an invalid axis index is provided.
void ConfigurePhantomAxis(MotionController *controller, int axisIndex)
// Check that the axis has been initialized correctly
Axis* axis = controller->AxisGet(axisIndex);
10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis->PositionToleranceFineSet(positionToleranceMax
); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
[ConfigurePhantomAxis]
config.h.
Definition at line 110 of file config.h.
