◆ GetCreationParameters()
MotionController::CreationParameters GetCreationParameters ( )
┌───────────────────────────┐ │ USER CONFIG ENDS HERE │ └───────────────────────────┘
#if _WIN32
// Create a controller with using defined parameters
MotionController::CreationParameters params;
strncpy(params.RmpPath, RMP_PATH, params.PathLengthMaximum);
strncpy(params.NicPrimary, NIC_PRIMARY, params.PathLengthMaximum);
strncpy(params.NodeName, NODE_NAME, params.PathLengthMaximum);
return params;
#elif __linux__
return params;
#endif
[GetCreationParameters]
axis-configuration.cpp, calculate-acceleration-from-velocity.cpp, config.h, difference-of-position-user-limit.cpp, follow-sensor.cpp, hello-rttasks.cpp, phantom-axis.cpp, point-to-point.cpp, print-network-topology.cpp, record-performance.cpp, and starter-template.cpp.
Definition at line 81 of file config.h.
