11.1.1
SetupController()
void SetupController
MotionController
controller
int
numAxes
0
void
SetupController
(MotionController *controller,
int
numAxes = 0)
// Start or shutdown the network depending on the configuration
if
USE_HARDWARE
Helpers::NetworkStart
(controller);
if
(controller->
NetworkStateGet
() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
controller->
NetworkStateGet
() != RSINetworkState::RSINetworkStateSHUTDOWN)
std::ostringstream message;
message <<
"The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n"
"If you intended to run with hardware, then follow the steps in README.md and /src/config.h\n"
"Otherwise, shutdown the network before running the sample apps with phantom axes."
throw
std::runtime_error(message.str().c_str());
// Check if we are using hardware or phantom axes
if
USE_HARDWARE
// Let the user defined function configure the axes
ConfigureHardwareAxes
(controller);
// Check that there are enough axes configured
int
axisCount = controller->
AxisCountGet
if
(axisCount < numAxes)
message <<
"Error! Not enough axes configured. Expected "
<< numAxes <<
" axes but only found "
<< axisCount <<
" axes."
"Please configure the axes in the Config::ConfigureHardwareAxes function."
throw
// Record the initial object counts to restore later
initialAxisCount
= controller->
AxisCountGet
initialMotionCount
= controller->
MotionCountGet
// Add phantom axes for the sample app if needed
if
(numAxes >
initialAxisCount
controller->
AxisCountSet
(numAxes);
for
int
i = 0; i < numAxes; i++)
ConfigurePhantomAxis
(controller, i);
[SetupController]
axis-configuration.cpp
calculate-acceleration-from-velocity.cpp
config.h
difference-of-position-user-limit.cpp
follow-sensor.cpp
hello-rttasks.cpp
phantom-axis.cpp
point-to-point.cpp
, and
starter-template.cpp
Definition at line
147
of file
config.h
Config
1.15.0
