config.h
1#ifndef CONFIG_H
2#define CONFIG_H
3
4// These macros are defined as part of the build process in CMake. To avoid
5// build errors, we default them to empty strings if they are not defined.
6#ifndef RMP_INSTALL_PATH
7#define RMP_INSTALL_PATH ""
8#endif
9
10#include <sstream>
11#include <source_location>
12
13#include "rsi.h" // Import our RapidCode Library.
14
15#include "helpers.h"
16
17using namespace RSI::RapidCode; // Import our RapidCode namespace
18
24namespace Config
25{
26
32
33 // Motion Controller Creation Parameters
34 inline constexpr char RMP_PATH[] = RMP_INSTALL_PATH;
35 inline constexpr char NIC_PRIMARY[] = "";
36 inline constexpr char NODE_NAME[] = "";
37 inline constexpr int CPU_AFFINITY = 0;
38
39 // If you want to use hardware, then follow the instructions in the README before setting this to true.
40 inline constexpr bool USE_HARDWARE = false;
41
48 {
49 // If you have configured your axes using rsiconfig, RapidSetup, or RapidSetupX then you can comment out this error and return.
50 // IMPLEMENTATION REQUIRED: Configure the axes for hardware
51 std::ostringstream message;
52 message << "You must implement the " << __func__ << " function (found in " << __FILE__ << " line " << __LINE__ << ") to use hardware.";
53 throw std::runtime_error(message.str().c_str());
54
55 // Simple Axis Configuration Example:
56 // (Look at the Axis: Configuration section in the RapidCode API Reference for more advanced configurations)
57
58 // const int USER_UNITS = 1048576; // example for 20-bit encoder, 2^20 = 1048576
59 // Axis *axis = controller->AxisGet(0);
60 // Helpers::CheckErrors(axis);
61 // axis->UserUnitsSet(USER_UNITS);
62 // axis->PositionSet(0);
63 // axis->ErrorLimitTriggerValueSet(0.1 * USER_UNITS);
64 // axis->ErrorLimitActionSet(RSIAction::RSIActionABORT);
65 // axis->Abort();
66 // axis->ClearFaults();
67 }
68
74
80 #if _WIN32
82 {
83 // Create a controller with using defined parameters
85 strncpy(params.RmpPath, RMP_PATH, params.PathLengthMaximum);
86 strncpy(params.NicPrimary, NIC_PRIMARY, params.PathLengthMaximum);
87 strncpy(params.NodeName, NODE_NAME, params.PathLengthMaximum);
88 return params;
89 }
90 #elif __linux__
92 {
94 strncpy(params.RmpPath, RMP_PATH, params.PathLengthMaximum);
95 strncpy(params.NicPrimary, NIC_PRIMARY, params.PathLengthMaximum);
97 return params;
98 }
99 #endif
101
110 void ConfigurePhantomAxis(MotionController *controller, int axisIndex)
111 {
112 // Check that the axis has been initialized correctly
113 Axis* axis = controller->AxisGet(axisIndex);
115
116 // These limits are not meaningful for a Phantom Axis (e.g., a phantom axis has no actual position so a position error trigger is not necessary)
117 // Therefore, you must set all of their actions to "NONE".
118 axis->PositionSet(0); // Set the position to 0
119 axis->ErrorLimitActionSet(RSIAction::RSIActionNONE); // Set Error Limit Action.
120 axis->AmpFaultActionSet(RSIAction::RSIActionNONE); // Set Amp Fault Action.
121 axis->AmpFaultTriggerStateSet(1); // Set Amp Fault Trigger State.
122 axis->HardwareNegLimitActionSet(RSIAction::RSIActionNONE); // Set Hardware Negative Limit Action.
123 axis->HardwarePosLimitActionSet(RSIAction::RSIActionNONE); // Set Hardware Positive Limit Action.
124 axis->SoftwareNegLimitActionSet(RSIAction::RSIActionNONE); // Set Software Negative Limit Action.
125 axis->SoftwarePosLimitActionSet(RSIAction::RSIActionNONE); // Set Software Positive Limit Action.
126 axis->HomeActionSet(RSIAction::RSIActionNONE); // Set Home Action.
127
128 const double positionToleranceMax =
129 std::numeric_limits<double>::max() /
130 10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
131 axis->PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
132 axis->PositionToleranceFineSet(positionToleranceMax
133 ); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
134
135 axis->MotorTypeSet(RSIMotorType::RSIMotorTypePHANTOM); // Set the MotorType to phantom
136 }
137
138
139 static int initialAxisCount = -1;
140 static int initialMotionCount = -1;
141
147 void SetupController(MotionController *controller, int numAxes = 0)
148 {
149 // Start or shutdown the network depending on the configuration
150 if (USE_HARDWARE)
151 {
152 Helpers::NetworkStart(controller);
153 }
154 else if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
155 controller->NetworkStateGet() != RSINetworkState::RSINetworkStateSHUTDOWN)
156 {
157 std::ostringstream message;
158 message << "The Sample Apps are configured to use Phantom Axes, but the network is not in the UNINITIALIZED or SHUTDOWN state.\n"
159 << "If you intended to run with hardware, then follow the steps in README.md and /src/config.h\n"
160 << "Otherwise, shutdown the network before running the sample apps with phantom axes.";
161
162 throw std::runtime_error(message.str().c_str());
163 }
164
165 // Check if we are using hardware or phantom axes
166 if (USE_HARDWARE)
167 {
168 // Let the user defined function configure the axes
169 ConfigureHardwareAxes(controller);
170
171 // Check that there are enough axes configured
172 int axisCount = controller->AxisCountGet();
173 if (axisCount < numAxes)
174 {
175 std::ostringstream message;
176 message << "Error! Not enough axes configured. Expected " << numAxes << " axes but only found " << axisCount << " axes."
177 << "Please configure the axes in the Config::ConfigureHardwareAxes function.";
178 throw std::runtime_error(message.str().c_str());
179 }
180 }
181 else
182 {
183 // Record the initial object counts to restore later
184 initialAxisCount = controller->AxisCountGet();
185 initialMotionCount = controller->MotionCountGet();
186
187 // Add phantom axes for the sample app if needed
188 if (numAxes > initialAxisCount)
189 {
190 controller->AxisCountSet(numAxes);
191 }
192
193 for (int i = 0; i < numAxes; i++)
194 {
195 ConfigurePhantomAxis(controller, i);
196 }
197 }
198 }
199
200
206 void Cleanup(MotionController* controller)
207 {
208 // Restore the object counts to the original values
209 if (initialAxisCount != -1) { controller->AxisCountSet(initialAxisCount); }
210 if (initialMotionCount != -1) { controller->MotionCountSet(initialMotionCount); }
211
212 // Reset the object counts
213 initialAxisCount = -1;
215 }
216
217};
218
219
220#endif // CONFIG_H
Set the Amp Fault action.
Set the motor type.
@ RSINetworkStateSHUTDOWN
Definition rsienums.h:628
EtherCAT not yet started.
Definition rsienums.h:622
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIMotorTypePHANTOM
Definition rsienums.h:1455
[ConfigurePhantomAxis]
Definition config.h:139
Definition config.h:147
Definition config.h:81
[GetCreationParameters]
Definition config.h:110
Path to the RMP.rta file (usually the RapidSetup folder).
Definition config.h:34
[SetupController]
Definition config.h:206
void ConfigureHardwareAxes(MotionController *controller)
Configures the hardware axes according to user specified implementation.
Definition config.h:47
This namespace provides static methods and constants for user configuration in RMP applications....
Definition config.h:25
(Linux only) CPU core to use. This should be an isolated core.
Definition config.h:37
Initial motion count to restore later (-1 indicates it has not been set).
Definition config.h:140
Name of the NIC to use for the EtherCAT network (not needed for running on phantom axes).
Definition config.h:35
Definition config.h:40
(Windows only) INtime node name. Use "" for default node.
Definition config.h:36
Definition helpers.h:87
[CheckErrors]
Definition helpers.h:128
char NodeName[PathLengthMaximum]
[Windows/INtime] Indicate the INtime node on which the RMP and RMPNetwork processes run.
Definition rsi.h:1045
Definition rsi.h:978
int32_t CpuAffinity
Definition rsi.h:1065
char NicPrimary[PathLengthMaximum]
Primary EtherCAT Network Interface (NIC) name.
Definition rsi.h:1019
Definition rsi.h:888
Definition rsi.h:872
