◆ NetworkStart()
void NetworkStart ( MotionController * controller)
controllerPointer to the MotionController to start the network on.
Exceptions
std::runtime_errorThrown if the network does not reach the OPERATIONAL state.
Code Snippet
// Initialize the Network
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started already.
controller->NetworkStart(); // If not. Initialize The Network. (This can also be done from RapidSetup Tool)
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateOPERATIONAL) // Check if network is started again.
RSINetworkStartError startError = controller->LastNetworkStartErrorGet();
std::cout << "Network start error: " << NetworkStartErrorName(startError)
<< " (" << static_cast<int>(startError) << ")" << std::endl;
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error starting the network, read the network log messages
CheckErrors [NetworkStart]
_helpers.cs, config.h, and helpers.h.
Definition at line 128 of file helpers.h.
