Motion: Multi-Axis
Learn how to use multi-axis motion in C#.
In this page:
📜 Multi-Axis Velocity Motion
Learn how to update Multi-Axis Velocity 📖 synchronously and on the fly. This sample demonstrates updating multi-axis velocities at a rate of ~2ms. Before running this sample app: 1) Configure your Multi-Axis on RapidSetup, 2) Adjust your Limits and Action for all axes.
/* This sample demonstrates updating a multi-axis velocity synchronously and on the fly.
It can update velocities at a rate of ~2ms.
1. Make sure to configure your Multi-Axis on RapidSetup.
2. Make sure to adjust your Limits and Action for all axes.
using System.Threading;
Console.WriteLine("📜 MultiAxis Motion: Velocity");
const int CYCLES = 3; // how many times to update the velocity
// get axes
Helpers.CheckErrors(axis0);
Helpers.CheckErrors(axis1);
Axis axis2 = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(axis2);
// get multiaxis (motion supervisor number is equal to number of axes because indexing starts at 0)
Helpers.CheckErrors(multi);
// remove any existing axes
multi.AxisRemoveAll();
// add axes to multiaxis
multi.AxisAdd(axis0);
multi.AxisAdd(axis1);
multi.AxisAdd(axis2);
// prepare for motion
multi.Abort();
multi.ClearFaults();
// define motion parameters
double[] accelerations = [20, 20, 20];
double[] velocities = [0, 0, 0];
Random rnd = new Random(); // for generating random velocities
// update velocities on the fly
for (int i = 0; i < CYCLES; i++)
// generate random velocities for all axes
velocities[0] = rnd.Next(1, 16);
velocities[1] = rnd.Next(1, 16);
velocities[2] = rnd.Next(1, 16);
Console.WriteLine($"Cycle {i + 1}: Velocities = [{velocities[0]}, {velocities[1]}, {velocities[2]}]");
// move multiaxis (this will also update the move on the fly)
multi.MoveVelocity(velocities, accelerations);
// short delay before next iteration
Thread.Sleep(2000);
// clean up
Helpers.AbortMotionObject(multi); // stop motion on all axes
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
void AxisRemoveAll()
Velocity move.
void AxisAdd(Axis *axis)
Definition rsi.h:12226
📜 Multi-Axis Point-to-Point Motion
Learn how to perform S-Curve Motion 📖 for multiple axes simultaneously. Demonstrates both trapezoidal and S-curve motion profiles using the MultiAxis object.
/* This sample demonstrates both trapezoidal and S-curve point-to-point motion profiles for multi-axis motion.
The MultiAxis object coordinates the motion of multiple axes simultaneously.
Console.WriteLine("📜 MultiAxis Motion: Point to Point");
Console.WriteLine($"Axis Count: {controller.AxisCountGet()}");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 2, minRequiredSampleMultiAxisCount: 1);
// get axes
// get multiaxis (indexed by motion supervisor number, indexing starts at 0)
// Use MotionAttributeMaskOnSet and MotionAttributeMaskOffSet to enable/disable synchronization features
// Both SYNC_START and SYNC_END are enabled by default
// See our Motion: Point-to-Point documentation for more details
// multi.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskSYNC_START);
// multi.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskSYNC_END);
multi.Abort(); // stop any existing motion
// Reset axes and position
axis0.PositionSet(0);
axis1.PositionSet(0);
double[] positions1 = [ 5, 10 ]; // first set of positions
double[] positions2 = [ 15, 15 ]; // second set of positions
double[] velocities1 = [ 10, 10 ]; // velocities for first move
double[] velocities2 = [ 10, 10 ]; // velocities for second move
double[] accelerations = [ 20, 20 ]; // accelerations for both axes
double[] decelerations = [ 20, 20 ]; // decelerations for both axes
double[] jerkPercent = [ 50, 50 ]; // jerk percent for s-curve motion
// move using s-curve motion profile
Console.WriteLine($"\nMove 1 (S-Curve): Positions = [{positions1[0]}, {positions1[1]}]");
multi.MoveSCurve(positions1, velocities1, accelerations, decelerations, jerkPercent);
multi.MotionDoneWait(); // wait for motion to complete
Console.WriteLine($"Axis 0 CommandPosition: {axis0.CommandPositionGet()} (expected: {positions1[0]})");
Console.WriteLine($"Axis 1 CommandPosition: {axis1.CommandPositionGet()} (expected: {positions1[1]})");
// move using trapezoidal motion profile
Console.WriteLine($"\nMove 2 (Trapezoidal): Positions = [{positions2[0]}, {positions2[1]}]");
multi.MoveTrapezoidal(positions2, velocities2, accelerations, decelerations);
Console.WriteLine($"Axis 0 CommandPosition: {axis0.CommandPositionGet()} (expected: {positions2[0]})");
Console.WriteLine($"Axis 1 CommandPosition: {axis1.CommandPositionGet()} (expected: {positions2[1]})");
Console.WriteLine("\nMulti-axis point-to-point motion complete.");
Point-to-point S-Curve Move.
