PathState | PathStateGet ()=0 |
| Gets the path state of the Robot.
bool | PathStateWait (PathState stateWaitFor, uint64_t timeoutMilliseconds)=0 |
| Waits for a specific path state.
bool | PathStateWaitChange (PathState stateWaitChange, uint64_t timeoutMilliseconds)=0 |
| Waits for the path state to not be the specified state.
uint64_t | MotionCounterGet ()=0 |
| Gets the current motion counter of the Robot.
void | MotionCounterWait (uint64_t motionCount, uint64_t timeoutMilliseconds)=0 |
| Waits for the counter increment by the specified amount.
uint64_t | SampleCounterGet ()=0 |
| Gets the current sample counter of the Robot's main execution thread.
void | SampleCounterWait (uint64_t sampleCount, uint64_t timeoutMilliseconds)=0 |
| Waits for the sample counter of the Robot's main execution thread to incremented by the specified amount.
bool | IsRunning ()=0 |
| Returns whether or not the robot is in motion (from executor or other source). Can be used to determine if safe to command a new move.
bool | PathIsRunning ()=0 |
| Returns whether or not a planned path is being executed. All G-Code gets converted to path. Joint moves aren't path moves.
bool | MotionDoneGet ()=0 |
| Check to see if motion is done and settled.
uint64_t | MotionDoneWait ()=0 |
| Waits for a move to complete.
uint64_t | MotionDoneWait (uint64_t timeoutMilliseconds)=0 |
bool | HasError ()=0 |
| Get the error state of the underlying Trajectory Executor.
const char *const | ErrorMessageGet ()=0 |
| Get the text of any error in the Trajectory Executor.
void | Resume ()=0 |
| Resume an axis.
void | Stop ()=0 |
| Stop an axis.
void | EStopAbort ()=0 |
| E-Stop, then abort an axis.
void | Abort ()=0 |
| Abort an axis.
void | AmpEnableSet (bool enable, int32_t ampActiveTimeoutMilliseconds)=0 |
| Enable all amplifiers.
void | EStop ()=0 |
| Commands a joint EStop and clears the loaded moves.
void | ClearFaults ()=0 |
| Clears the MultiAxis fault then the Robot's error bit.
Pose | ActualPoseGet (LinearUnits units=LinearUnits::None)=0 |
| Get the current actual pose of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use Quaternion::ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
RobotPosition | ActualPositionGet (LinearUnits units=LinearUnits::None)=0 |
| Get the current actual position of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use Quaternion::ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
Pose | CommandPoseGet (LinearUnits units=LinearUnits::None)=0 |
| Get the current commanded pose of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use Quaternion::ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
RobotPosition | CommandPositionGet (LinearUnits units=LinearUnits::None)=0 |
| Get the current commanded position of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use Quaternion::ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
RapidVector< double > | JointsActualPositionsGet ()=0 |
| Get the actual positions of the axes in the underlying MultiAxis.
RapidVector< double > | JointsCommandPositionsGet ()=0 |
| Get the commanded positions of the axes in the underlying MultiAxis.
RapidVector< double > | InverseKinematics (Pose pose)=0 |
| Run the given pose through the current inverse kinematic model to see the joint positions the robot would choose.
RapidVector< double > | InverseKinematics (RobotPosition pose)=0 |
Pose | ForwardKinematics (const RapidVector< double > &joints)=0 |
| Get the Actual pose of the robot from the the joint MultiAxis positions.
RobotPosition | ForwardKinematicsPosition (const RapidVector< double > &joints)=0 |
| Get the Actual position of the robot from the the joint MultiAxis positions.
const KinematicModel & | ModelGet ()=0 |
| Get the model this robot was created with.
void | EndEffectorTransformSet (const Pose &transform)=0 |
| Transform that defines the control point relative to the end end of the current kinematic model For example if you have a suction cup EoAT that is 0.15 meters from the mounting point of your robotic arm you could call this method with Pose(0,0,.15) to define the tool z offset.
void | EndEffectorTransformSet (const RobotPosition &transformPosition)=0 |
| Transform that defines the control point relative to the end end of the current kinematic model with a RobotPosition.
void | OriginTransformSet (const Pose &transform)=0 |
| Transform that defines the origin of the robot in the world. For example if you have a gantry that is homed but what the command MoveAbsolute(0,0,0) to put you at 4 in the x axis, you could call this method with Pose(4,0,0)
void | OriginTransformSet (const RobotPosition &transformPosition)=0 |
| Transform that defines the origin of the robot in the world as a RobotPosition.
const RobotPosition & | EndEffectorTransformGet ()=0 |
| End of Robot to TCP.
const RobotPosition & | OriginTransformGet ()=0 |
| Offset for the origin location.
const double | ScaleFactorBetweenUnitsGet (LinearUnits from, LinearUnits to)=0 |
| Gets scaling for scale factor needed to convert from -> to units by multiplying
const double | ScaleFactorBetweenUnitsGet (RotationalUnits from, RotationalUnits to)=0 |
void | MoveAbsolute (const Pose &absolutePose)=0 |
| Executes a point-to-point absolute motion in cartesian space.
void | MoveRelative (const Pose &relativePose)=0 |
| Executes a point-to-point motion relative to the current end effector Pose.
void | PathClear ()=0 |
| Clears out all loaded lines and arcs from the path. Part of the PathMotion method group.
void | PathVelocitySet (double unitsPerSecond)=0 |
| Sets the target linear cartesian velocity for each move (UserUnits/second).
double | PathVelocityGet ()=0 |
| Gets the target velocity for the machine (UserUnits/second).
void | PathAccelerationSet (double unitsPerSecondSquared)=0 |
| Sets the target acceleration for the machine (UserUnits/second^2). Should be set appropriately based on your hardware.
double | PathAccelerationGet ()=0 |
| Gets the target acceleration for the machine (UserUnits/second^2).
void | PathProgrammingModeSet (PathMode mode)=0 |
| Sets the programming mode (Relative/Absolute).
PathMode | PathProgrammingModeGet ()=0 |
| Gets the programming mode (Relative/Absolute).
void | PathArc (const Pose &target, double radius, RotationDirection direction)=0 |
| Appends an arc on to the current on the PathPlaneGet() plane XY by default.
void | PathArc (const RobotPosition &target, double radius, RotationDirection direction)=0 |
void | PathArc (const Pose &target, const Vector3d ¢er, RotationDirection direction)=0 |
| Appends an arc on to the current path with end pose about a specific center point.
void | PathArc (const RobotPosition &RobotPosition, const Vector3d ¢er, RotationDirection direction)=0 |
void | PathLine (const Pose &target)=0 |
void | PathLine (const RobotPosition &position)=0 |
void | PathPlaneSet (Plane plane)=0 |
| Sets the plane for the purposes of ambiguous cases (arcs >= 180deg). Last set plane or XY plane is default.
Plane | PathPlaneGet ()=0 |
| Gets the plane some arcs will be forced to be on.
void | PathLinearScalingSet (double scaleFactor)=0 |
| Sets scaling between the input to path motion and output of path motion to the kinematic model.
double | PathLinearScalingGet () const =0 |
| Gets scaling between input to path motion and output of path motion to the kinematic model.
void | PathUnitsSet (LinearUnits units)=0 |
| Defines the units Cartesian Path Motion is in.
LinearUnits | PathUnitsGet () const =0 |
| Gets the units of path motion.
double | PathProcessLoadedMoves ()=0 |
| Processes our loaded moves. Used internally and to check whether loaded moves are valid, and must be called before both PathPlannedPositionsGet and PathDurationGet.
RapidVector< RobotPosition > | PathPlannedPositionsGet (uint64_t startFrame, uint64_t frameCount)=0 |
| Get Positions (see RobotPosition) representing the planned motion in cartesian space that will happen when run is called.
double | PathDurationGet ()=0 |
| Get total (seconds) duration of the planned motion that will happen when run is called.
void | Run ()=0 |
| Run the loaded path lines/arcs. The behavior is non-blocking. Use Robot.MotionDoneWait() to block.
uint32_t | MotionFrameBufferSizeGet ()=0 |
| Gets the TrajectoryExecutor's buffer size in frames, one frame is used per RMP sample period.
const char *const | VersionGet () |
| Get the RSI RapidCode version.
int32_t | MpiVersionMajor () |
| Get the major MPI version.
int32_t | MpiVersionMinor () |
| Get the minor MPI version.
int32_t | MpiVersionRelease () |
| Get the release MPI version.
int32_t | RSIVersionMajor () |
| Get the major RSI version.
int32_t | RSIVersionMinor () |
| Get the minor RSI version.
int32_t | RSIVersionMicro () |
| Get the micro RSI version.
int32_t | RSIVersionPatch () |
| Get the patch RSI version.
int32_t | NumberGet () |
| Get the zero-based index of this object.
int32_t | ErrorLogCountGet () |
| Get the number of software errors in the error log.
const RsiError *const | ErrorLogGet () |
| Get the next RsiError in the log.
void | ErrorLogClear () |
| Clear the error log.
void | ThrowExceptions (bool state) |
| Configure a class to throw exceptions.
const char *const | RsiErrorMessageGet (RSIErrorMessage msg) |
| Get the RSI-specific error message text for a specific RSIErrorMessage.
const char *const | ErrorMessageGet (RSIErrorMessage msg) |
| Get the detailed text message for an RSIErrorMessage.
bool | WarningMsgCheck (RSIErrorMessage msg) |
| Check to see if an RSIErrorMessage is a warning (true) or not (false).
void | Trace (bool state) |
| Enables/Disables trace output.
void | TraceMaskOnSet (RSITrace maskOn) |
| Turn on a particular trace output mask.
bool | TraceMaskOnGet (RSITrace maskOn) |
| Check to see if a particular trace output mask is turned on.
void | TraceMaskOffSet (RSITrace maskOff) |
| Turn off a particular trace output mask.
void | TraceMaskClear () |
| Clear the trace output mask.
void | TraceFileSet (const char *const fileName) |
| Channels Tracing messages to specified file.
void | TraceFileClose () |
| Stops Logging to the file.
void | TraceInjectMessage (RSITrace traceLevel, const char *const message) |
| Add a message to the Trace Log.
