MotionHold.cs
39using RSI.RapidCode.dotNET; // Import our RapidCode Library.
40using NUnit.Framework;
41using System;
42
43#if DOXYGEN // RSI internal documentation use only
44using RSI.RapidCode;
45#endif
46
48[TestFixture]
49[Category("Software")]
50public class MotionHold : SampleAppTestBase
51{
52 public void MotionHoldByDigitalInput()
53 {
55 // Constants
56 const int DIGITAL_INPUTS_PDO_INDEX = 3; // Specify the pdo inputs index that represent digital inputs.
57
58 // SET MOTION HOLD
59 ulong inputAddress = controller.NetworkInputAddressGet(DIGITAL_INPUTS_PDO_INDEX); // Get host address using the PDO Input Index of Digital Inputs.
60
61 axis.MotionHoldTypeSet(RSIMotionHoldType.RSIMotionHoldTypeCUSTOM); // Use TypeCUSTOM to hold execution based on a particular bit turning ON or OFF.
62 axis.MotionHoldUserAddressSet(inputAddress); // Specify the digital inputs host address. This address' value will be used to evaluate the motion hold condition.
63 axis.MotionHoldUserMaskSet(0x20000); // Specify the bit you want to mask/watch from the MotionHoldUserAddressSet' address value (this evaluates using a logic AND)
64 axis.MotionHoldUserPatternSet(0x20000); // Specify the bit value that will release the motion hold. (When this value is met, motion hold will be released)
65
66 axis.MotionAttributeMaskOnSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
67
68 axis.MoveRelative(10); // Command simple relative motion. (This motion will be HOLD by the condition above)
69 axis.MotionDoneWait(); // Wait for Motion to be completed.
70
71 axis.MoveRelative(10); // If motion attribute mask off has not been set, this motion will have same HOLD condition as previous move.
72 axis.MotionDoneWait(); // Wait for Motion to be completed.
73
74 axis.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD);// Set the HOLD motion attribute mask OFF. (This will clear any motion HOLDS that were set on this Axis)
75
76 axis.MoveRelative(10); // This motion will have no HOLD since the previous line has set the motion attribute mask OFF.
77 axis.MotionDoneWait(); // Wait for Motion to be completed.
78
79 // Abort and Clear Faults
80 axis.Abort();
81 axis.ClearFaults();
83 }
84
85 [Test]
86 public void MotionHoldByPosition()
87 {
89 // Constants
90 const double TRIGGER_POS = 1; // Specify the position that will be evaluted on triggering/releasing motion
91 const int MOVING_AXIS_TARGET = 10;
92 const int HOLDINGAXIS_TARGET = 2;
93
94 // Initialize RapidCode Objects
95 // Initiazlize Axes: holdingAxis and movingAxis
96 Axis holdingAxis = controller.AxisGet(Constants.HOLDING_AXIS_INDEX); // Initialize Axis Class. (Use RapidSetup Tool to see what is your axis number)
97 HelperFunctions.CheckErrors(holdingAxis); // [Helper Function] Check that the axis has been initialize correctly.
98
99 Axis movingAxis = controller.AxisGet(Constants.MOVING_AXIS_INDEX); // Initialize HoldAxis Class. (Use RapidSetup Tool to see what is your axis number)
100 HelperFunctions.CheckErrors(movingAxis); // [Helper Function] Check that the axis has been initialize correctly.
101
102 // SET UP MOTION HOLD // Condition/Configuration to the Axis(movingAxis) that will hold Motion and its Position that will trigger/release motion
103 holdingAxis.MotionHoldTypeSet(RSIMotionHoldType.RSIMotionHoldTypeAXIS_COMMAND_POSITION); // Use RSIMotionHoldTypeAXIS_ACTUAL_POSITION if it is not Phantom Axis.
104 holdingAxis.MotionHoldAxisNumberSet(movingAxis.NumberGet()); // Specify motion hold to the Axis(movingAxis) whose position will hold the motion of holdingAxis.
105 holdingAxis.MotionHoldAxisPositionSet(TRIGGER_POS); // Specify motion hold position which is the movingAxis's position(need to multiply with USER_UNITS to get correct position value) to trigger/release the motion of holdingAxis.
106 holdingAxis.MotionHoldAxisLogicSet(RSIUserLimitLogic.RSIUserLimitLogicGE); // Specify the logic condition that will be evaluated to trigger/release motion based on the SET POSITION(USER_UNITS * TRIGGER_POS).In this case, GT(Greater than or Equal to) motion hold position limit to release
107
108 // SET MOTION HOLD ON
109 holdingAxis.MotionAttributeMaskOnSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
110 holdingAxis.MoveRelative(HOLDINGAXIS_TARGET); // Command simple relative motion(This motion will be hold by condition above until movingAxis's Position passes motion hold position limit)
111
112 // Release MOTION HOLD
113 movingAxis.MoveRelative(MOVING_AXIS_TARGET); // Move movingAxis.MovingAxis's position reaches its MotionHold Position limit(in this case, limit is 5). It will trigger/release motion on holdingAxis (holidingAxis will move relatively 10).
114 movingAxis.MotionDoneWait();
115 holdingAxis.MotionDoneWait();
117
119 Assert.That(holdingAxis.CommandPositionGet(), Is.EqualTo(HOLDINGAXIS_TARGET));
120 }
121
122 [Test]
123 public void MotionHoldBySoftwareAddress()
124 {
126 // Constants
127 UInt64 SOFTWARE_ADDRESS = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 1);
128 int WAIT_TIME = 10;
129 int MOVE_DIST = 2;
130
131 // SET MOTION HOLD ON AVAILABLE SOFTWARE ADDRESS
132 axis.MotionHoldTypeSet(RSIMotionHoldType.RSIMotionHoldTypeCUSTOM); // Use TypeCUSTOM to hold execution based on a particular bit turning ON or OFF.
133 axis.MotionHoldUserAddressSet(SOFTWARE_ADDRESS); // Specify the available hostAddress . This address' value will be used to evaluate the motion hold condition.
134 axis.MotionHoldUserMaskSet(0x1); // Specify the bit you want to mask/watch from the MotionHoldUserAddressSet' address value (this evaluates using a logic AND)
135 axis.MotionHoldUserPatternSet(0x1); // Specify the bit value that will release the motion hold. (When this value is met, motion hold will be released)
136
137 // Check the condition to be false at first
138 if (controller.MemoryGet(SOFTWARE_ADDRESS) != 0x0) // Check Available host address value is mask to be false (in this case 0x0)
139 {
140 controller.MemorySet(SOFTWARE_ADDRESS, 0x0); // if not, mask it to false value/condition (in this case 0x0)
141 }
142
143 // SET MOTION HOLD
144 axis.MotionAttributeMaskOnSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask ON. (This initializes the HOLD on a particular motion)
145
146 axis.MoveRelative(MOVE_DIST); // Command simple relative motion. (This motion will be HOLD by the condition above)
147 System.Threading.Thread.Sleep(WAIT_TIME); // Sleep for (x) miliseconds before releasing motion hold.
148
149 var expectedCmdPos1 = axis.CommandPositionGet(); // Sould be 0
150
151 // RELEASE MOTION HOLD
152 controller.MemorySet(SOFTWARE_ADDRESS, 0x1); // Release Motion Hold by specifying the host address value to SET Condition (in this case 0x10000)
153 axis.MotionDoneWait(); // Wait for motion to be done
154 controller.MemorySet(SOFTWARE_ADDRESS, 0x0); // Specify host address value back to false value/condition (in this case 0x0)
155
156 var expectedCmdPos2 = axis.CommandPositionGet(); // Should be MOVE_DIST
157
158 // COMMAND MOTION AGAIN
159 axis.MoveRelative(MOVE_DIST); // Command simple relative motion again. (This motion will be HOLD by the condition above)
160 System.Threading.Thread.Sleep(WAIT_TIME); // Sleep for (x) miliseconds before releasing motion hold.
161
162 // RELEASE MOTION HOLD
163 controller.MemorySet(SOFTWARE_ADDRESS, 0x1); // Release Motion Hold by specifying the host address value to SET Condition (in this case 0x1)
164 axis.MotionDoneWait(); // Wait for motion to be done
165 controller.MemorySet(SOFTWARE_ADDRESS, 0x0); // Specify host address value back to false value/condition (in this case 0x0)
166
167 // CLEAR MOTION HOLD
168 axis.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD); // Set the HOLD motion attribute mask OFF. (This will clear any motion HOLDS that were set on this Axis)
169
170 axis.MoveRelative(MOVE_DIST); // This motion will have no HOLD since the previous line has set the motion attribute mask OFF.
171 axis.MotionDoneWait(); // Wait for Motion to be completed.
173
175 Assert.That(expectedCmdPos1, Is.EqualTo(0));
176 Assert.That(expectedCmdPos2, Is.EqualTo(MOVE_DIST));
177 }
178}
double CommandPositionGet()
Definition rsi.h:5870
int32_t MemoryGet(uint64_t address)
Read controller memory.
uint64_t NetworkInputAddressGet(int32_t index)
Sets the Axis position.
int32_t MotionDoneWait()
Set the motion hold type.
int32_t NumberGet()
Get the axis number.
RSIUserLimitLogic
Definition rsienums.h:646
RSIMotionAttrMask
Definition rsienums.h:1060
RSIMotionHoldType
Definition rsienums.h:1095
