_helpers.cs
1using RSI.RapidCode; // RSI.RapidCode.dotNET;
2
4public static class Helpers
5{
15 public static void CheckErrors(RapidCodeObject rsiObject)
16 {
17 var hasErrors = false;
18 var errorStrBuilder = new System.Text.StringBuilder();
19
20 while (rsiObject.ErrorLogCountGet() > 0)
21 {
22 // get error
23 RsiError rsiError = rsiObject.ErrorLogGet();
24
25 // get message
26 var errorMsg = rsiError.isWarning ? $"WARNING: {rsiError.Message}" : $"ERROR: {rsiError.Message}";
27 errorStrBuilder.AppendLine(errorMsg);
28
29 // set flag
30 hasErrors = !rsiError.isWarning;
31 }
32
33 if (hasErrors)
34 throw new Exception(errorStrBuilder.ToString());
35 }
36
37
47 public static void NetworkStart(MotionController controller)
48 {
49 // check if network is started already
50 if (controller.NetworkStateGet() != RSINetworkState.RSINetworkStateOPERATIONAL)
51 {
52 Console.WriteLine("Starting Network..");
53
54 // if not started, initialize the network
55 controller.NetworkStart();
56 }
57
58 // check if network is started again
59 if (controller.NetworkStateGet() != RSINetworkState.RSINetworkStateOPERATIONAL)
60 {
61 RSINetworkStartError startError = controller.LastNetworkStartErrorGet();
62 Console.WriteLine($"Network start error: {startError} ({(int)startError})");
63
64 // read network log messages
65 int messagesToRead = controller.NetworkLogMessageCountGet();
66
67 // print all the messages to help figure out the problem
68 for (int i = 0; i < messagesToRead; i++)
69 Console.WriteLine(controller.NetworkLogMessageGet(i));
70
71 throw new SystemException("Expected OPERATIONAL state but the network did not get there.");
72 }
73 else
74 {
75 Console.WriteLine("Network Started");
76 }
77 }
78
79
89 public static void NetworkShutdown(MotionController controller)
90 {
91 // check if the network is already shutdown
92 if (controller.NetworkStateGet() == RSINetworkState.RSINetworkStateUNINITIALIZED ||
93 controller.NetworkStateGet() == RSINetworkState.RSINetworkStateSHUTDOWN)
94 return;
95
96 // shutdown the network
97 Console.WriteLine("Shutting down the network..");
98 controller.NetworkShutdown();
99
100 // check if the network is shutdown
101 var networkState = controller.NetworkStateGet();
102 if (networkState != RSINetworkState.RSINetworkStateUNINITIALIZED &&
103 networkState != RSINetworkState.RSINetworkStateSHUTDOWN)
104 {
105 // some kind of error shutting down the network, read the network log messages
106 int messagesToRead = controller.NetworkLogMessageCountGet();
107
108 // print all the messages to help figure out the problem
109 for (int i = 0; i < messagesToRead; i++)
110 Console.WriteLine(controller.NetworkLogMessageGet(i));
111
112 throw new SystemException("Expected SHUTDOWN state but the network did not get there.");
113 }
114 else
115 {
116 Console.WriteLine("Network Shutdown");
117 }
118 }
119
120
129 public static void ControllerSetup(MotionController controller)
130 {
131 NetworkShutdown(controller);
132
133 // reset the controller to ensure it is in a known state
134 controller.Reset();
135
136 NetworkStart(controller);
137 }
138
139
147 public static void PhantomAxisReset(Axis phantomAxis)
148 {
149 if (phantomAxis.MotorTypeGet() != RSIMotorType.RSIMotorTypePHANTOM)
150 {
151 throw new Exception(@$"Axis {phantomAxis.NumberGet()} is not configured as a phantom axis.
152 Please ensure the axis is set to phantom before calling PhantomAxisConfigure.");
153 }
154
155 // abort any motion
156 AbortMotionObject(phantomAxis);
157
158 // disable all limits (not used for phantom axes)
159 phantomAxis.ErrorLimitActionSet(RSIAction.RSIActionNONE);
160 phantomAxis.HardwareNegLimitActionSet(RSIAction.RSIActionNONE);
161 phantomAxis.HardwarePosLimitActionSet(RSIAction.RSIActionNONE);
162 phantomAxis.HomeActionSet(RSIAction.RSIActionNONE);
163 phantomAxis.SoftwareNegLimitActionSet(RSIAction.RSIActionNONE);
164 phantomAxis.SoftwarePosLimitActionSet(RSIAction.RSIActionNONE);
165
166 // set position tolerances to max value for immediate MotionDone
167 double POSITION_TOLERANCE_MAX = Double.MaxValue / 10.0;
168 phantomAxis.PositionToleranceCoarseSet(POSITION_TOLERANCE_MAX);
169 phantomAxis.PositionToleranceFineSet(POSITION_TOLERANCE_MAX);
170
171 // set sample apps default motion parameters
172 phantomAxis.UserUnitsSet(1);
173 phantomAxis.DefaultVelocitySet(100);
174 phantomAxis.DefaultAccelerationSet(1000);
175 phantomAxis.DefaultDecelerationSet(1000);
176 phantomAxis.DefaultJerkPercentSet(0);
177 phantomAxis.PositionSet(0);
178 }
180
181
189 /// @internal @[AbortMotionObject]
190 public static void AbortMotionObject(RapidCodeMotion motionObject)
191 {
192 motionObject.EStopAbort();
193 motionObject.MotionDoneWait();
194 motionObject.ClearFaults();
195
196 // check for idle state
197 if (motionObject.StateGet() != RSIState.RSIStateIDLE)
198 {
199 RSISource source = motionObject.SourceGet(); // get state source enum
200 string errorMsg = @$"Axis or MultiAxis {motionObject.NumberGet()} failed to enter IDLE state after aborting.
201 The source of the axis error is: {motionObject.SourceNameGet(source)}";
202 throw new Exception(errorMsg);
203 }
204 }
206
207 /*
208 @brief Ensures relationship between USE_HARDWARE constant and network status and throws if mismatch found.
209 @param controller Pointer to the MotionController to check.
210 @exception Exception Thrown if mismatch found between USE_HARDWARE constant and network status, or user cancels on warning.
211 @par Code Snippet
212 @snippet _helpers.cs VerifyHardwareUsage
213 */
215 public static void VerifyHardwareUsage(MotionController controller)
216 {
217 const bool USE_HARDWARE = Constants.USE_HARDWARE; // User must set this in _constants.cs
218
219 bool networkIsOperational = controller.NetworkStateGet() == RSINetworkState.RSINetworkStateOPERATIONAL;
220
221 if (USE_HARDWARE && !networkIsOperational)
222 {
223 throw new Exception("USE_HARDWARE is set to true, but the network is not operational. " +
224 "Please properly configure your hardware or run _setup.cs.");
225 }
226 else if (!USE_HARDWARE && networkIsOperational)
227 {
228 throw new Exception("USE_HARDWARE is set to false, but the network is operational. " +
229 "Please ensure you are not connected to real hardware, or set USE_HARDWARE in _constants.cs to true.");
230 }
231 else if (!USE_HARDWARE && !networkIsOperational)
232 {
233 Console.WriteLine("Running with phantom axes as expected.");
234 }
235 else
236 {
237 // State running with hardware and require 'y' input from user to continue or any other key to abort
238 Console.WriteLine("Caution: You are currently running with hardware. " +
239 "Do not continue unless you have configured your axes through _setup.cs or another tool!");
240 Console.Write("Press 'y' to continue: ");
241 var input = Console.ReadKey();
242 Console.WriteLine(); // Move to next line after key press
243
244 if (input.KeyChar != 'y' && input.KeyChar != 'Y')
245 {
246 throw new Exception("User chose not to continue with hardware operation.");
247 }
248 }
249 }
251
252 /*
253 @brief Verifies that the AXIS_COUNT constant matches the controller's axis count, then validates minimum axis and MultiAxis requirements. Outputs comparison information to console.
254 @param controller The MotionController object to verify.
255 @param minRequiredSampleAxisCount Minimum number of axes required by the sample application (default: 1).
256 @param minRequiredSampleMultiAxisCount Minimum number of MultiAxis objects required by the sample application (default: 0).
257 @exception Exception Thrown if AXIS_COUNT doesn't match controller axis count, if minimum axis count is not met, or if minimum MultiAxis count (calculated as MotionCount minus AxisCount) is not met.
258 @par Code Snippet
259 @snippet _helpers.cs VerifyAxisCount
260 */
262 public static void VerifyAxisCount(MotionController controller, int minRequiredSampleAxisCount = 1, int minRequiredSampleMultiAxisCount = 0)
263 {
264 int controllerAxisCount = controller.AxisCountGet();
265 int AXIS_COUNT = Constants.AXIS_COUNT;
266
267 // Verify AXIS_COUNT matches controller AxisCountGet()
268 if (controllerAxisCount != AXIS_COUNT)
269 {
270 // Axis count mismatch. Throw exception to stop execution
271 throw new Exception($"Controller axis count ({controllerAxisCount}) does not match intended AXIS_COUNT ({AXIS_COUNT}). " +
272 "Please ensure AXIS_COUNT in _constants.cs matches your number of hardware axes, then run _setup.cs or another tool " +
273 "to configure your hardware.");
274 }
275
276 // Verify minimum axis count
277 // Check against AXIS_COUNT here because if we get here we know controllerAxisCount == AXIS_COUNT
278 if (AXIS_COUNT < minRequiredSampleAxisCount)
279 {
280 throw new Exception($"This sample requires at least {minRequiredSampleAxisCount} " +
281 $"{(minRequiredSampleAxisCount == 1 ? "axis" : "axes")}, but AXIS_COUNT is only {AXIS_COUNT}. " +
282 $"Update your AXIS_COUNT in _constants.cs to meet the minimum requirement.");
283 }
284
285 // Verify minimum MultiAxis count
286 if (controller.MotionCountGet() - controllerAxisCount < minRequiredSampleMultiAxisCount)
287 {
288 throw new Exception($"This sample requires at least {minRequiredSampleMultiAxisCount} " +
289 $"MultiAxis object{(minRequiredSampleMultiAxisCount == 1 ? "" : "s")}. " +
290 "Please add more motion supervisors.");
291 }
292 }
293
294}
Aborts motion on the given RapidCodeMotion object (Axis or MultiAxis), waits for motion to stop,...
Definition _helpers.cs:189
Shuts down the network communication for the given MotionController.
Definition _helpers.cs:89
Definition _helpers.cs:15
Configures a phantom axis on the controller.
Definition _helpers.cs:147
Definition _helpers.cs:47
Definition _helpers.cs:129
RSIMotorType MotorTypeGet()
Get the motor type.
void DefaultVelocitySet(double velocity)
Set the default velocity in UserUnits.
void DefaultJerkPercentSet(double jerkPercent)
Set the default jerk percent.
int32_t AxisCountGet()
int32_t MotionCountGet()
RSIState StateGet()
RSISource SourceGet()
void EStopAbort()
E-Stop, then abort an axis.
The RapidCodeMotion interface is implemented by Axis and MultiAxis .
Definition rsi.h:5505
int32_t ErrorLogCountGet()
Definition rsi.h:180
Definition rsi.h:111
bool isWarning
Definition rsi.h:120
Definition rsienums.h:621
Definition rsienums.h:1256
RSIMotorType
Motor Type.
Definition rsienums.h:1452
Network start errors.
Definition rsienums.h:715
RSISource
Definition rsienums.h:1151
[CheckErrors]
Definition helpers.h:128
void NetworkShutdown(MotionController *controller)
[NetworkStart]
Definition helpers.h:167
