◆ NetworkShutdown()
void NetworkShutdown ( MotionController * controller)
Shuts down the network communication for the given MotionController.
controllerPointer to the MotionController to shut down the network on.
Exceptions
std::runtime_errorThrown if the network does not reach the SHUTDOWN or UNINITIALIZED state.
Code Snippet
void NetworkShutdown(MotionController *controller)
// Check if the network is already shutdown
if (controller->NetworkStateGet() == RSINetworkState::RSINetworkStateUNINITIALIZED ||
controller->NetworkStateGet() == RSINetworkState::RSINetworkStateSHUTDOWN)
return;
// Shutdown the network
controller->NetworkShutdown();
if (controller->NetworkStateGet() != RSINetworkState::RSINetworkStateUNINITIALIZED &&
controller->NetworkStateGet() != RSINetworkState::RSINetworkStateSHUTDOWN) // Check if the network is shutdown.
int messagesToRead = controller->NetworkLogMessageCountGet(); // Some kind of error shutting down the network, read the network log messages
else // Else, of network is shutdown.
CheckErrors [NetworkShutdown]
_helpers.cs, and helpers.h.
Definition at line 167 of file helpers.h.
