◆ PrintFooter()
void PrintFooter ( std::string sampleAppName,
int exitCode )
sampleAppNameThe name of the sample application to print in the footer.
exitCodeThe exit code of the sample application.
Code Snippet
std::cout << "\n----------------------------------------------------------------------------------------------------\n";
if (exitCode == 0)
std::cout << sampleAppName << " Sample App Completed Successfully\n";
std::cout << sampleAppName << " Sample App Failed with Exit Code: " << exitCode << "\n";
std::cout << "----------------------------------------------------------------------------------------------------\n" << std::endl;
[PrintFooter]
axis-configuration.cpp, calculate-acceleration-from-velocity.cpp, difference-of-position-user-limit.cpp, follow-sensor.cpp, hello-rttasks.cpp, helpers.h, phantom-axis.cpp, point-to-point.cpp, print-network-topology.cpp, print-rttasks-summary.cpp, record-performance.cpp, and starter-template.cpp.
Definition at line 221 of file helpers.h.
