UserLimitCommandPositionDirect.cs
Attention
See the following Concept pages for a detailed explanation of this sample: User Limits.
using NUnit.Framework;
using System;
[TestFixture]
[Category("Software")]
public class UserLimitCommandPositionDirect : StaticMemoryTestBase
// Constants
const int AXIS_COUNT = 1;
const int USER_LIMIT_FIRST = 0; // Specify which user limit to use.
const RSIUserLimitLogic LOGIC = RSIUserLimitLogic.RSIUserLimitLogicEQ; // Logic for input value comparison.
const RSIUserLimitTriggerType TRIGGER_TYPE = RSIUserLimitTriggerType.RSIUserLimitTriggerTypeSINGLE_CONDITION; // Choose the how the condition (s) should be evaluated.
const RSIAction ACTION = RSIAction.RSIActionTRIGGERED_MODIFY; // Choose the action you want to cause when the User Limit triggers.
const int DURATION = 0; // Enter the time delay before the action is executed after the User Limit has triggered.
const bool ONE_SHOT = true; // if true, User Limit will only trigger ONCE
// User Limit Interrupt constants
const int TC_COMMAND_POSITION_INDEX = 2;
const int TC_ACTUAL_POSITION_INDEX = 3;
public void UserLimitCommandPositionDirectSet()
// Some Necessary Pre User Limit Configuration
controller.AxisCountSet(AXIS_COUNT);
controller.UserLimitCountSet(USER_LIMIT_COUNT); // Set the amount of UserLimits that you want to use.
axis = CreateAndReadyAxis(Constants.AXIS_NUMBER); // Initialize your axis object.
axis.TriggeredModifyDecelerationSet(Constants.DECELERATION);
axis.TriggeredModifyJerkPercentSet(Constants.JERK_PERCENT);
// USER LIMIT CONDITION 0 (trigger on digital input)
controller.UserLimitConditionSet(USER_LIMIT_FIRST, 0, LOGIC, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeDIGITAL_INPUTS), 0x400000, 0x400000); // Set your User Limit Condition (1st step to setting up your user limit)
// controller.UserLimitOutputSet(USER_LIMIT_FIRST, RSIDataType.RSIDataTypeDOUBLE, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTC_ACTUAL_POSITION), controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER), true);
controller.UserLimitConfigSet(USER_LIMIT_FIRST, TRIGGER_TYPE, ACTION, axis.NumberGet(), DURATION, ONE_SHOT); // Set your User Limit Configuration. (2nd step to setting up your user limit)
// CONDITION 0 (wait for first user limit to trigger)
controller.UserLimitConditionSet(USER_LIMIT_SECOND, 0, RSIUserLimitLogic.RSIUserLimitLogicEQ, controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSERLIMIT_STATUS, USER_LIMIT_FIRST), 1, 1);
// CONDITION 1 (AND wait for Axis command velcity = 0.0)
controller.UserLimitConditionSet(USER_LIMIT_SECOND, 1, RSIUserLimitLogic.RSIUserLimitLogicEQ, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY), 0.0);
// OUTPUT (copy value from UserBuffer to TC.CommandPosition when trigered)
//controller.UserLimitOutputSet(USER_LIMIT_SECOND, RSIDataType.RSIDataTypeDOUBLE, controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER), axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeTC_COMMAND_POSITION), true);
controller.UserLimitConfigSet(USER_LIMIT_SECOND, RSIUserLimitTriggerType.RSIUserLimitTriggerTypeCONDITION_AND, RSIAction.RSIActionNONE, 0, 0, ONE_SHOT);
// get the Axis moving
axis.ClearFaults();
axis.AmpEnableSet(true);
axis.MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
ConfigureUserLimitInterrupts(USER_LIMIT_FIRST);
ConfigureUserLimitInterrupts(USER_LIMIT_SECOND);
// wait for (and print) interrupts
WaitForInterrupts();
public void ConfigureUserLimitInterrupts(int userLimitIndex)
controller.UserLimitInterruptUserDataAddressSet(userLimitIndex, COMMAND_POSITION_INDEX, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_POSITION));
controller.UserLimitInterruptUserDataAddressSet(userLimitIndex, ACTUAL_POSITION_INDEX, axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeACTUAL_POSITION));
public void WaitForInterrupts()
bool done = false;
int timeout_millseconds = 10;
while (!done)
RSIEventType eventType = controller.InterruptWait(timeout_millseconds);
Console.WriteLine("IRQ: " + eventType.ToString() + " at sample " + controller.InterruptSampleTimeGet());
switch (eventType)
Console.WriteLine("UserLimit " + controller.InterruptSourceNumberGet());
Console.WriteLine("CmdPos: " + controller.InterruptUserDataDoubleGet(COMMAND_POSITION_INDEX));
Console.WriteLine("ActPos: " + controller.InterruptUserDataDoubleGet(ACTUAL_POSITION_INDEX));
Console.WriteLine("TC.CmdPos: " + controller.InterruptUserDataDoubleGet(TC_COMMAND_POSITION_INDEX));
Console.WriteLine("TC.ActPos: " + controller.InterruptUserDataDoubleGet(TC_ACTUAL_POSITION_INDEX));
done = true;
default:
Configure a User Limit.
double InterruptUserDataDoubleGet(uint32_t userDataIndex)
int32_t InterruptSampleTimeGet()
int32_t NumberGet()
Get the axis number.
