◆ ErrorLimitActionSet()
void ErrorLimitActionSet ( RSIAction action)
ErrorLimitActionSet sets the action that will occur when the Error Limit Event triggers.
actionAction taken on Error Limit trigger. A RSIAction value.
Note:
Axis: Configuration
controller.AxisCountSet(controller.AxisCountGet() + 1); // Configure one additional axis to be used for the phantom axis
int axisNumber = controller.AxisCountGet() - 1; // Set the axis number to the last axis on the network (subtract one because the axes are zero indexed)
axis = controller.AxisGet(axisNumber); // Initialize Axis class
HelperFunctions.CheckErrors(axis); // [Helper Function] Check that the axis has been initialized correctly
axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // Set Error Limit Action.
axis.HardwareNegLimitActionSet(RSIAction.RSIActionNONE); // Set Hardware Negative Limit Action.
axis.HardwarePosLimitActionSet(RSIAction.RSIActionNONE); // Set Hardware Positive Limit Action.
axis.HomeActionSet(RSIAction.RSIActionNONE); // Set Home Action.
axis.SoftwareNegLimitActionSet(RSIAction.RSIActionNONE); // Set Software Negative Limit Action.
axis.SoftwarePosLimitActionSet(RSIAction.RSIActionNONE); // Set Software Positive Limit Action.
const double positionToleranceMax = Double.MaxValue / 10.0; // Reduce from max slightly, so XML to string serialization and deserialization works without throwing System.OverflowException
axis.PositionToleranceCoarseSet(positionToleranceMax); // Set Settling Coarse Position Tolerance to max value
axis.PositionToleranceFineSet(positionToleranceMax); // Set Settling Fine Position Tolerance to max value (so Phantom axis will get immediate MotionDone when target is reached)
axis.MotorTypeSet(RSIMotorType.RSIMotorTypePHANTOM); // Set the MotorType to phantom
Go to axis screen->Limits & Actions. In image below, ErrorLimitActionSet sets the action type shown in the Position Error box. It is currently set to ABORT.
  • Position Error = Command Position - Actual Position
  • For safety reasons, you may want to set this to ABORT event.
ErrorLimitActionGet
AxisConfig.cs, Homing.cs, MultiAxisMotion.cs, MultiaxisMotion.cpp, PVTmotionMultiAxis.cpp, PathMotion.cpp, PhantomAxis.cpp, SampleAppsHelper.h, SingleAxisSyncOutputs.cpp, SyncOutputWithMotion.cpp, UpdateBufferPoints.cpp, axis-config-phantom-axis.cs, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, and mathblock-pdo-copy.cs.
