50using RSI.RapidCode.dotNET;
55class Homing : SampleAppTestBase
57 public void MasterBasedHoming()
72 Console.WriteLine(
"Homing successful\n");
80 public void HomingWithAKDdrive()
113 System.Threading.Thread.Sleep(100);
117 Console.WriteLine(
"HOME.MOVE");
120 UInt16 statusWordValue;
121 int isHomedvalue = 0;
124 while (isHomedvalue != 1)
127 isHomedvalue = statusWordValue >> 12;
130 Console.WriteLine(
"Axis homed.");
142 public void HomingWithDS402drive()
147 const int AXIS_NUMBER = 0;
150 const int offsetIndex = 0x607C;
151 const int offsetSubindex = 0x0;
152 const int offsetByteSize = 4;
153 const int offsetValue = 0;
156 const int methodIndex = 0x6098;
157 const int methodSubindex = 0x0;
158 const int methodByteSize = 1;
159 const int methodValue = 24;
162 const int targetSpeedIndex = 0x6099;
163 const int targetSpeedSubindex = 0x1;
164 const int targetSpeedByteSize = 4;
165 const int targetSpeedValue = 2;
168 const int originSpeedIndex = 0x6099;
169 const int originSpeedSubindex = 0x2;
170 const int orignSpeedByteSize = 4;
171 const int originSpeedValue = 10;
174 const int accelerationIndex = 0x609A;
175 const int accelerationSubindex = 0x0;
176 const int accelerationByteSize = 4;
177 const int accelerationValue = 100;
180 const int CONTROL_WORD_TO_PREP_HOMING = 15;
181 const int CONTROL_WORD_TO_START_HOMING = 31;
182 const int ACCEPTABLE_DELAY_IN_MS = 20;
183 const int STATUS_WORD_TARGET_REACHED_BIT = 0x400;
184 const int STATUS_WORD_HOMING_ATTAINED_BIT = 0x1000;
185 const int STATUS_WORD_HOMING_ERROR_BIT = 0x2000;
198 controller.
SampleWait(ACCEPTABLE_DELAY_IN_MS);
202 controller.
206 controller.
208 UInt16 statusWordValue;
209 bool cancelHome =
false;
212 while ((!cancelHome) && ((statusWordValue & STATUS_WORD_TARGET_REACHED_BIT) == 0))
220 if ((statusWordValue & STATUS_WORD_HOMING_ATTAINED_BIT) == STATUS_WORD_HOMING_ATTAINED_BIT)
222 Console.WriteLine(
"Axis homed.");
224 else if ((statusWordValue & STATUS_WORD_HOMING_ERROR_BIT) == STATUS_WORD_HOMING_ATTAINED_BIT)
226 Console.WriteLine(
"Error Occured during homing.");
240 public void CustomHome()
247 const int HOME_LIMIT_NETWORK_INDEX = 99;
248 const int HOME_LIMIT_SIG_BIT = 0;
249 const int LongTime = 15000;
261 axis.
MoveVelocity(Constants.VELOCITY, Constants.ACCELERATION);
264 Boolean done =
false;
Get the Network Index associated with a DS402 Axis Feature.
Set the slow home velocity.
Set the origin position.
Set the axis operation mode.
Set the home velocity.
NetworkNode * NetworkNode
void Home()
Execute the homing routine.
void HomeStateSet(bool homed)
Set the home state.
bool HomeStateGet()
Get the home state.
void HomeLimitCustomConfigSet(uint64_t address, int32_t bitIndex)
Sets a PDO output directly.
uint64_t NetworkInputAddressGet(int32_t index)
Send a Kollmorgen AKD ASCII command (NodeType must equal KOLLMORGEN_AKD)
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue)
Write a number in the SDO.
Get the DS402 status word.
int32_t NumberGet()
Get the axis number.
MotionController * rsiControl
RSIEventType
Event Types or Status Bits.
RSIOperationMode
DS402 modes of operation.
RSINetworkIndexType
Network index types for Axis.
