Axis: Homing
Examples of various ways to home a drive.
In this page:
📜 Homing: Drive-Based
This sample code performs Drive-Based Homing (DS402) 📖 assuming the drive follows the DS402 Standard. RSI encourages drive-based homing method over all others because it avoids network latencies.
/* This sample application demonstrates drive-based homing with a DS402-compliant drive using the RapidCode .NET API.
Drive-based homing avoids network latencies since the drive executes the homing routine.
Many drives follow the DS402 standard, making this a widely applicable homing method.
This sample configures SDO parameters, manages control word states, and monitors status word for completion.
Console.WriteLine("📜 Axis Homing: DS402 Drive");
const int offsetIdx = 0x607C;
const int offsetSub = 0x0;
const int offsetSize = 4;
const int offsetVal = 0;
const int methodIdx = 0x6098;
const int methodSub = 0x0;
const int methodSize = 1;
const int methodVal = 24;
const int targetSpeedIdx = 0x6099;
const int targetSpeedSub = 0x1;
const int targetSpeedSize = 4;
const int targetSpeedVal = 2;
const int originSpeedIdx = 0x6099;
const int originSpeedSub = 0x2;
const int originSpeedSize = 4;
const int originSpeedVal = 10;
const int accelIdx = 0x609A;
const int accelSub = 0x0;
const int accelSize = 4;
const int accelVal = 100;
const int CTRL_WORD_PREP_HOMING = 15;
const int CTRL_WORD_START_HOMING = 31;
const int DELAY_MS = 20;
const int STATUS_TARGET_REACHED = 0x400; // bit 10: target reached (homing complete)
const int STATUS_HOMING_ATTAINED = 0x1000; // bit 12: homing attained (successful)
const int STATUS_HOMING_ERROR = 0x2000; // bit 13: homing error
// get rmp controller
// 1. configure homing parameters via SDOs writes
axis.NetworkNode.ServiceChannelWrite(offsetIdx, offsetSub, offsetSize, offsetVal); // home offset
axis.NetworkNode.ServiceChannelWrite(methodIdx, methodSub, methodSize, methodVal); // home method (home type)
axis.NetworkNode.ServiceChannelWrite(targetSpeedIdx, targetSpeedSub, targetSpeedSize, targetSpeedVal); // speed during search for switch
axis.NetworkNode.ServiceChannelWrite(originSpeedIdx, originSpeedSub, originSpeedSize, originSpeedVal); // speed during search for zero
axis.NetworkNode.ServiceChannelWrite(accelIdx, accelSub, accelSize, accelVal); // home acceleration
// 2. configure control word for homing
int axisCtrlWordIdx = (int)axis.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeCONTROL_WORD_INDEX);
axis.rsiControl.NetworkOutputOverrideValueSet(axisCtrlWordIdx, CTRL_WORD_PREP_HOMING); // control word should be 15 before switching to homing mode
axis.rsiControl.NetworkOutputOverrideSet(axisCtrlWordIdx, true); // override control word
controller.SampleWait(DELAY_MS); // delay to give transitions time
// 3. configure operation mode to homing
axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE);
// 4. home
axis.rsiControl.NetworkOutputOverrideValueSet(axisCtrlWordIdx, CTRL_WORD_START_HOMING); // start homing
bool cancelHome = false;
UInt16 statusWord = axis.NetworkNode.StatusWordGet(Constants.AXIS_0_INDEX);
while ((!cancelHome) && ((statusWord & STATUS_TARGET_REACHED) == 0)) // wait until target reached or cancel
// A timeout that sets cancelHome would be a good idea for this while loop
statusWord = axis.NetworkNode.StatusWordGet(Constants.AXIS_0_INDEX); // update status word
// A short sleep or wait is appropriate so you aren't spamming this call
// evaluate homing result
if ((statusWord & STATUS_HOMING_ATTAINED) == STATUS_HOMING_ATTAINED)
Console.WriteLine("Axis homed successfully");
else if ((statusWord & STATUS_HOMING_ERROR) == STATUS_HOMING_ERROR)
Console.WriteLine("Error occurred during homing");
// clean up
axis.rsiControl.NetworkOutputOverrideSet(axisCtrlWordIdx, false);
// restore mode of operation to your desired control mode (typically CSP mode)
axis.OperationModeSet(RSIOperationMode.RSIOperationModeCYCLIC_SYNCHRONOUS_POSITION_MODE);
Set the axis operation mode.
NetworkNode * NetworkNode
Definition rsi.h:7077
Sets a PDO output directly.
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Write a number in the SDO.
Get the DS402 status word.
MotionController * rsiControl
Definition rsi.h:5521
Definition rsienums.h:621
RSIOperationMode
DS402 modes of operation.
Definition rsienums.h:1472
RSINetworkIndexType
Definition rsienums.h:1573
Source: axis-homing-ds402-drive.cs
📜 Homing: Drive-Based (AKD drive via ASCII)
This sample code performs Drive-Based Homing (AKD ASCII) 📖 with a Kollmorgen AKD drive. RSI encourages drive-based homing method over all others because it avoids network latencies.
/* This sample application demonstrates drive-based homing with a Kollmorgen AKD drive using the RapidCode .NET API.
AKD Drive-based ASCII homing uses preloaded methods available on the drive.
This allows for homing to be performed entirely in the drive without network latencies producing more accurate results.
Drive homing is the recommended homing strategy since it avoids network latencies by having the drive execute the homing routine.
Console.WriteLine("📜 Axis Homing: AKD Drive");
// check Axis type
if (axis.NetworkNode.TypeGet() != RSINodeType.RSINodeTypeKOLLMORGEN_AKD)
Console.WriteLine("Wrong Axis type. This sample requires an AKD Axis.");
// 1. get the drive ready
axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE); // set mode to homing mode
axis.NetworkNode.AKDASCIICommand("DRV.OPMODE 2"); // set drive operation mode (0=current, 1=velocity, 2=position)
axis.NetworkNode.AKDASCIICommand("HOME.AUTOMOVE 0"); // 0=disabled, 1=homing starts when drive enabled
// Make sure you know your motor's position, velocity, and acceleration units before you send any values
// 2. set limit switches
axis.NetworkNode.AKDASCIICommand("DIN5.MODE 18"); // set digital input modes - DI5 is now positive limit switch
axis.NetworkNode.AKDASCIICommand("DIN5.INV 1"); // set polarity - DI5 is now active when low
axis.NetworkNode.AKDASCIICommand("DIN6.MODE 19"); // set digital input modes - DI6 is now negative limit switch
axis.NetworkNode.AKDASCIICommand("DIN6.INV 1"); // set polarity - DI6 is now active when low
// 3. configure drive homing parameters
axis.NetworkNode.AKDASCIICommand("HOME.MODE 1"); // select homing method (MODE1 = find limit input)
axis.NetworkNode.AKDASCIICommand("HOME.V 20"); // set homing velocity
axis.NetworkNode.AKDASCIICommand("HOME.ACC 200"); // set homing acceleration
axis.NetworkNode.AKDASCIICommand("HOME.DEC 200"); // set homing deceleration
axis.NetworkNode.AKDASCIICommand("HOME.DIR 0"); // set homing direction (0=negative, 1=positive)
axis.NetworkNode.AKDASCIICommand("HOME.P 0"); // set home position
axis.NetworkNode.AKDASCIICommand("HOME.DIST 0"); // set homing distance
axis.NetworkNode.AKDASCIICommand("HOME.MAXDIST 0"); // set max homing distance
axis.NetworkNode.AKDASCIICommand("HOME.IPEAK"); // set peak current
// 4. get the axis ready
axis.ErrorLimitActionSet(RSIAction.RSIActionNONE); // set action to none so we don't get position error while drive is in control
axis.Abort(); // disable axis
axis.ClearFaults(); // clear any faults
axis.AmpEnableSet(true, Constants.AMP_ENABLE_MS); // enable the axis
System.Threading.Thread.Sleep(100); // allow time for amp enable
// 5. start homing
axis.NetworkNode.AKDASCIICommand("HOME.MOVE"); // start homing procedure (active in opmode 2 only)
Console.WriteLine("HOME.MOVE command sent");
// 6. check is homing done
UInt16 statusWord;
int isHomed = 0;
int axisIdx = axis.NumberGet();
while (isHomed != 1) // when isHomed = 1, homing has finished
statusWord = axis.NetworkNode.StatusWordGet(axisIdx);
isHomed = statusWord >> 12; // get 12th bit only - tells us homing is done when it goes high
Console.WriteLine("Axis homed");
// 7. cleanup
axis.OriginPositionSet(0.0); // set origin to 0 (needed for repeated use)
axis.Abort(); // disable the axis
axis.OperationModeSet(RSIOperationMode.RSIOperationModeINTERPOLATED_POSITION_MODE); // restore mode of operation
axis.ErrorLimitActionSet(RSIAction.RSIActionABORT); // restore position error action
Set the origin position.
Send an ASCII command to a supported Kollmorgen drive.
RSINodeType TypeGet()
Get the node type, as determined by the Vendor ID and Product Code.
int32_t NumberGet()
Get the axis number.
Definition rsienums.h:1256
RSINodeType
Valid Node types.
Definition rsienums.h:804
Source: axis-homing-akd-drive.cs
📜 Homing: Master-Based
This sample code performs a simple Master-Based Homing (DS402) 📖 routine where the RMP controller executes the homing.
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Source: axis-homing-master-based.cs
